The while loop, loops infinitely in case of raw FDT data.
The loop condition (size) is not modified during iterations.
Check only for invalid modes if a valid handler is presented to
rtems_signal_catch(). When NULL is used for the handler, ASR processing
is disabled and the mode is not used.
Update #4244.
Do the ASR and preemption mode change only if requested by the mode
mask. The bug was introduced by
508f868237225a75e566d9fd304206363cfe441d.
Do not mix checks for different error indicators (RTEMS_NOT_DEFINED and
RTEMS_INVALID_NUMBER). This simplifies the specification of
rtems_semaphore_create().
Rejecting initially locked MrsP semaphores was due to a limitiation of
the early limitiation of the MrsP protocol. This limitation no longer
exists.
MrsP semaphores are a generalization of the priority ceiling semaphores
for SMP configurations. Priority ceiling semaphores are required to use
the priority task wait queue discipline. Require this discipline also
for MrsP semaphores.
Close #4347.
Move the CPU time budget to the thread configuration. This simplifies
_Thread_Initialize().
Overview
The errata is worked around in the kernel without requiring toolchain
modifications. It is triggered the JMPL/RETT return from trap instruction
sequence never generated by the compiler and. There are also other
conditions that must must be true to trigger the errata, for example the
instruction that the trap returns to has to be a JMPL instruction. The
errata can only be triggered if certain data is corrected by ECC
(inflicted by radiation), thus it can not be triggered under normal
operation. For more information see:
www.gaisler.com/notes
Affected RTEMS target BSPs:
* GR712RC
* UT699
* UT700/699E
The work around is enabled by defining __FIX_LEON3_TN0018 at build time.
After applying the following GCC patch, GCC will set the define when
compiling for an affected multilib:
* GR712RC (-mcpu=leon3 -mfix-gr712rc)
* UT700/UT699E (-mpcu=leon3 -mfix-ut700)
* UT699 (-mcpu=leon -mfix-ut699)
When building for another multilib and TN0018 is still required, it
is possible to enable it on the RTEMS kernel configure line using the
TARGET_CFLAGS (-D__FIX_LEON3FT_TN0018) or other by other means.
The following GCC patch sets __FIX_LEON3FT_TN0018 for the affected RTEMS
multilibs:
diff --git a/gcc/config/sparc/rtemself.h b/gcc/config/sparc/rtemself.h
index 6570590..ddec98c 100644
--- a/gcc/config/sparc/rtemself.h
+++ b/gcc/config/sparc/rtemself.h
@@ -33,6 +33,8 @@
builtin_assert ("system=rtems"); \
if (sparc_fix_b2bst) \
builtin_define ("__FIX_LEON3FT_B2BST"); \
+ if (sparc_fix_gr712rc || sparc_fix_ut700 || sparc_fix_ut699) \
+ builtin_define ("__FIX_LEON3FT_TN0018"); \
while (0)
Workaround Implementation
In general there are two approaches that the workaround uses:
A) avoid ECC restarting the RETT instruction
B) avoid returning from trap to a JMPL instruction
Where A) comes at a higher performance cost than B), so B) is used
where posssible. B) can be achived for certain returns from trap
handlers if trap entry is controlled by assembly, such as system calls.
A)
A special JMPL/RETT sequence where instruction cache is disabled
temporarily to avoid RETT containing ECC errors, and reading of RETT
source registers to "clean" them from incorrect ECC just before RETT
is executed.
B)
The work around prevents JMPL after system calls (TA instruction) and
modifies assembly code on return from traps jumping back to application
code. Note that for some traps the trapped instruction is always
re-executed and can therefore not trigger the errata, for example the
SAVE instruction causing window overflow or an float instruction causing
FPU disabled trap.
