Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
By convention, thread priorities must be integers in RTEMS. Smaller
values represent more important threads.
Use same structure as POSIX API for thread priority conversion to/from
SuperCore.
Move POSIX API priority validation into _POSIX_Priority_To_core().
Instead of lowering the priority in case the initial budget is consumed
raise the priority for each new period. Restore the normal priority
once the initial budget is consumed. This makes it later easier to
combine the high priority phase with temporary priority boosts (e.g. via
priority ceiling and inheritance).
Use the thread lock to protect the POSIX thread attributes instead of
the thread state lock. This makes it easier to change the thread
priority and keep the POSIX attributes consistent.
Fixes a false positive use of uninitialized variable warning.
This field was redundant.
This field was unused.
Make _POSIX_Mutex_Default_attributes constant and independent of the
scheduler instance. Use INT_MAX to indicate the default ceiling
priority.
Accept all priority values in pthread_mutexattr_setprioceiling(). This
is in line with POSIX and FreeBSD. The priority is validated in
pthread_mutex_init(). Validate the priority only for priority ceiling
mutexes.
This gets rid of the pull in of <stdarg.h> via <rtems.h> via
<rtems/rtems/ratemon.h> via <rtems/print.h>.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
Rename RTEMS_PRINTF_ATTRIBUTE() into RTEMS_PRINTFLIKE() (similar to
<sys/cdefs.h> __printflike()) and move it to <rtems/score/basedefs.h>.
Rework CPU counter support to enable use of the GR740 up-counter via
%asr22 and %asr23.
updates #2608.
Destroy the thread queue in case of a priority ceiling violation,
otherwise the SMP profiling data gets corrupted.
Update #2738.
Remove double declarations, useless comments and unused functions.
Enable for all configurations since it pulls in no additional
dependencies. Return value of the scheduler instance of the executing
thread.
dependencies.
Use priority maximum of scheduler instance. This avoids a potential
memory corruption on SMP configurations.
Close #2734.
Close #2735.
Return the unmodified thread priority value according to POSIX.
Close #2736.
Bug introduced by b04b76c6a0c87ffc9670d356e793108411ce355a.
Do not hide network file systems if RTEMS_NETWORKING is not defined,
since they may be provided by the LibBSD.
In case the CPU architecture provides no specialized
_CPU_Bitfield_Find_first_bit() macro, then use the __builtin_clz()
builtin in case __GNUC__ is defined.
Turn _Bitfield_Find_first_bit() macro into an inline function.
The priority bit map can deal with a maximum of 256 priority values
ranging from 0 to 255. Consistently use an unsigned int for
computation, due to the usual integer promotion rules.
Make Priority_bit_map_Word definition architecture-independent and
define it to uint16_t. This was already the case for all architectures
except PowerPC. Adjust the PowerPC bitmap support accordingly.
Rename __log2table into _Bitfield_Leading_zeros since it acually returns
the count of leading zeros of an 8-bit integer. The value for zero is a
bit odd. Provide it unconditionally.
Remove superfluous includes. Use one attribute compare for each
semaphore variant. Text size drops by 10% on PowerPC due to this.
