* | pthread_mutex_setprioceiling: fixed bug where returned priority was | Joel Sherrill | 1996-09-05 | 1 | -1/+3 | |
| | | | | not converted from core priority to posix priority. | |||||
* | nanosleep: negative value for tv_sec is no longer an error. It now | Joel Sherrill | 1996-09-05 | 1 | -4/+10 | |
| | | | | is changed into being a 0 delay. | |||||
* | new file to support GNU Ada. | Joel Sherrill | 1996-08-29 | 1 | -0/+28 | |
| | | | | | currently the only routine in this file simply returns the minimum stack size for each thread. | |||||
* | fixed typo .. changed == to != | Joel Sherrill | 1996-08-27 | 1 | -1/+1 | |
* | check that we were passed a valid mutex and ignore errors from the | Joel Sherrill | 1996-08-27 | 1 | -0/+8 | |
| | | | | | later pthread_mutex_lock. This makes our behavior more compatible with that of FSU pthreads. | |||||
* | pthread_create: changed EINVAL for no more threads back to EAGAIN | Mark Johannes | 1996-08-23 | 1 | -20/+21 | |
* | Changed all EFAULTs to EINVALs | Mark Johannes | 1996-08-19 | 1 | -7/+14 | |
* | pthread_mutex_init: added error messages for NULL mutex and EBUSY | Mark Johannes | 1996-08-19 | 1 | -6/+22 | |
* | updates from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-08-15 | 1 | -2/+4 | |
* | _Thread_Start_multitasking: added code to initialize the floating point | Joel Sherrill | 1996-08-15 | 1 | -1/+25 | |
| | | | | context of the first thread to execute. | |||||
* | changed ENOMEM error message | Mark Johannes | 1996-08-15 | 1 | -1/+4 | |
* | clock_gettime: changed assert condition to a standard error code | Joel Sherrill | 1996-08-15 | 1 | -2/+3 | |
| | | | | clock_getres: now checking for a null pointer being passed in | |||||
* | sched_rr_get_interval: converted assert condition into a standard error | Joel Sherrill | 1996-08-15 | 1 | -1/+5 | |
| | | | | code and added check for a NULL interval being passed in. | |||||
* | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1996-08-15 | 1 | -0/+7 | |
| | | | | condition variable | |||||
* | pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO | Mark Johannes | 1996-08-15 | 1 | -4/+6 | |
* | pthread_kill: moved check for SA_SIGINFO to allow for validation of all | Mark Johannes | 1996-08-15 | 1 | -7/+7 | |
| | | | | parameters. Also changed returns to macro of -1 and errno set. | |||||
* | fixed typo for NOTSUP -> ENOTSUP | Mark Johannes | 1996-08-15 | 1 | -13/+12 | |
* | commented of ENOTSUP until fixed in newlib | Mark Johannes | 1996-08-14 | 1 | -0/+1 | |
* | pthread_cond_timedwait: added error cases for abstime | Mark Johannes | 1996-08-14 | 1 | -0/+11 | |
* | pthread_cond_destroy: added enable dispatch to EBUSY case | Mark Johannes | 1996-08-13 | 1 | -1/+3 | |
* | pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First | Mark Johannes | 1996-08-13 | 1 | -3/+3 | |
* | pthread_cond_destroy: EBUSY case now uses Thread_queue_First | Mark Johannes | 1996-08-13 | 1 | -1/+1 | |
* | removed count from Thread_queue_Control | Mark Johannes | 1996-08-13 | 1 | -1/+0 | |
* | removed Thread_queue_Get_number_waiting | Mark Johannes | 1996-08-13 | 2 | -25/+0 | |
* | deleted a line for spacing correction | Joel Sherrill | 1996-08-13 | 1 | -1/+0 | |
* | _POSIX_Condition_variables_Wait_support: changed status of lock and unlock ↵ | Mark Johannes | 1996-08-13 | 1 | -2/+2 | |
| | | | | to return EINVAL is there is an error | |||||
