* | doxygen: Split up "libmisc" subgroups and removed libmisc | Andreas Dachsberger | 2019-04-04 | 8 | -23/+13 |
| | | | | Update #3706. | ||||
* | doxygen: New API subgroup Tracing | Andreas Dachsberger | 2019-04-04 | 3 | -2/+10 |
* | doxygen: Added RTEMS Test Framework to API | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Added inttypes.h to Print Support | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Added subclasses to API | Andreas Dachsberger | 2019-04-04 | 4 | -0/+8 |
| | | | | | | | Update #3706. RTEMS Application Loader, RTEMS Runtime Link Editor, Status Checks and Test Support | ||||
* | doxygen: Zero and Null Device Drivers now in Device Drivers | Andreas Dachsberger | 2019-04-04 | 2 | -2/+2 |
* | doxygen: Print Support now in API->IO | Andreas Dachsberger | 2019-04-04 | 3 | -2/+18 |
* | doxygen: Mouse now in Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: Time Test 27 now in Device Drivers | Andreas Dachsberger | 2019-04-04 | 2 | -2/+10 |
* | doxygen: Benchmark Timer Driver Interface now in Device Drivers | Andreas Dachsberger | 2019-04-04 | 2 | -0/+10 |
* | doxygen: Put Real-Timer Clock Driver Interface into group Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Put Print Support in IO | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Real Time Clock Time of Day API Definition in BSP->Shared | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: Put SPI Driver into group Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Put C Library Support and POSIX in Internal | Andreas Dachsberger | 2019-04-04 | 2 | -0/+4 |
* | doxygen: Added some subgroups to API and IO | Andreas Dachsberger | 2019-04-04 | 3 | -6/+12 |
| | | | | | | I2C library, Media Manager and Profiling Support Update #3706. | ||||
* | doxygen: Added I2C Driver to Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Added Version to API->Classic | Andreas Dachsberger | 2019-04-04 | 4 | -3/+7 |
* | doxygen: Added Frame Buffer Device Driver Interface to Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: Added some subgroups to IO Library | Andreas Dachsberger | 2019-04-04 | 3 | -0/+6 |
| | | | | | | Update #3706. Types and Mount, IO Internal, Kernel Print Support | ||||
* | doxygen: Removed XXX group | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
| | | | | | | Update #3706. Content was added to Classic Barrier Implementation | ||||
* | doxygen: Added Management to Example CPU Architecture | Andreas Dachsberger | 2019-04-04 | 1 | -0/+8 |
* | doxygen: Added libmisc group and libmisc mouse group | Andreas Dachsberger | 2019-04-04 | 2 | -3/+19 |
| | | | | | | | | Update #3706. @ingroup for these groups already existed, but no @defgroup Further restructuring necessary | ||||
* | doxygen: Added toplevel group for device drivers | Andreas Dachsberger | 2019-04-04 | 2 | -1/+10 |
* | doxygen: Added further groups to RTEMSAPI | Andreas Dachsberger | 2019-04-04 | 2 | -11/+20 |
| | | | | | | | Update #3706. Associativity Routines, BSD Compatibility Support now part of RTEMSAPI | ||||
* | doxygen: Added Mainpage to RTEMSAPIClassic | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: User Extensions Implementation group now in Internal->Classic | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: Rework some Doxygen comments | Sebastian Huber | 2019-04-04 | 3 | -44/+51 |
| | | | | | | They are intended as examples in the RTEMS Software Engineering manual. Update #3704. | ||||
* | doxygen: score: Added ScoreRWLock to Score group | Andreas Dachsberger | 2019-04-02 | 1 | -5/+9 |
* | doxygen: Added groups to IO library | Andreas Dachsberger | 2019-04-02 | 4 | -3/+19 |
* | doxygen: score: Put ARM Co-Processor 15 group in ARM | Andreas Dachsberger | 2019-04-02 | 1 | -3/+3 |
* | doxygen: Restructured cpukit/include/rtems/rtems | Andreas Dachsberger | 2019-04-02 | 55 | -75/+90 |
* | doxygen: Reviewed cpukit/include/rtems/posix | Andreas Dachsberger | 2019-04-02 | 1 | -2/+2 |
* | doxygen: Reviewed cpukit/include/rtems/rtems | Andreas Dachsberger | 2019-04-02 | 16 | -60/+17 |
* | doxygen: Reviewed cpukit/include/rtems/score | Andreas Dachsberger | 2019-04-02 | 6 | -35/+25 |
* | doxygen: score: Add x86-64 CPU architecture group | Andreas Dachsberger | 2019-04-02 | 2 | -0/+24 |
* | doxygen: score: Add V850 CPU architecture group | Andreas Dachsberger | 2019-04-02 | 3 | -18/+54 |
* | doxygen: score: Add SPARC64 CPU architecture group | Andreas Dachsberger | 2019-04-02 | 2 | -0/+22 |
* | doxygen: score: Add SPARC CPU architecture group | Andreas Dachsberger | 2019-04-02 | 3 | -2/+26 |
* | doxygen: score: Add SuperH CPU architecture group | Andreas Dachsberger | 2019-04-02 | 2 | -0/+20 |
* | doxygen: score: Add RISC-V CPU architecture group | Andreas Dachsberger | 2019-04-02 | 4 | -1/+26 |
* | doxygen: score: Add powerpc CPU architecture group | Andreas Dachsberger | 2019-04-02 | 5 | -2/+32 |
* | doxygen: score: Add or1k CPU architecture group | Andreas Dachsberger | 2019-04-02 | 4 | -1/+27 |
* | doxygen: score: Add nios2 CPU architecture group | Andreas Dachsberger | 2019-04-01 | 3 | -0/+26 |
* | doxygen: score: Add Moxie CPU architecture group | Andreas Dachsberger | 2019-04-01 | 3 | -0/+26 |
* | doxygen: score: Add m68k CPU architecture group | Andreas Dachsberger | 2019-04-01 | 9 | -10/+47 |
* | doxygen: score: Change no_cpu architecture group | Andreas Dachsberger | 2019-04-01 | 2 | -36/+49 |
| | | | | | | Groups CPUContext and CPUInterrupt are now defined with a unique name for this architecture group. Update #3706. | ||||
* | doxygen: score: Add lm32 CPU architecture group | Andreas Dachsberger | 2019-04-01 | 3 | -14/+53 |
* | doxygen: score: Add i386 CPU architecture group | Andreas Dachsberger | 2019-04-01 | 8 | -2/+57 |
* | doxygen: score: Add Epiphany CPU architecture group | Andreas Dachsberger | 2019-04-01 | 4 | -2/+20 |
| | | | | Update #3706. |
