* aclocal/sysv-ipc.m4: Remove (unused).
* configure.ac: Remove RTEMS_UNIX, RTEMS_UNIXLIB.
* configure.ac: Remove some unix-specific checks.
Remove unix-CPU_CONTEXT size checking.
Remove enable-unixlib.
Remove unix subdir.
* configure.ac: Remove unix subdir.
* aclocal/canonical-target-name.m4, aclocal/check-networking.m4,
aclocal/check-posix.m4, aclocal/enable-posix.m4:
Remove unix/posix.
* score/cpu/Makefile.am: Remove unix subdir.
* libblock/include/rtems/bdbuf.h: Use size_t for swapout_workers.
* libblock/src/bdpart.c: Add __attribute__((unused)) to suppress
warnings.
* libblock/src/bdbuf.c: Fix broken printf formats.
Use size_t for sizes.
control function. The IO control handler takes now the disk device as
first parameter instead of the physical device number.
* cpukit/libblock/include/rtems/blkdev.h, libblock/src/bdbuf.c,
libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/nvdisk.c,
libblock/src/flashdisk.c, libblock/src/ramdisk.c: Update for block
device API change.
Minor portability code-massaging.
* score/include/rtems/score/interr.h: Introduce Internal_errors_t.
* score/src/interr.c, score/include/rtems/score/userext.h,
score/src/userextthreadbegin.c: Reflect having introduced
Internal_errors_t.
* posix/src/alarm.c: If 0 seconds do not insert timer.
* rtems/src/regionextend.c: Eliminate warning. Use default else.
* score/inline/rtems/score/thread.inl, score/src/threaddispatch.c:
Correct conditionals so _Thread_Enable_dispatch() is always inlined
when intended.
* posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/canceleval.c: Make psxcancel run again.
_POSIX_Thread_Exit() can be called on running thread or another
thread when it is cancelled.
* posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c,
posix/src/mutextimedlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c, posix/src/semtimedwait.c: Switch from
switch to if's because only one value needed to be tested. This
shrinks the code and makes it easier to do coverage analysis on.
* score/inline/rtems/score/object.inl: _Objects_Get_local_object() is
only called from places where the index is known to be valid.
_Objects_Set_local_object() already assumed this. Eliminates
unreachable code.
* rtems/src/timerserver.c: Indentation.
* rtems/src/regiondelete.c, rtems/src/regionextend.c,
rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c,
rtems/src/regiongetsegment.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c: Avoid initializing status code. This
generates dead code on some targets. Add default case to eliminate
unitialized variable warning.
* cpukit/sapi/include/rtems/io.h: Documentation.
* cpukit/sapi/src/ioregisterdriver.c: Call from interrupt context is
an error.
* cpukit/sapi/src/iounregisterdriver.c: Disable preemption during
critical section.
* libmisc/shell/main_mknod.c: Fixed build problem with networking
disabled.
* Makefile.am, preinstall.am: Added statvfs.h.
* libcsupport/Makefile.am: Add statvfs.c.
* libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c:
New.
* libcsupport/include/rtems/libio.h: Add a file system handler for
the statvfs call.
* libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c,
libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the
statvfs handler to NULL.
* include/rtems/fs.h: Add a second node access field for the RFS
file system to hold a directory offset while the existing field
holds the inode number. This save a rescan of the directory when
working with directories.
* libblock/include/rtems/bdbuf.h: Added references and user fields
to the buffer descriptor.
* libblock/src/bdbuf.c: Added dynamic buffer support for different
block sizes. Fixed a number of bugs.
* libblock/src/blkdev.c: Release the disk device on an error.
* libblock/src/diskdevs.c: Set the block size to the media block
size during initialisation of the disk device.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk.c: Updated the drivers to handle variable
block sizes.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any
buffers when an error occurs. The FAT buffer layer hangs onto a
single buffer while mounted. This should be fixed.
* sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain,
rtems_chain_is_node_off_chain, and rtems_chain_previous.
* score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain,
and _Chain_Is_node_off_chain.
* libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h:
New shell commands.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and
mknod commands.
* libmisc/shell/hexdump-display.c: Fixed the reopen bug which
showed up as a free with a bad pointer.
* libmisc/shell/main_mount.c: List the user adding file system
when listing the available file systems to mount.
* libmisc/shell/utils-cp.c: Remove the fixed static copy buffer
and use a large dynamic buffer.
* score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c,
score/src/objectallocate.c, score/src/objectfree.c: Remove
warnings.
* sapi/src/ioregisterdriver.c: Reowork so this is a context switch
disable critical section not interrupt disable critical section.
Hopefully eliminated dead code which showed up in coverage runs.
* sapi/include/rtems/io.h, sapi/src/ioregisterdriver.c: Documenation.
rtems_io_lookup_name() is now deprecated. Added
rtems_io_driver_io_error(). rtems_io_register_driver() is now
thread-safe.
* rtems/src/ratemonreportstatistics.c: owner field is always set so
safe to use. Reformat.
* rtems/src/regionresizesegment.c: Always evaluate the blocked queue
if the resize succeeded.
* rtems/src/tasksetnote.c: Spacing.
* posix/include/rtems/posix/psignal.h: Add extern for ualarm timer.
* posix/src/alarm.c, posix/src/ualarm.c: Change from switch to if since
many enumerated values have no action.
* posix/src/psignal.c: Initialize ualarm and alarm timers.
* libmisc/monitor/mon-driver.c: Fix warning if
defined(RTEMS_USE_16_BIT_OBJECT).
* libmisc/monitor/mon-prmisc.c: Fix warning if
* rtems/score/arm.h: Recognize ARMv7A.
* rtems/score/arm.h: Recognize ARMv6J as needed by arm1136 variants.
PR 1445/bsps
* include/rtems/pci.h:
Make pci_[read|write]_config* static inline, again.
* include/rtems/pci.h: Add another missing prototype.
* include/rtems/pci.h: Add missing prototype.
* libcsupport/src/fstat.c, libcsupport/src/fcntl.c,
libcsupport/src/calloc.c, libcsupport/src/isatty_r.c,
libcsupport/src/issetugid.c, libcsupport/src/lseek.c,
libcsupport/src/read.c, libcsupport/src/getpid.c:
Rework autoconf defines.
* libcsupport/src/_rename_r.c: Rework autoconf defines.
Remove unused includes.
