significant things:
and PowerPC
same code base.
compiled and there is no comparable code for the C4x.
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
that contains:
* Removes MKLIB
handling)
<andrew@pogo.wv.tek.com>.
Eric Norum <eric@cls.usask.ca>.
./bootstrap
converted to automake.
pc686.cfg was not present.
Janovetz <janovetz@tempest.ece.uiuc.edu> to return a status from
network initialization rather than panic'ing. It changes a bunch
of rtems_panics to printfs and returns a status from
rtems_bsdnet_initialize_network().
I'd like to propose a change to RTEMS task variables that I think would
make them more useful. I think that it is early enough in their
existence to still make changes to their API.
1) Change type from `int' to `void *'.
2) Add extra argument to task_variable_add -- if non-NULL, a pointer to
a `destructor' function to be called when the task exits. This function
would be called with that task's value of the task variable as its
argument. In many cases, the `dtor' function could be `free'.
rtems_status_code rtems_task_variable_add (
rtems_id tid, void **ptr, void (*dtor)(void *));
rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr);
This would be all we'd need to cleanly and efficiently support C++
per-thread exception information without dragging in all that POSIX API
stuff.
were done by Joel.
and _CORE_message_queue_Insert_message for posix message queues.
+ Yellow line tested new source
Added correct include file.
+ Yellow lined tested routine with Posix message queue test (01)
+ Added messsage size check
+ Debugged and yellowed out routine
+ Yellow line tested source.
+ Removed extra flag attribute from message queue structure.
+ Yellow-lined all posix message queue routines.
queues as well as the messages.
was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>.
