* libfs/src/nfsclient/src/nfs.c: Use
rtems_clock_get_seconds_since_epoch() from public API.
* libfs/src/nfsclient/Makefile.am: Remove RTEMS_RELLDFLAGS.
* aclocal/prog-cc.m4: Add RTEMS_RELLDFLAGS hack.
* libfs/src/nfsclient/src/dirutils.c: #include <limits.h>.
* rtems/include/rtems/rtems/clock.h: #include <sys/time.h>
* librpc/include/rpc/rpcent.h: #include <rpc/types.h>.
* librpc/include/rpc/xdr.h: #include <rtems/bsd/sys/cdefs.h>.
* libfs/src/devfs/devfs.h: Add missing "extern"s.
* libfs/src/imfs/imfs.h: Add missing "extern"s
* libfs/src/pipe/pipe.h: Add missing "extern"s.
Add extern "C" {}.
* score/cpu/arm/cpu.c, score/cpu/avr/cpu.c, score/cpu/bfin/cpu.c,
score/cpu/c4x/cpu.c, score/cpu/h8300/cpu.c, score/cpu/i386/cpu.c,
score/cpu/lm32/cpu.c, score/cpu/m32c/cpu.c, score/cpu/m32r/cpu.c,
score/cpu/mips/cpu.c, score/cpu/nios2/cpu.c, score/cpu/no_cpu/cpu.c,
score/cpu/sh/cpu.c, score/cpu/sparc/cpu.c, score/cpu/unix/cpu.c:
Fix typo.
* score/include/rtems/score/timespec.h: Remove unnecessary includes.
Fix typo.
* posix/include/rtems/posix/time.h, score/src/coretodget.c,
score/src/coretodgetuptime.c: Add required include files which
were formerly included from timespec.h
* libfs/src/pipe/fifo.c: Do not include .inl files directly. Use .h
files with kernel visibility violated until functionality exposed.
* .cvsignore: New file.
* configure.ac: Check for functions in newlib.
* posix/Makefile.am: Unconditionally compile files which now
are in newlib.
* libcsupport/Makefile.am: Unconditionally compile files which now
are in newlib.
* posix/src/execl.c, posix/src/execle.c,
posix/src/execlp.c, posix/src/execv.c,
posix/src/execve.c, posix/src/execvp.c,
posix/src/sleep.c, posix/src/usleep.c:
Compile contents conditionally.
* libcsupport/src/closedir.c, libcsupport/src/getcwd.c,
libcsupport/src/isatty.c, libcsupport/src/opendir.c,
libcsupport/src/readdir.c, libcsupport/src/readdir_r.c,
libcsupport/src/rewinddir.c, libcsupport/src/seekdir.c,
libcsupport/src/telldir.c, libcsupport/src/ttyname.c:
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: Add
Lattice Mico32 support.
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, preinstall.am, rtems/asm.h,
rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/lm32.h,
rtems/score/types.h: New files.
PR 1348/cpukit
* rtems/src/ratemonperiod.c: Properly handle period statistics after
cpu usage information is reset while a period is running.
PR 1347/cpukit
* rtems/include/rtems/rtems/timer.h, rtems/src/rtemstimer.c,
rtems/src/timerreset.c, rtems/src/timerserver.c,
score/Makefile.am, score/include/rtems/score/watchdog.h: Rework Timer
Server to ensure that the context allows for blocking, allocating
memory, and acquiring semaphores and mutexes.
* score/src/watchdogadjusttochain.c: New file.
PR 1346/cpukit
* rtems/include/rtems/rtems/ratemon.h: Sense of rate monotonic
statistics nanoseconds or ticks granularity conditional is backwards.
* libfs/src/pipe/fifo.c: Actually disable initializing pipes as
requested in confdefs.h.
* sapi/include/confdefs.h: Add disable of pipes by default since they
use resources which are otherwise not accounted for. Eventually the
resources will have to be properly configured.
* libfs/Makefile.am: Add stub for devide filesystem for unix port.
* libfs/src/devfs/devfs_unixstub.c: New file.
* rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/support.h,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/workspace.c: Revert ssize_t patch.
* cpu.c: Links hello again.
* score/Makefile.am, score/include/rtems/score/watchdog.h: Add
_Watchdog_Report and _Watchdog_Report_chain as debug assist routines.
They are NOT to be used in directives.
* score/src/watchdogreport.c, score/src/watchdogreportchain.c:
New files.
* cpu.c, cpu_asm.c: Add debug printk() calls until the BSP/port can
initialize and shutdown completely cleanly. When this works,
implement context switch. Testing on avrtest and simulavr.
* score/src/watchdogadjust.c, score/src/watchdogtickle.c: Spacing.
PR 1341/cpukit
* sapi/include/confdefs.h: The following macros were missing
the _Configure_From_workspace() wrapper on their size estimate:
+ CONFIGURE_INTERRUPT_STACK_MEMORY
+ CONFIGURE_MEMORY_PER_TASK_FOR_CLASSIC_API
+ CONFIGURE_INTERRUPT_VECTOR_TABLE
+ CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS
In addition, there was a duplicate definition of
CONFIGURE_MEMORY_PER_TASK_FOR_CLASSIC_API.
* configure.ac: Add AC_CHECK_FUNC's to check functions migrating
into newlib.
* posix/include/rtems/posix/psignal.h: Fix typo in converting method
from macro to static inline.
* posix/Makefile.am, posix/include/rtems/posix/psignal.h: Add stubs for
gettimer() and setitimer().
* posix/src/getitimer.c, posix/src/setitimer.c: New files.
* libcsupport/Makefile.am, posix/Makefile.am: Comment out including
files which contain routines which are now provided by the newlib
posix subdirectory. Document a few which come from the unix directory.
PR 1340/cpukit
* sapi/inline/rtems/chain.inl: Add rtems_chain_initialize to public
chain API.
* score/include/rtems/score/heap.h,
score/include/rtems/score/protectedheap.h,
score/include/rtems/score/wkspace.h, score/src/heap.c,
score/src/heapallocate.c, score/src/heapallocatealigned.c,
score/src/heapextend.c, score/src/heapresizeblock.c,
score/src/heapsizeofuserarea.c, score/src/pheapgetblocksize.c,
score/src/wkspace.c: Revert use of ssize_t. This type is not
guaranteed to be able to represent a positive number greater than the
size of a single allocatable object. We needed a type that is able to
represent the size of a pool of multiple allocatable objects or
potentially nearly all memory.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Do not
think about running init/fini on AVR. We do not know what mechanism
it uses but this is not it.
PR 1306/cpukit
* posix/inline/rtems/posix/priority.inl: Eliminate hard coded numbers
in favor of existing macros.
* posix/Makefile.am: Add dummy vfork() implementation.
* posix/src/vfork.c: New file.
PR 1336/cpukit
* sapi/inline/rtems/chain.inl: Add rtems_chain_prepend_unprotected and
rtems_chain_append_unprotected.
* libcsupport/Makefile.am: Add getrusage().
* libcsupport/src/getrusage.c: New file.
* score/src/timespecaddto.c: Fix typo.
* libcsupport/src/ttyname.c: Change third parameter of ttyname to be
size_t instead of int.