* | _POSIX_Condition_variables_Wait_support: fixed the timeout sequence. | Mark Johannes | 1996-08-13 | 1 | -7/+25 | |
* | fixed spacing | Joel Sherrill | 1996-08-13 | 1 | -2/+2 | |
* | removed errors for TOD not set yet. | Joel Sherrill | 1996-08-13 | 1 | -9/+9 | |
| | | | | made nanosleep return -1/EINTR for being interrupted for a signal. | |||||
* | clock_getres: added error check for NULL pointer being passed in. | Joel Sherrill | 1996-08-12 | 1 | -0/+3 | |
* | nanosleep: verify rqtp parameter is non-NULL. | Joel Sherrill | 1996-08-12 | 1 | -0/+7 | |
| | | | | nanosleep: return 0 time remaining for a yield case. | |||||
* | time: It is not an error if the TOD is not set. | Joel Sherrill | 1996-08-12 | 1 | -2/+4 | |
* | Wait_support: removed the calls to mutex core to posix status codes | Mark Johannes | 1996-08-12 | 1 | -2/+2 | |
* | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1996-08-12 | 1 | -12/+0 | |
* | fixed spacing ; moved a dummy MP support routine to clean up printout. | Joel Sherrill | 1996-08-12 | 1 | -9/+10 | |
* | _POSIX_Mutex_Get: made null id an error | Joel Sherrill | 1996-08-12 | 1 | -0/+5 | |
* | pthread_mutex_getprioceiling: added error check for null old_ceiling | Joel Sherrill | 1996-08-12 | 1 | -2/+4 | |
| | | | | | pthread_mutex_setprioceiling: added comment indicating an error was impossible to generate. | |||||
* | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1996-08-12 | 1 | -0/+12 | |
* | _POSIX_Condition_variables_Wait_support: added ↵ | Mark Johannes | 1996-08-12 | 1 | -4/+5 | |
| | | | | _POSIX_Mutex_From_core_mutex_status for the two calls to the mutex manager | |||||
* | _POSIX_Condition_variables_Signal_support: added setting mutex back to NULL | Mark Johannes | 1996-08-12 | 1 | -5/+7 | |
| | | | | | | if the queue has been emptied of waiting tasks. _POSIX_Condition_variables_Wait_support: added error check for different mutexesfor the same condition variable. Also added _Thread_queue_Enter_critical_section | |||||
* | pthread_mutexattr_setprioceiling: fixed typo | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
* | pthread_mutexattr_setprioceiling: valid priority ceiling check looked at | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
| | | | | value in attribute structure instead of passed in priority | |||||
* | pthread_mutexattr_getprotocol: added check for attribute structure being | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
| | | | | initialized | |||||
* | added code to catch NULL pointers for return values passed to get routines | Joel Sherrill | 1996-08-09 | 1 | -6/+9 | |
* | sched_yield: was not invoking the dispatcher. | Joel Sherrill | 1996-08-09 | 1 | -1/+3 | |
* | merged remote object id and invalid id error cases. | Joel Sherrill | 1996-08-09 | 1 | -6/+3 | |
* | CORE_mutex_Status: added CORE_MUTEX_STATUS_CEILING_VIOLATED to enum | Mark Johannes | 1996-08-08 | 1 | -1/+2 | |
* | _POSIX_signals_Clear_signals: added this routine | Mark Johannes | 1996-08-08 | 1 | -12/+36 | |
| | | | | _POSIX_signals_Get_highest: changed initial starting signal to SIGHUP, still needs SIGFIRSTNOTRT | |||||
* | added ss_high_priority field to support sporadic server. | Joel Sherrill | 1996-08-08 | 1 | -0/+1 | |
* | _MPCI_Register_packet_processor: Changed prototype of fist parameter name to ↵ | Mark Johannes | 1996-08-08 | 1 | -1/+1 | |
| | | | | the_class |
