path: root/cpukit (follow)
* 2004-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-154-83/+66
| | | | | | | | | | | | | * Makefile.am: Remove wrapup. * pppd/Makefile.am: Build libpppd. Use automake-compilation rules. * rtems_servers/Makefile.am: Build libftpd. Use automake-compilation rules. * rtems_telnetd/Makefile.am: Build libtelnetd. Use automake-compilation rules. * rtems_webserver/Makefile.am: Build libhttpd. Use automake-compilation rules. * wrapup/Makefile.am: Remove (Unused).
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-144-0/+14
| | | | | | | | * pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * rtems_servers/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-5/+10
| | | | | * wrapup/Makefile.am: Remove $(ARCH)/$(dirstamp). Add TMPINSTALL_FILES to CLEANFILES.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-0/+12
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. Add cpuopts.h to DISTCLEANFILES.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1432-22/+163
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-143-5/+23
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. * netinet/in_cksum.c: #include netinet/in_cksum_<cpu>.h.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1412-4/+61
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-3/+10
| | | | | * Makefile.am: Move include_adadir into RTEMS_ADA condional block. Add CLEANFILES. Add PREINSTALL_FILES to CLEANFILES.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-144-8/+12
| | | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. * automake/local.am: Remove depend-am. * automake/subdirs.am: Remove depend-recursive.
* 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-146-882/+16
| | | | | | | | | | | | | | PR/549 networking * netinet/in_cksum_powerpc.h: New (copy of in_cksum_powerpc.c). * netinet/in_cksum_powerpc.c: Remove. * netinet/in_cksum_i386.h: New (copy of in_cksum_i386.c). * netinet/in_cksum_i386.c: Remove. * netinet/in_cksum_arm.h: New (copy of in_cksum_arm.c). * netinet/in_cksum_arm.c: Remove. * netinet/in_cksum_m68k.c: New (copy of in_cksum_m68k.c). * netinet/in_cksum_m68k.c: Remove. * netinet/Makefile.am: Reflect changes above.
* 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-122-3/+7
| | | | | PR 548/rtems * Makefile.am: Add src/envlock.c.
* 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1228-14/+70
| | | | * configure.ac: Requires automake >= 1.8.1.
* 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-122-2/+6
| | | | * cpu/Makefile.am: Use @RTEMS_CPU@ instead of $(RTEMS_CPU).
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-114-42/+14
| | | | | | | | | | * aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT. Remove PROJECT_TOPdir (Unused). * aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE. Expand ${PROJECT_ROOT}. Remove RTEMS_ENABLE_BARE (Unused). Don't AC_SUBST RTEMS_BSP. * aclocal/enable-bare.m4: Remove (Unused).
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-7/+5
| | | | | * aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4. Remove gnu-make endif HACK (Unused).
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-23/+23
| | | | * Makefile.am: Reformat, add UNUSED_FILES.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-22/+36
| | | | | * Makefile.am: Include compile.am, again. Cleanup.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-37/+41
| | | | | * Makefile.am: Include compile.am, again. Reformat/Cleanup.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-32/+60
| | | | | | | * Makefile.am: Include compile.am, again. Put man-pages into EXTRA_DIST to work around automake not distributing conditionally installed *_MANS. Distribute include/rpcsvc.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-5/+7
| | | | | * Makefile.am: Include compile.am, again. Eliminate DOC_FILES.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-13/+17
| | | | | * Makefile.am: Include compile.am, again. Eliminate C_FILES. Reformat.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1110-6/+25
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-34/+41
| | | | | | | * wrapup/Makefile.am: Include compile.am. Use TMP_LIBS instead of LIBS to avoid potential conflicts with auto*tools' LIBS. Reflect new locations of libscorecpu*.a
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-30/+22
| | | | * Makefile.am: Include compile.am again. Misc fixes.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1126-21/+73
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-115-176/+11
| | | | | | | * Makefile.am: Remove AUTOMAKE_FILES. * automake/compile.am: Replace contents with contents of automake/amcompile.am. * automake/amcompile.am, automake/lib.am: Remove.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-18/+4
| | | | * macros/rtems/score/README: Remove (Redundant with macros/README).
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1126-156/+173
| | | | * Makefile.am: Convert to using automake compilation rules.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1112-22/+24
| | | | | | | | | | * configure.ac, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4, aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING (deprecated in autoconf-2.59) * automake/local.am: Remove clean-local, depend-gcc.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-41/+24
| | | | * Makefile.am: Remove *C_FILES.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-2/+6
| | | | * wrapup/Makefile.am: Cosmetics.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-0922-39/+138
| | | | | * Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-095-11/+23
| | | | | | | | | * aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING). * aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING). * automake/amcompile.am: Remove $(ARCH). * wrapup/Makefile.am: Add $(ARCH). Remove compile.am, lib.am. Include amcompile.am.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-25/+30
| | | | | * wrapup/Makefile.am: Use ../*/*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-098-173/+177
| | | | | * Makefile.am: Build lib*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-9/+12
| | | | | * Makefile.am: Build libposix$(LIB_VARIANT).a instead of $(ARCH)/libposix.a.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-7/+12
| | | | | * Makefile.am: Build libitron$(LIB_VARIANT).a instead of $(ARCH)/libitron.a.
| | | | | * Makefile.am: Build libscore$(LIB_VARIANT).a instead of $(ARCH)/libscore.a.
| | | | | * Makefile.am: Build librtems$(LIB_VARIANT).a instead of $(ARCH)/librtems.a.
| | | | | * Makefile.am: Build libcsupport$(LIB_VARIANT).a instead of $(ARCH)/libcsupport.a.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-096-34/+40
| | | | | | * include/rtems/blkdev.h, include/rtems/ide_part_table.h, src/bdbuf.c, src/ide_part_table.c, src/ramdisk.c: Switch to using c99 fixed size types instead of RTEMS-types.
| | | | | * Makefile.am: Build libblock$(LIB_VARIANT).a instead of $(ARCH)/libblock.a.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-2/+8
| | | | | | * wrapup/Makefile.am: Reflect changes to libblock/Makefile.am. Reflect changes to libcsupport/Makefile.am.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-075-8/+9
| | | | | * qsm.h, sim.h: Remove efi68k and efi332 references as they are no longer in the tree.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-1/+5
| | | | | * aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port more completely covers the MIPS family.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-0/+6
| | | | | * rtems/rtems_bsdnet_internal.h: Include rtems/cdefs.h so things compile.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-1/+4
| | | | * rtems/score/mips.h: Removed junk revision line.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-0718-3782/+16
| | | | | | | | | | | | | | | * cpu/Makefile.am: mips64orion port removed as mips port more completely covers the MIPS family. * cpu/mips64orion/.cvsignore, cpu/mips64orion/ChangeLog, cpu/mips64orion/Makefile.am, cpu/mips64orion/asm.h, cpu/mips64orion/configure.ac, cpu/mips64orion/cpu.c, cpu/mips64orion/cpu_asm.S, cpu/mips64orion/cpu_asm.h, cpu/mips64orion/idtcpu.h, cpu/mips64orion/idtmon.h, cpu/mips64orion/iregdef.h, cpu/mips64orion/rtems/.cvsignore, cpu/mips64orion/rtems/score/.cvsignore, cpu/mips64orion/rtems/score/cpu.h, cpu/mips64orion/rtems/score/mips64orion.h, cpu/mips64orion/rtems/score/types.h: Removed.
* 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-072-19/+23
| | | | * wrapup/Makefile.am: Reflect changes to library Makefile.ams.
