* libcsupport/src/__assert.c: Rework autoconf defines.
* libcsupport/src/__brk.c: Eliminate RTEMS_UNIX.
Remove unused includes.
* libcsupport/src/getgroups.c: Remove unused includes.
* libcsupport/src/setpgid.c: Remove unused includes.
* libcsupport/src/malloc_p.h: Remove #include <inttypes.h>.
* libnetworking/net/ppp_tty.c: Reflect termios_baud_to_number having
been renamed to rtems_termios_baud_to_number.
* libcsupport/src/termios_setinitialbaud.c:
Include rtems/termiostypes.h.
Rename termios_set_initial_baud into rtems_termios_set_initial_baud.
* libcsupport/src/termios_num2baud.c:
Rename termios_number_to_baud into rtems_number_to_baud.
* libcsupport/src/termios_baud2num.c:
Rename termios_baud_to_number into rtems_termios_baud_to_number.
* libcsupport/src/termios_baud2index.c:
Rename termios_baud_to_index into rtems_termios_baud_to_index.
* libcsupport/include/rtems/termiostypes.h: Include stdlib.h.
Add rtems_termios_baud_t.
Rename termios_number_to_baud into rtems_termios_number_to_baud,
termios_baud_to_number into rtems_termios_baud_to_number,
* libnetworking/lib/tftpDriver.c: Remove vim: meta-tags.
* score/src/heapwalk.c(Heap_Walk_printer): Add missing return type.
* libnetworking/lib/tftpDriver.c (rtems_tftp_eval_path):
Add missing parameter pathlen.
* libmisc/shell/hexdump-conv.c: Use %lc instead of %C.
* rtems/src/regiondelete.c, rtems/src/regiongetfreeinfo.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c: Remove warnings.
* score/src/objectidtoname.c: Remove error which cannot be reached
since API that calls this checks the error first.
* score/src/objectsetname.c: Adjust handling of length.
rtems/src/regionreturnsegment.c: Do not initialize return status to
RTEMS_INTERNAL_ERROR.
* include/rtems/pci.h: Revert extern inline patch.
* rtems/score/cpu.h: Define CPU_STRUCTURE_ALIGNMENT to be on a 4 byte
boundary.
* libmisc/capture/capture.c, posix/src/pthread.c, rtems/src/tasks.c,
score/include/rtems/score/userext.h: Eliminate use of deprecated
rtems_extension. Re-add prototype for _User_extensions_Add_API_set.
* libcsupport/include/rtems/libcsupport.h,
libcsupport/src/newlibc_reent.c: Eliminate use of deprecated
rtems_extension.
* score/Makefile.am: Re-add file accidentally deleted by Sebastian.
* score/inline/rtems/score/thread.inl: Restore the BSP context -- do
not save the current. This routine is also marked as not returning
which saves the exit path code.
* include/rtems/pci.h: Change extern inline to static inline.
* sapi/include/rtems/extension.h, sapi/src/extensiondelete.c,
sapi/src/extensionident.c, sapi/src/extensioncreate.c,
sapi/inline/rtems/extension.inl, score/include/rtems/score/userext.h,
score/src/userextthreaddelete.c, score/src/userext.c,
score/src/userextthreadcreate.c, score/src/userextremoveset.c,
score/src/userextthreadbegin.c, score/src/userextaddset.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/userextthreadrestart.c: Documentation. The types
User_extensions_routine and rtems_extension are now deprecated.
Removed unused types User_extensions_thread_post_switch_extension and
rtems_task_post_switch_extension. Renamed _User_extensions_Add_API_set()
in _User_extensions_Add_set(). Renamed _User_extensions_Add_set() in
_User_extensions_Add_set_with_table().
* score/src/userextaddapiset.c: Removed file.
* score/Makefile.am: Update.
* score/src/heap.c, score/include/rtems/score/heap.h: Reduced alignment
requirement for CPU_ALIGNMENT from four to two.
* posix/include/rtems/posix/threadsup.h: Add no return atrribute to
_POSIX_Thread_Exit().
* rtems/score/cpu.h: Add no return atrribute to _CPU_Context_restore()
since it is used for restarting self.
* libmisc/shell/hexdump-odsyntax.c: Fix failure on SH2e where there is
only single precision float.
* libcsupport/src/getpagesize.c, posix/Makefile.am: Eliminate one copy
of getpagesize() and make it return an int.
* posix/src/getpagesize.c: Removed.
* posix/Makefile.am: Add getpagesize(). Now required by GNU Ada.
* posix/src/getpagesize.c: New file.
* rtems/asm.h: Added macro to define ARM functions.
* cpu_asm.S, arm_exc_handler_low.S: Use macro from above.
* score/src/userextaddapiset.c: Disable code that is only used when
ITRON or POSIX is enabled.
* libmisc/shell/utils-cp.c: Include <utime.h> instead of
<sys/utime.h> for better POSIX compilance.
* libcsupport/src/malloc_p.h: Rely upon uintmax_t and PRIuMAX being
provided.
* libcsupport/src/libio_init.c, libcsupport/src/libio.c:
Reflect rtems_libio_number_iops being uint32_t.
* libcsupport/src/libio_init.c: Reflect rtems_libio_number_iops
being uint32_t.
* libcsupport/src/libio_init.c: Remove extern uint32_t
rtems_libio_number_iops.