RTEMS SPARC traps workaround implementation:
NAME NOTE TRAP COMMENT
* window overflow 1 - 0x05 always returns to a SAVE
* window underflow 1 - 0x06 always returns to a RESTORE
* interrupt traps 2 - 0x10..1f special rett sequence workaround
* syscall 3 - 0x80 shutdown system - never returns
* ABI flush windows 2 - 0x83 special rett sequence workaround
* syscall_irqdis 4 - 0x89
* syscall_irqen 4 - 0x8A
* syscall_irqdis_fp 1 - 0x8B always jumps back to FP instruction
* syscall_lazy_fp_switch 5 - 0x04 A) jumps back to FP instruction, or to
B) _Internal_error() starting with SAVE
1) no workaround needed because trap always returns to non-JMPL instruction
2) workaround implemented by special rett sequence
3) no workaround needed because system call never returns
4) workaround implemented by inserting NOP in system call generation. Thus
fall into 1) when workaround is enabled and no trap handler fix needed.
5) trap handler branches into both 1) and returning to _Internal_error()
which starts with a SAVE and besides since it shuts down the system that
RETT should never be in cache (only executed once) so fix not necessary
in this case.
Any custom trap handlers may also have to be updated. To simplify that,
helper work around assembly code in macros are available in a separate
include file <libcpu/grlib-tn-0018.h>.
Close #4155.
Close #4336.
Update #4336.
Update #4336.
CID 1437650: Unchecked return value from library in rtems_shell_help().
Closes #4291
CID 1255518: Unchecked return value from library in pwdgrp_init().
Closes #4282
CID 1063856: Unchecked return value from library in
rtems_shell_main_chmod().
Closes #4281
CID 1049146: Unchecked return value from library in get_clock().
CID 1049147: Unchecked return value from library in get_random_fd().
Closes #4280
CID 1255318: Unchecked return value in display_line().
Updates #4257
CID 1399723: Missing break in switch in pci_read_addressable().
Closes #4279
CID 1399726: Missing break in switch in task_usage().
CID 1399728: Missing break in switch in task_usage().
CID 1399742: Missing break in switch in task_usage().
Closes #4278
Run with stack alignment faults enabled under RTEMS_DEBUG to catch any
stack misalignments early. This makes it easier to track them down
should they ever occur.
According to commentary on GCC bug
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99143, the alignment
behavior of linker sections on which RTEMS has relied was never
guaranteed to be consistent across platforms and any alignment
requirements for linker sections needs to be enforced explicitly.
This adds those explicit alignment requirements.
Closes #4255.
The Per_CPU_Control::isr_dispatch_disable is a 32-bit integer.
Close #4206.
Make sure that a user-provided stack size is the minimum size allocated
for the stack.
Make sure we meet the stack alignment requirement also for CPU ports
with CPU_STACK_ALIGNMENT > CPU_HEAP_ALIGNMENT.
Ensure that CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE meets the task
storage alignment requirement.
Make sure we meet the stack alignment requirement for user-provided
thread storage areas.
Clarify CPU_STACK_ALIGNMENT requirements in no_cpu port. Add static
assertion to enforce CPU_STACK_ALIGNMENT requirements.
In uniprocessor configurations, we can simplify rtems_signal_catch().
Add a validation test for the SMP special case.
Use the invariant that an ASR is only processed if ASR processing is
enabled.
Remove superfluous check for the objects maximum since the maximum is
also used as a loop limit.
Fix formatting.
Check for an integer overflow. Add a validation test for task create
errors.
CID 1468688: Unchecked return value in snapshot_thread().
Closes #4262
CID 1459004: Unchecked return value in endgrent().
Closes #4261
CID 1456677: Unchecked return value in resolve_hold_back().
Closes #4260
CID 1399710: Unchecked return value in printer_task().
CID 1472764: Unchecked return value in rtems_print_printer_task().
Closes #4258
Update #4267.
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Update #4267.
Update #4267.
Update #4267.
Update #4267.
Update #4267.
Update #4269.
Update #4269.
Use the right system initialization step for the stack allocator
initialization. Do the stack allocator initialization before the
workspace initialization so that _Memory_Allocate() can be used to get
memory for the allocator.
This type is not only used by Task Manager directives. This is a
preparation to move the rtems_scheduler_*() directives from
<rtems/rtems/tasks.h> to a new <rtems/rtems/scheduler.h>.
