Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2843.
Update #2840.
Update #2843.
Update #2843.
Update #2843.
This simplifies the CLOCK_MONOTONIC based time services. It is
potentially important for libbsd.
Close #3265.
Rename PER_CPU_WATCHDOG_MONOTONIC to PER_CPU_WATCHDOG_TICKS. Add new
PER_CPU_WATCHDOG_MONOTONIC which is based on the system uptime (measured
by timecounter).
Close #3264.
Rename _Watchdog_Realtime_from_*() to _Watchdog_Ticks_from_*().
Update #3264.
Avoid unnecessary lock acquire/release operations. Get realtime via
timecounter only if necessary.
Update #3264.
Setting the PIRQ to 0 before reading the data produces a short clock pulse.
Moving the write to after reading the data fixes the issue.
Close #3173
At least with Binutils 2.30 and GCC 7.3 we need symbol definitions
without the leading underscore.
Fixed in Newlib 1658a57715de93d50983f34e75216101eb373993.
GCC 7.3 defines __USER_LABEL_PREFIX__ to nothing.
Some time ago the Classic API object size related parameters were
changed to use size_t. Reflect this in the Ada bindings.
Update #3082.
Update #3111.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3082.
The RTEMS_BLKIO_SETBLKSIZE IO control expects an uint32_t parameter and
not a size_t which is 64-bits on 64-bit targets.
Update #3082.
Update #3085.
A rtems_configuration_is_smp_enabled() inside a !defined( RTEMS_SMP)
block makes no sense.
Remove !defined( RTEMS_SMP ) conditions.
Test tm04 works now again.
Update #3000.
Closes @3267.
Update #3254.
Update #3260.
Update #3254.
Update #3260.
Update #3269.
Update #3254.
Update #3260.
Update #3254.
Update #3260.
Update #2702.
Update #2555.
Update #3254.
Update #3254.
Update #3254.
Prepare for header file move to common include directory.
Update #3254.
