* itron/src/trcv_mbf.c, posix/src/semopen.c,
rtems/src/taskvariableadd.c, score/macros/rtems/score/heap.inl: Fix
warnings.
* cpu.c, cpu_asm.S: Fixed ARM Data Abort handling.
which included commits to RCS files with non-trunk default branches.
Patch from Steven Johnson <sjohnson@sakuraindustries.com>
* aclocal/rtems-ampolish.m4: New.
* configure.ac: Use RTEMS_AMPOLISH3.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
PR 949/networking
* libnetworking/sys/socket.h: GNU/Linux is wrong in making
MSG_DONTWAIT public. It is strictly BSD and not SUSV. See
http://www.opengroup.org/onlinepubs/009695399/basedefs/sys/socket.h.html for clarification.
PR 949/networking
PR 949/networking
* libnetworking/sys/socket.h: Make MSG_DONTWAIT public as in GNU/Linux.
* posix/inline/rtems/posix/mutex.inl,
posix/inline/rtems/posix/timer.inl,
posix/macros/rtems/posix/cond.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/timer.inl: Fix warnings.
score/macros/rtems/score/threadmp.inl: Fix compile error.
Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru>
* score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/inline/rtems/score/threadmp.inl,
score/macros/rtems/score/threadmp.inl, score/src/threadmp.c,
score/src/threadqenqueue.c: Victor spotted the problem that
_MPCI_Receive_server_tcb and _Thread_MP_Receive were duplicate
variables and needed to be set to the same value. I took that
idea and just removed _Thread_MP_Receive. All uses are now
_MPCI_Receive_server_tcb.
* cpu.c (_CPU_Initialize): Add fpu initialization.
* rtems/score/cpu.h: Setup CPU_*_ENDIAN from GCC's__MIPS{EL|EB}__.
(Partial merger of submission by Bruce Robinson <brucer@pmccorp.com>).
PR 761/rtems
* score/src/threadhandler.c: Add volatile cast so test is weak function
is present will do something. Otherwise, it can be assume by gcc to
always be a true condition.
* itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/task.inl: Fix warnings.
* posix/macros/rtems/posix/cond.inl: Fix typo.
* score/macros/rtems/score/heap.inl: Fix missed type change.
PR 830/filesystem
* libcsupport/src/termios.c: termios ioctl(FIONREAD) reported wrong
number of characters. So add chars in low-level/raw buffer to total
count.
PR 850/rtems
* score/src/watchdogtickle.c: A Watchdog (used to timeout an event)
with a delay of 1 sometimes does not seem to timeout. The problem
occurs, because for whatever reason when the watchdog tickle function
executes, the watchdog->delta_interval is 0. it is then decremented
before being tested, becomes huge and so doesnt time out. It is
thought there is a race condition where the watchdog->delta_interval
is calculated by reference to a head (also with a delay of 1). But
before it can be added after the head, the head is removed, so the
new head now has a delay of 0.
PR 852/filesystem
* libblock/src/bdbuf.c: Increase performance of MSDOS file accesses by
using a simple read-ahead and write-combining scheme. Improvement is
dramatic.
PR 886/filesystem
* libcsupport/src/libio.c: fcntl(fd,F_GETFL) fails to set O_NONBLOCK if
the descriptor is in non-blocking mode.
PR 866/rtems
* score/include/rtems/system.h, score/include/rtems/score/isr.h,
score/inline/rtems/score/thread.inl,
score/macros/rtems/score/thread.inl: Added memory barriers to enter
and exit of dispatching and interrupt critical sections so GCC will
not optimize and reorder code out of a critical section.
operations. The "memory" barrier will move the the generic interrupt
enable/disable/flash macros.
PR 890/networking
* httpd/webs.c: The webservers enters an infinite loop when a POST
request with less data than indicated in the Content-Length header is
received. It also consumes additional heap memory and a file
descriptor for each invalid POST.
* rtems/score/cpu.h: Increase default stack size on i386 from 1K to 4K.
Most i386 targets are not memory strapped so making this a bit large
is not a burden. It lets more tests run. ticker and psxtimer will not
even run with 1K of stack.
* posix/inline/rtems/posix/cond.inl, posix/macros/rtems/posix/cond.inl,
posix/src/conddestroy.c: Remove warnings.
* rtems/src/tasks.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c: Remove
warnings.
* posix/include/intr.h, posix/include/rtems/posix/intr.h
posix/inline/rtems/posix/intr.inl.
posix/macros/rtems/posix/intr.inl, posix/src/intr.c:
Remove (Unused, dead).
* posix/Makefile.am: Reflect changes above. Rework.
* posix/Makefile.am: Build devctl.
* rtems/Makefile.am: Rework.
* score/Makefile.am: Rework.
