* aclocal/version.m4: Updated to rtems-ss-20021004.
* netinet/in_cksum.c, netinet/ip_icmp.h, netinet/ip_input.c,
netinet/tcp_input.c, netinet/tcp_subr.c, netinet/tcp_var.h,
sys/queue.h: Address alignment requirements for the ARM.
* rtems/rtems_glue.c: Add IP aliasing ioctls SIOCAIFADDR and
SIOCDIFADDR.
* rtems/score/cpu.h: Fix u16 and u32 swap routines.
* src/imfs/memfile.c: Fixed case where last close of unlinked file
did not remove the resources associated with that file. Reported
by Till Straumann <strauman@slac.stanford.edu> on the mailing list.
* kern/uipc_socket.c: Make sure that small non-zero delays work.
Suggested cleanup from Eric Norum.
* rtems/mkrootfs.c: As part of PR283, remove redundant code that
creates /etc/passwd and /etc/group.
* src/getpwent.c: Per PR283, reimplement to address reentrancy problems.
* src/getgrent.c: Removed as functionality is now just a wrapper for
common routines in src/getpwent.c.
* Makefile.am: Reflect file removal.
* netinet/Makefile.am, netinet/udp_usrreq.c: Back off some of
the IP_FORWARD patch as it appears to not compile in the
current tree.
* include/rtems/libio.h: Change rtems_filesystem_read_t and
rtems_filesystem_write_t to return ssize_t to match read(2)
and write(2) respectively.
* src/dosfs/fat.c, src/imfs/deviceio.c, src/imfs/imfs.h,
src/imfs/imfs_directory.c, src/imfs/imfs_fchmod.c,
src/imfs/memfile.c: Eliminated warnings. A lot of this focus
was on changing read and write entry points to return ssize_t
as read(2) and write(2) now do.
* src/dpmemcreate.c, src/dpmemident.c, src/msgqcreate.c,
src/msgqident.c, src/partcreate.c, src/partident.c,
src/ratemoncreate.c, src/ratemonident.c, src/regioncreate.c,
src/regionident.c, src/semcreate.c, src/semident.c, src/taskcreate.c,
src/taskident.c, src/timercreate.c, src/timerident.c: Added casts
to Objects_Name to eliminate warnings.
* kern/uipc_socket.c: Fix case on SO_RCVTIMEO and SO_SNDTIMEO where
conversion into ticks can result in a 0 ticks timeout which is
the same as requesting no timeout. Reported by Sergei Organov
<osv@javad.ru>.
* kern/uipc_mbuf.c, sys/mbuf.h, netinet/udp_usrreq.c: Add
optional UDP broadcast forwarding support.
* netinet/Makefile.am: Defined FORWARD_PROTOCOL to enabled UDP
broadcast forwarding.
* src/psignal.c: Remove duplication from rtems/posix/psignal.h.
* rtems/score/cpu.h (_CPU_Initialize_vectors) Define to NULL
since it is not used.
* src/readdir_r.c: New file.
* Makefile.am: Reflect above.
* pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve
warnings.
* src/bdbuf.c: Previous fix for PR282 regressed mutex changes.
* src/bdbuf.c: Per PR282, correct problem in function
rtems_bdbuf_read() where device ioctl() is called with the
logical device number used instead of corresponding physical
device number.
* netinet/in_cksum.c: #include <string.h> for puts in generic
routines.
* rtems_webserver/md5.h: Add missing newline.
* rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
* shell/shell.c: #include <time.h>
* wrapup/Makefile.am: Eliminate LIBNAME.
* rtems.adb (IO_Initialize): Make this match the C prototype.
* src/io.c: Fixed some spacing.
* score/include/Makefile.am: Remove cpuopt.h generation.
* configure.ac: Correct package name.
Don't build ada if POSIX is disabled.
Generate cpuopt.h on the fly, filter out autoconf-2.53 PACKAGE crap.
* rtems.ads: Corrected binding for Io_Initialize.
* cpu_asm.S: More PR267 tinkering which eliminates some conditional
compilation.
* configure.ac: New.
* Makefile.am: New.
* .cvsignore: New.
* aclocal/prog-gnat.m4: New.
* configure.ac: Add ada subdir handling.
* src/adjtime.c: New file -- adjtime() support required by the
Network Time Protocol (NTP) port to RTEMS.
* src/Makefile.am: Modified to reflect above.
* aclocal/bsp-alias.m4: Remove.
* src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h>
to avoid warning on ntohl().
* rtems/rtems_glue.c: Per PR270, the BSD network code expects that
the value of the number of seconds since boot is non-zero. The
RTEMS network initialization code assures this by waiting for a
second. A more efficient technique is to simply wait until the
* macros/rtems/score/coremsg.inl: Add <string.h> to remove warning.
* src/threadidlebody.c: Add return 0 to avoid warning.
* cpu_asm.S: Per PR267, the _ISR_Handler() function never was modifying
_ISR_Nest_level, and _Watchdog_Insert() requires this variable
to be modified to determine if an interrupt may have modified
the watchdog chain. Prior to modifying _ISR_Handler(), I had
a test that would fail if _ISR_Flash was not commented out in
_Watchdog_Insert(). After this modification was made, my test
ran flawlessly.
* cpu_asm.S: Clarified some comments, removed code that forced
SR_IEP on when returning from an interrupt.
* rtems_servers/ftpd.c: Remove unused variable buf.
* pppd/md5.c: #include <string.h> to make gcc31 happy.
* rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy.
* rtems_webserver/webmain.c: Remove unused variable dir, cp.
* src/write.c (_write_r): Change prototype to match newlib's reent.h.
* pppd/utils.c: Include i960 in varargs conditional to avoid error.
* pppd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o.
* capture/Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Use .$(OBJEXT) instead of .o.
* dummy/Makefile.am: Use .$(OBJEXT) instead of .o.
* dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o.
* monitor/Makefile.am: Use .$(OBJEXT) instead of .o.
* mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* serdbg/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Use .$(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use .$(OBJEXT) instead of .o.
* untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31
warnings about abort/exit).
* src/cancelrun.c: Remove check for PTHREAD_CANCELED not being defined
to ensure that newlib patch includes it.
* libc/getservent.c: Per PR265, add #include <netinet/in.h> for
ntohl() function.
* shell/Makefile.am: Remove shell.h from EXTRA_DIST.
