Pass the executing thread as a function parameter. Obtain the executing
thread inside a thread dispatch critical section to avoid problems on
SMP.
Move implementation specific parts of corespinlock.h and
corespinlock.inl into new header file corespinlockimpl.h. The
corespinlock.h contains now only the application visible API.
Move implementation specific parts of spinlock.h and spinlock.inl into
new header file spinlockimpl.h. The spinlock.h contains now only the
Move implementation specific parts of timer.h and timer.inl into new
header file timerimpl.h. The timer.h contains now only the application
visible API.
SMP.
Move implementation specific parts of corerwlock.h and corerwlock.inl
into new header file corerwlockimpl.h. The corerwlock.h contains now
Move implementation specific parts of rwlock.h and rwlock.inl into new
header file rwlockimpl.h. The rwlock.h contains now only the
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
Move implementation specific parts of cond.h and cond.inl into new
header file condimpl.h. The cond.h contains now only the application
visible API.
SMP.
Move implementation specific parts of corebarrier.h and corebarrier.inl
into new header file corebarrierimpl.h. The corebarrier.h contains now
Move implementation specific parts of barrier.h and barrier.inl into new
header file barrierimpl.h. The barrier.h contains now only the
SMP.
Move implementation specific parts of coremsg.h and coremsg.inl into new
header file coremsgimpl.h. The coremsg.h contains now only the
Move implementation specific parts of mqueue.h and mqueue.inl into new
header file mqueueimpl.h. The mqueue.h contains now only the
Move implementation specific parts of message.h and message.inl into new
header file messageimpl.h. The message.h contains now only the
SMP.
Move implementation specific parts of coresem.h and coresem.inl into new
header file coresemimpl.h. The coresem.h contains now only the
Move implementation specific parts of semaphore.h and semaphore.inl into
new header file semaphoreimpl.h. The semaphore.h contains now only the
A common use case for disabled preemption was to ensure mutual exclusion
on single-processor configurations. On SMP this does not work.
To abandon non-preemptible tasks simplifies the scheduler.
Task variables are not supported on SMP.
Task deletion is currently not implemented on SMP configurations.
Add a configuration field which indicates if the SMP mode of operation
is enabled. This can be used to disable features unsupported on SMP,
e.g task variables.
Delete now unused file <rtems/score/isr.inl>.
The _Thread_Dispatch_is_enabled() is false if _ISR_Nest_level is not
equal to zero.
SMP.
