* Makefile.am: Add fileio to list of interactive tests.
* src/sync.c: New file.
PR 455/bsps
* rtems/score/cpu.h: Added missing CPU_swap_u16().
PR 92/rtems
* Makefile.am, src/alarm.c, src/psignal.c: Added ualarm() and usleep().
* src/ualarm.c, src/usleep.c: New files.
* fsmount/Makefile.am: Fix path to automake-includes.
* fsmount/.cvsignore: New file.
* configure.ac: Removed duplicate entry.
* configure.ac: Add libmisc/fsmount/Makefile.
PR 369/filesystem
* Makefile.am, shell/cmds.c, wrapup/Makefile.am: sample application to
show the use of the DOSFS functions
* fsmount/Makefile.am, fsmount/README, fsmount/fsmount.c,
fsmount/fsmount.h: New files.
PR 435/networking
* rtems/rtems_showifstat.c: rtems_showifstat misses printing
the netmask
PR 443/filesystem
* src/imfs/deviceio.c: deviceio.c mishandles return codes
PR 436/rtems_misc
* monitor/mon-monitor.c: monitor registered commands list manipulation bugs
PR 440/filesystem
* src/dosfs/fat_fat_operations.c: Improve write data speed for DOSFS FAT12/FAT16 systems
PR 439/filesystem
PR 442/filesystem
* src/open.c: file never closed if ftruncate() fails in open()
PR 439/filesystem
*src/dosfs/fat_file.c: flush temporary buffer when closing files
PR 439/filesystem
PR 441/filesystem
*src/dosfs/msdos.h: add rename support to DOSFS
*src/dosfs/msdos_create.c: add rename support to DOSFS
*src/dosfs/msdos_file.c: add rename support to DOSFS
*src/dosfs/msdos_init.c: add rename support to DOSFS
*src/dosfs/msdos_mknod.c: add rename support to DOSFS
PR 441/filesystem
* configure.ac: Remove (Merged into ../configure.ac).
* .cvsignore, Makefile.am, pppd/Makefile.am,
rtems_servers/Makefile.am, rtems_telnetd/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
PR 434/filesystem
* src/imfs/imfs_init.c: Modified to return error code
* src/imfs/miniimfs_init.c: Modified to return error code
* src/imfs/imfs_initsup.c: Modified to set error upon memory failure.
PR 434/filesystem
PR 288/rtems
* rtems/new-exceptions/cpu.h: _ISR_Nest_level is now properly
maintained and does not reside in SPRG0.
PR 430/rtems
* include/rtems/score/watchdog.h: _Watchdog_Ticks_since_boot should
be a VOLATILE variable.
* src/watchdoginsert.c: 'restart' algorithm needs to enforce
reloading the list head in case a TICK interrupt during ISR_Flash()
modified the list. This is achieved by a proper VOLATILE cast.
Also _Watchdog_Sync_count++ should be protected by _ISR_Disable
(prevent corruption in case ISR calls watchdoginsert)
* src/watchdogadjust.c: ISR protection added.
* src/watchdogtickle.c: ISR protection added.
NOTE: PowerPC BSPs using the new exception processing MUST BE UPDATED
to maintain _ISR_Nest_level. See also PR288 which provides fixes
for the affected BSPs distributed with RTEMS.
* ChangeLog: Correct format.
* wrapup/Makefile.am: Remove bogus $(MULTISUBDIR).
opertations will wait for ever.
will wait for ever.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
* cpu/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* configure.ac: Merge-in librpc/configure.ac.
* Makefile.am: Add librpc to SUBDIRS.
Remove @subdirs@.
PR 418/ada
* rtems.adb: Add missing all keyword to derefence pointer.
PR 419/rtems
* src/termios.c: Removed warning.
* configure.ac: Merge-in libcsupport/configure.ac.
* Makefile.am: Add libcsupport to SUBDIRS.
* Makefile.am: DOC_FILES = src/TODO src/CASES,
* src/config.h: New.
* configure.ac: Merge-in posix/configure.ac.
Merge-in itron/configure.ac.
Misc. cosmetical changes.
* Makefile.am: Add posix, itron to SUBDIRS.
* Makefile.am:
* configure.ac: Merge-in libnetworking/configure.ac.
Remove "rtems-" from RTEMS_VERSION.
Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]).
* Makefile.am: Add libmisc to SUBDIRS.
* Makefile.am, libc/Makefile.am, lib/Makefile.am, wrapup/Makefile.am:
* kern/kern_mib.c: Use RTEMS_VERSION to setup osrelease.
* configure.ac: Merge-in libmisc/configure.ac.
* Makefile.am:
* capture/config.h: New.
* capture/Makefile.am: Add config.h.
* cpuuse/config.h: New.
* cpuuse/Makefile.am: Add config.h.
* devnull/config.h: New.
* devnull/Makefile.am: Add config.h.
* dummy/config.h: New.
* dummy/Makefile.am: Add config.h.
* dumpbuf/config.h: New.
* dumpbuf/Makefile.am: Add config.h.
* monitor/config.h: New.
* monitor/Makefile.am: Add config.h.
* mw-fb/config.h: New.
* mw-fb/Makefile.am: Add config.h.
* rtmonuse/config.h: New.
* rtmonuse/Makefile.am: Add config.h.
* serdbg/config.h: New.
* serdbg/Makefile.am: Add config.h.
* shell/config.h: New.
* shell/Makefile.am: Add config.h.
* stackchk/config.h: New.
* stackchk/Makefile.am: Add config.h.
* untar/config.h: New.
* untar/Makefile.am: Add config.h.
* configure.ac: Merge-in libfs/configure.ac.
* Makefile.am: Add libfs to SUBDIRS.
* Makefile.am, src/Makefile.am, src/dosfs/Makefile.am,
src/imfs/Makefile.am: Reflect having merged configure.ac into
../configure.ac.
* src/dosfs/config.h: New.
* src/dosfs/Makefile.am: Add config.h.
* src/imfsfs/config.h: New.
* src/imfs/Makefile.am: Add config.h.
Remove COMMON_C_FILES, DOC_FILES (Unused).
* src/dosfs/fat.c: include config-header "config.h".
* src/dosfs/fat_fat_operations.c: Ditto.
* src/dosfs/fat_file.c: Ditto.
* src/dosfs/msdos_conv.c: Ditto.
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
* Makefile.am: Reflect having merged configure.ac into
../configure.ac.
