specific register macros and correct code in rtems.s.
of theses targets...
returned a buffer which was not zero-filled, the reference count
was not correct. When the application exitted, the "lastClose"
handler was not being called to flush the output. This problem
had manifested itself on a variety of platforms.
The function rtems_termios_dequeue_characters() incorrectly incremented
the buffer pointers when it was invoked and there were no characters
in the ring buffer. This problem had also manifested itself on a
variety of platforms. The symptom was a strange repeating of the
data in the transmitter buffer when the transmitter serial device
was supposed to go idle.
Haven't had a chance to do an extensive shake-out of 980710, but it
builds just fine on FreeBSD 2.2.5 (after termios is fixed using the
attached patch), and the tests run fine. FYI: FreeBSD doesn't support
System V IPC out of the box, but one only needs to add three options
to the kernel build configuration file, recompile the kernel, and
you're ready.
task to be deleted was created via the same API (i.e. were of the object
class created by this API). For example, a POSIX thread calling
the rtems_task_delete(SELF) directive would incorrectly update the RTEMS
object local pointer table.
Jennifer discovered this when moving tests implemented in C using the
Classic RTEMS API into a tree of Ada tests. The Ada tests were implicitly
using POSIX services. This lead to some unexpected behavior.
not a valid object class. This was discovered while looking for
a bug reported by Jennifer.
of seconds since 1988 from RTEMS and not adding in the 1970-1988 correction
factor. Plus removed checks for data/time set since POSIX does not permit
this call to fail. GNAT 3.12 depends on this.
important distinctions between CPU models which are not made by gcc.
These distinctions help give us a more optimized memcpy(). This is important
for message queues and KA9Q.
vector number to user ISR's and other ports could pass both the vector
number and a pointer to the ISF.
cfsetispeed().
Eric Norum per request from Geoffroy Montel:
> The rtems_termios_enqueue_raw_characters function type is void.
> The problem is that I can't return an error message if the input
> buffer is full.
> Could we add a return value?
Sure, but what would you do with the overflow indication? POSIX says,
``when the input limit is reached, the saved characters are thrown away
without notice''.
Anyhow, the change is so small I've done it and enclosed the patch.
support for device driver support on tcsetattr(), and hardware
flow control callbacks.
used to calculate the amount of memory used by tasks whether the
POSIX API is enabled or disabled.
This makes the headings line up above the columns a little better.
Now that it's so easy to include/exclude the stack check code I find
myself adding it to all my `debug' targets.
+ POSIX threads
+ Ada tasks
+ POSIX threads API support
+ POSIX condition variables
+ POSIX keys (still do not account for data fields)
+ POSIX mutexes
+ POSIX queued signals
+ added macro for extra memory for task stacks
+ default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+ extra memory for Ada task stacks
so confdefs.h could see it.
the system signals.h file.
Moved POSIX_signals_Siginfo_node type definition to this file to allow
confdefs.h to know the size per queued signal.
file descriptors is user configurable.
memory requirements.
Also added variable to tell libio how many file descriptors to allocate.
gcc-target-default.cfg
by newlib.
These were noticed by Eric Norum.
a result of enabling the newlib POSIX directory.
It appears that the new glibc does not clear all the bits of the signal
set with a sigprocmask.
Bug report from Olivier Hainque <hainque@inf.enst.fr> on SPARC Solaris 2.6.
