* | Bug fix from Eric Norum: | Joel Sherrill | 1997-09-19 | 1 | -1/+0 |
| | | | | | | | | | | | After weeks of trying to figure why my RTEMS/KASQ server crashes now and then I found a nasty bug I introduced in adding multiple-driver support to libio. The bug only affects `add-on' driver classes (like the networking code). Old-style file descriptors were not affected. The bug cleared 32 bytes of memory (unspecified location) whenever a `close' of a socket was performed! I was clearing an IOP I hadn't allocated -- and the pointer wasn't initiallized, either! | ||||
* | updated | Joel Sherrill | 1997-09-16 | 1 | -4/+11 |
* | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 1997-08-28 | 2 | -64/+9 |
| | | | | but not in newer RTEMS. | ||||
* | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 1997-08-28 | 2 | -1/+3 |
* | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1997-08-28 | 1 | -3/+5 |
* | Added error numbers and changed default error code from 0 to -1 for | Joel Sherrill | 1997-08-27 | 1 | -7/+9 |
| | | | | error number mapping. | ||||
* | Corrected bug per Katsutoshi Shibuya's report: | Joel Sherrill | 1997-08-22 | 2 | -4/+4 |
| | | | | | | | The definition of "BEGIN_DATA" should not be null; should be ".data". Also, the definition of "BEGIN_BSS" should be ".bss". For this error, the compiled object has codes that write on the text segment area. It is fatal when the code runs on ROM. | ||||
* | Removed assert condition when not initialized or there are 0 periods. | Joel Sherrill | 1997-08-22 | 1 | -0/+5 |
* | Moved reentrant wrappers into their own file. | Joel Sherrill | 1997-08-22 | 1 | -4/+2 |
* | Fixed iop/memory leak bug reported by Dan Dickey. | Joel Sherrill | 1997-08-22 | 1 | -1/+6 |
* | Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER. | Joel Sherrill | 1997-08-22 | 1 | -10/+15 |
* | Added commit about missing support for condition initializer. | Joel Sherrill | 1997-08-22 | 1 | -0/+1 |
* | new implementation of mc68681.h | Joel Sherrill | 1997-08-04 | 1 | -72/+291 |
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 1 | -4/+19 |
* | moved from main include directory | Joel Sherrill | 1997-08-04 | 5 | -0/+478 |
* | Added these files to contain bodies for routines included in the API | Joel Sherrill | 1997-08-02 | 2 | -0/+101 |
| | | | | | but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | ||||
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 2 | -0/+191 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 2 | -4/+110 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 4 | -17/+107 |
* | fixed typo | Joel Sherrill | 1997-07-18 | 1 | -4/+4 |
* | Reordered specs. | Joel Sherrill | 1997-07-10 | 1 | -4/+4 |
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 1 | -11/+10 |
* | Repository damaged -- files readded. | Joel Sherrill | 1997-07-09 | 1 | -0/+214 |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 2 | -2/+2 |
| | | | | Ada interface where entry is a keyword. | ||||
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 1 | -0/+2 |
* | Added post switch extension. | Joel Sherrill | 1997-07-09 | 1 | -0/+5 |
* | Corrected typos and spacing. | Joel Sherrill | 1997-07-09 | 1 | -3/+3 |
* | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 1997-07-09 | 2 | -0/+8 |
* | Added True and False constants for RTEMS.Boolean types. This necessitated | Joel Sherrill | 1997-06-03 | 2 | -8/+36 |
| | | | | making sure every True/False reference was fully qualified. | ||||
* | Added RTEMS boolean constants. | Joel Sherrill | 1997-06-03 | 1 | -0/+3 |
* | Added Pending_Events and lined up other event constants | Joel Sherrill | 1997-06-03 | 1 | -33/+34 |
* | added more constants and fixed numer | Joel Sherrill | 1997-06-03 | 2 | -24/+64 |
* | added Signal constants, Is_Status_Successful, and Attribute constants. | Joel Sherrill | 1997-06-03 | 2 | -5/+74 |
* | added rtems_interrupt_level_attribute routien to return a properly | Joel Sherrill | 1997-06-03 | 2 | -16/+6 |
| | | | | shifted interrupt_level attribute field and RTEMS_INTERRUPT_MASK. | ||||
* | added Minimum_Stack_Size and Mode constants | Joel Sherrill | 1997-06-02 | 1 | -8/+23 |
* | added new files from test area. | Joel Sherrill | 1997-06-02 | 2 | -0/+3372 |
| | | | | This code has successfully been used to run sp01. | ||||
* | Added support for context switching the data used by the gcc m68k | Joel Sherrill | 1997-05-28 | 3 | -2/+31 |
| | | | | | | software floating point emulation code. Code implemented by Karen Sara Looney <Karen.Looney@colorado.edu> with much email assistance from Joel. | ||||
* | Corrected by adding check for NULL address passed into get_status | Joel Sherrill | 1997-04-25 | 1 | -0/+3 |
| | | | | directive. | ||||
* | Added to comment header block to include new status directive. | Joel Sherrill | 1997-04-25 | 1 | -0/+1 |
* | Patch from Chris John <cjohns@awa.com.au> to add use of a select statement | Joel Sherrill | 1997-04-22 | 2 | -2/+138 |
| | | | | | | in the unix port idle thread task. This should keep the entire application from blocking when any component does a blocking application. Also added TOD_MICROSECONDS_TO_TICKS. | ||||
* | promote TOD_MICROSECONDS_TO_TICKS through API as RTEMS_MICROSECONDS_PER_TICK. | Joel Sherrill | 1997-04-22 | 1 | -0/+2 |
* | multiprocessing fixed on linux by fixing cpu.c so correct form of | Joel Sherrill | 1997-04-22 | 1 | -3/+4 |
| | | | | semctl was being invoked. | ||||
* | updated with new license information per Tony Bennett. | Joel Sherrill | 1997-04-22 | 3 | -30/+10 |
* | File changed to reflect change in license and copyright. | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 250 | -1205/+1205 |
* | Added FPSP support for MC68040 | Joel Sherrill | 1997-04-16 | 1 | -2/+19 |
* | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1997-04-15 | 2 | -4/+10 |
| | | | | | of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | ||||
* | printing task names now instead of id numbers | Joel Sherrill | 1997-04-09 | 1 | -3/+16 |
* | new files. | Joel Sherrill | 1997-04-09 | 5 | -0/+415 |
* | added code to prevent attempts to clean up the library when rtems is | Joel Sherrill | 1997-04-09 | 1 | -0/+8 |
| | | | | down. |
