* libcsupport/src/termios_baud2index.c,
libcsupport/src/termios_baud2num.c, libcsupport/src/termios_num2baud.c
libcsupport/src/termios_setinitialbaud.c:
Add HAVE_CONFIG_H support to let files receive configure defines.
* libmisc/bspcmdline/bspcmdline.h: Minimize includes.
* libmisc/bspcmdline/bspcmdline_get.c,
libmisc/bspcmdline/bspcmdline_getparam.c,
libmisc/bspcmdline/bspcmdline_getparamraw.c,
libmisc/bspcmdline/bspcmdline_getparamrhs.c:
* libmisc/uuid/clear.c, libmisc/uuid/compare.c,
libmisc/uuid/copy.c, libmisc/uuid/isnull.c,
libmisc/uuid/pack.c, libmisc/uuid/parse.c,
libmisc/uuid/unpack.c, libmisc/uuid/unparse.c,
libmisc/uuid/uuid_time.c:
Add HAVE_CONFIG_H guards around #include "config.h".
* libmisc/monitor/mon-symbols.c:
Add HAVE_STRINGS_H for better POSIX compliance.
libfs/src/nfsclient/src/cexphelp.c,
libfs/src/nfsclient/src/dirutils.c,
libfs/src/nfsclient/src/nfs.modini.c,
libfs/src/nfsclient/src/nfsTest.c,
libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/rpcio.modini.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-block.c,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir.c,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-inode.c,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-mutex.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-shell.c,
libfs/src/rfs/rtems-rfs-trace.c: Add HAVE_CONFIG_H support to let
* libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c,
libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetbyht.c,
libnetworking/libc/linkaddr.c, libnetworking/libc/ns_print.c,
libnetworking/libc/res_debug.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c:
* libmisc/monitor/mon-command.c:
* libmisc/shell/hexdump-display.c, libmisc/shell/hexdump-parse.c,
libmisc/shell/hexsyntax.c, libmisc/shell/main_hexdump.c,
libmisc/shell/main_rm.c:
* shttpd/auth.c, shttpd/io_emb.c, shttpd/mime_type.c,
shttpd/shttpd.c: Add HAVE_STRINGS_H for better POSIX compliance.
* libmisc/shell/dd-args.c, libmisc/shell/dd-conv.c,
libmisc/shell/dd-conv_tab.c, libmisc/shell/dd-misc.c,
libmisc/shell/dd-position.c, libmisc/shell/fdisk.c,
libmisc/shell/fts.c, libmisc/shell/hexdump-conv.c,
libmisc/shell/hexdump-display.c, libmisc/shell/hexdump-odsyntax.c,
libmisc/shell/hexdump-parse.c, libmisc/shell/hexsyntax.c,
libmisc/shell/login_check.c, libmisc/shell/login_prompt.c,
libmisc/shell/main_dd.c, libmisc/shell/main_hexdump.c,
libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/main_rtc.c, libmisc/shell/mknod-pack_dev.c:
* libfs/src/dosfs/msdos_misc.c: Part fix to PR1491.
* libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-file.c,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-shell.c: Fix printf format warning. Primarily
for size_t.
* libcsupport/src/sleep_noposix.c: Fix warning and bug.
* libmisc/shell/shell_makeargs.c: Fix bugs introduced by patch
attempting to add quoted arguments.
which included commits to RCS files with non-trunk default branches.
* libblock/src/ide_part_table.c: Functionality of
rtems_ide_part_table_get() and rtems_ide_part_table_free() was needed
internally but those routines are deprecated from the public API. So
move their contents to private static routines. Using the private
routines in this file avoids deprecation warnings and leaves
functional, although deprecated, versions for potential use by
applications.
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c,
httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c,
libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c,
libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_init.c, libnetworking/libc/res_query.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
PR 1456/cpukit
* libcsupport/src/ttyname.c: ttyname_r() when called directly (not via
ttyname()) does not prefix the caller provided buffer with the
predefined _PATH_DEV string (/dev/). Thus the directory search fails
and no tty name is returned to the caller.
* ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c,
httpd/websuemf.c, libblock/src/diskdevs.c,
libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c,
score/src/objectgetnameasstring.c: Fix warnings for ctype methods.
* libmisc/shell/shell_makeargs.c: Fix warnings.
PR 1458/cpukit
* rtems/inline/rtems/rtems/asr.inl: Do not enable signals by default.
Wait for a signal handler to be installed.
PR 1496/shell
* libmisc/shell/shell_makeargs.c: Add support for quoted arguments.
* score/include/rtems/score/interr.h,
score/src/objectinitializeinformation.c: Add new fatal error for
configuring unlimited and maximum of 0.
* libmisc/Makefile.am: Remove duplicate file from list.
* libblock/src/ramdisk-config.c: Revert accidental commit.
* libblock/src/ramdisk-config.c, sapi/include/confdefs.h:
CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it.
* libcsupport/include/rtems/libio.h, libcsupport/src/_rename_r.c:
Add a rename file op and have rename use it.
* libfs/Makefile.am, libfs/src/dosfs/msdos_rename.c,
libfs/src/imfs/imfs_rename.c: New files to support the rename file
op.
* libfs/src/imfs/imfs.h: Add rename interface.
* libfs/src/imfs/imfs_init.c: Add rename handler.
* libfs/src/imfs/miniimfs_init.c: Fix up ops struct.
* libfs/src/dosfs/msdos.h: Add msdos_rename and remove
msdos_file_link.
* libfs/src/dosfs/msdos_create.c: Remove the link call.
* libfs/src/dosfs/msdos_eval.c: Fix a path parsing bug.
* libfs/src/dosfs/msdos_init.c: Add rename handler and clean up
the struct naming.
* libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h:
Change the link call to allow linking of directories if told to
and change the unlink to handle unlink directories that are not
empty so rename can be supported.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Fix the link/unlink calls.
* libfs/src/rfs/rtems-rfs-rtems.c: Add a rename handler. Fix the
link/unlink calls.
* libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, httpd/asp.c,
libfs/src/nfsclient/src/nfs.c: Work around a newlib warning when
using the is*() family of calls.
* cpu.c: Provide body for CPU specific Idle thread. This halts on qemu
but is just a nop on a real cpu.
