Update #4267.
Update #4267.
Update #4267.
Update #4267.
Update #4269.
Update #4269.
Use the right system initialization step for the stack allocator
initialization. Do the stack allocator initialization before the
workspace initialization so that _Memory_Allocate() can be used to get
memory for the allocator.
This type is not only used by Task Manager directives. This is a
preparation to move the rtems_scheduler_*() directives from
<rtems/rtems/tasks.h> to a new <rtems/rtems/scheduler.h>.
Call _Thread_queue_Flush_critical() directly.
Use the number of threads which must arrive at the barrier to trip the
automatic release also to indicate if the barrier is a manual release
barrier.
Use the type safe _Objects_Open_u32() instead. Return the object
identifier to enforce a common usage pattern.
Do the preemption and ASR processing changes in one rush and acquire the
thread state lock only once.
Do the mode changes necessary for the ASR processing directly under
protection of the thread state lock to avoid the recursive calls to
thread dispatching done in rtems_task_mode().
Close #4244.
Update #4244.
Ensure that no invalid modes are set during ASR processing.
Update #4244.
This call just obfuscated the call to _ISR_Set_level().
Update #4244.
The api pointer is never NULL.
Update #4244.
Remove superfluous ASR_Information::signals_posted. Move code out of
trivial inline functions.
Update #4244.
Move _Signal_Action_handler() and signal MP initialization to
rtems_signal_send(). The goal is to make _Signal_Action_handler() a
static function in a follow up patch.
Update #4244.
Update #4244.
Update #4244.
Update #4244.
Update #4244.
Require that the corresponding lock is acquired before the action
handler returns. This helps to avoid recursion in the signal
processing.
Update #4244.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
CID 1467420: Dereference before null check in rtems_shell_line_editor().
Closes #4254
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Unify the wording across similar directives of other managers.
Update #3993.
Update #3993.
Update #3993.
Unify the wording across similar directives of other managers. Add
"CONSTRAINTS" section.
Update #3993.
Update #3993.
CID 1468681: Dereference before null check in rtems_debugger_thread_continue().
CID 1468690: Dereference before null check in rtems_debugger_thread_system_resume().
CID 1468694: Dereference before null check in rtems_debugger_thread_find_index().
Closes #4241.
CID 1468682: swbreaks is assigned a value dereferenced from target before
it has been verified that target is not null.
Closes #4240.
CID 1437625: Unchecked return value from call to rtems_task_create().
CID 1472765: Unchecked return value from call to rtems_task_start().
Closes #4237.
These macros are to be used to check the status from calls that are flagged
by Coverity as 'Unchecked return value'.
Fix file assert.h
- Move the heap sbrk code into a separate routnine.
- Update heap and workspace greedy allocators to use the common
sbrk greedy support.
Closes #3982
Change RTEMS_STRING() and RTEMS_XSTRING() to accept a variable number of
arguments which is stringified. This can be used for example to create
register lists for inline assembler statements.
- Call the heap extend handler until all memory has been
requested.
Closes #3982
- Add the bool flag no_regular_file_mknod to the mount table so a file
system can indicate creating regular files is not done by
use the mknod handler. The file system will handle creating a
file node in the open handler.
- Note, the mount option is an enum which means there is only one
exclusive option supported. As a result no encapsulation is
provided and file systems need to set no_regular_file_mknod directly.
Closes #4222
This fixes a missing decrement of the number of waiting threads during a
barrier wait timeout.
Close #4230.
Update #4230.
Update #4230.
