Use a dedicate system initialization step to zero the memory used for
the workspace and C program heap.
This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is
not configured.
Canonicalize CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY and use
defined/undefined instead of TRUE/FALSE.
Close #3862.
Update #3863.
Update #3865.
Do not cast to unsigned int to avoid an unsigned long long enum type.
Use a multiplication/division instead to preserve the signedness of the
POSIX status.
Update #3861.
Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST
to allow applications and support functions to place system
initialization handlers behind the standard handlers.
Update #3838.
Update #3838.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
Use a dedicated system initialization step for the stack checker
interrupt stack support.
Update #3838.
Add new BSP system initialization step for work to be performed before
the work areas are initialized.
Update #3838.
Update #3838.
Update #3838.
Only align per-processor data in SMP configurations.
Fix T_check_task_context() in RTEMS_SMP with RTEMS_DEBUG configurations.
Modify the status code returned by _CORE_message_queue_Submit() when it
detects a wait about to happen in an ISR (which would be deadly) to
return a status which translated to EAGAIN instead of ENOMEM.
This is only relevant for POSIX message queues, since Classic API message
queues cannot block on send.
The motivation is to match the "most related" errno value returned from
mq_send() and mq_timedsend() according to POSIX, via Open Group:
[EAGAIN]
The O_NONBLOCK flag is set in the message queue description
associated with mqdes, and the specified message queue is full.
or via the RTEMS POSIX users documentation
EAGAIN
The message queue is non-blocking, and there is no room on the queue
for another message as specified by the mq_maxmsg.
Neither of these matches the case ofi avoided ISR wait perfectly, but
they seem to be the closest equivalent, unless it is desirable to keep a
new non-standard error for this case. It is presumed that this is not
desirable.
The previously returned ENOMEM error value is not documented in either
the Open Group or the RTEMS POSIX uses documentation. A companion patch
corrects the documentation to include this error condition.
Based on the discussion in:
https://lists.rtems.org/pipermail/devel/2020-January/056891.html
closes #3857.
Message-Id: <CAF9ehCW5P12ZkZja4UPYTbdBFUyC1VKVL-tU7nyUtvK1Lz2Z3g@mail.gmail.com>
The FACE Technical Standard, Edition 3.0 and later require the definition
of the subcommand SOCKCLOSE in <devctl.h>.
Reference: ​https://www.opengroup.org/face
closes #3856.
Dead code identified by Coverity (CID 1456674). The value of ret
at line 358 is always 0.
Dead code identified by Coverity (CID 1456678). The value of ret
at line 293 is always 0.
Remove THREAD_STATUS_PROXY_BLOCKING and replace it with
STATUS_PROXY_BLOCKING.
Update #2408.
The objects node is statically initialized to one. Clear the node field
before it is set.
Update #3621.
Use the user provided now handler of the test configuration to get the
time in T_now().
Use CONFIGURE_MAXIMUM_PROCESSORS to configure the EDF SMP scheduler
context. This avoids hard to debug configuration errors resulting in
memory corruptions.
Close #3815.
- This patch is based on the patch attached to #3552 submitted
by jameszxj.
Closes #3552
Bug was introduced by previous commit.
Update #3845.
Update #3845.
Update #3753.
Remove CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE.
Update #3844.
This function is unused.
Update #3735.
Update #3735.
Update #3735.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Update #3841.
Obsolete the CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE configuration
option.
Update #3735.
Obsolete undocumented configuration options CONFIGURE_MAXIMUM_FIFOS and
CONFIGURE_MAXIMUM_PIPES. Replace these options with the new
CONFIGURE_IMFS_ENABLE_MKFIFO configuration option.
Update #3840.
Two use cases were envisioned for this.
1) a BSP or application which desires to update a real-time clock
when the RTEMS TOD is set.
2) a paravirtualized BSP can use this to propagate setting the time
in an RTEMS application to the hosting environment. This enables
the entire set of applications in the virtualized environments
to have a single consistent TOD.
Use self-contained condition variables instead of Classic API barriers.
This simplifies the implementation and configuration.
Update #3840.
Closes #3839
Use watchdog for shared memory driver instead of a Classic API Timer.
The MrsP semaphore implementation predates the addition of
self-contained synchronization objects. At this time, the potential
memory reduction was justified considering the more complex
configuration and additional use of the workspace. With the
availability of self-contained synchronization options, e.g. POSIX
mutexes, this is no longer justified. Memory constrained applications
should use the self-contained synchronization objects. Remove the
CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option. This has only an
impact on applications which use SMP and a large number of scheduler
instances.
Update #3833.
Move variant, discipline, and global information to flags stored in a
node pointer of active semaphores.
Update #3833.
Use a system initialization handler instead of a legacy IO driver.
Update #3834.
This function is no longer supported by the standard clock driver
implementation (clockimpl.h).
Update #3436.
