* configure.ac: Add score/cpu/no_cpu/Makefile.
* Makefile.am, configure.ac: Add httpd.
* httpd/asp.c, httpd/balloc.c, httpd/cgi.c, httpd/default.c,
httpd/ej.h, httpd/ejIntrn.h, httpd/ejlex.c, httpd/ejparse.c,
httpd/emfdb.c, httpd/emfdb.h, httpd/form.c, httpd/handler.c,
httpd/h.c, httpd/license.txt, httpd/Makefile.am, httpd/md5c.c,
httpd/md5.h, httpd/mime.c, httpd/misc.c, httpd/NOTES, httpd/ringq.c,
httpd/rom.c, httpd/rtems_webserver.h, httpd/security.c,
httpd/sock.c, httpd/socket.c, httpd/sockGen.c, httpd/sym.c,
httpd/uemf.c, httpd/uemf.h, httpd/um.c, httpd/um.h, httpd/umui.c,
httpd/url.c, httpd/value.c, httpd/wbase64.c, httpd/webcomp.c,
httpd/webmain.c, httpd/webpage.c, httpd/webrom.c, httpd/webs.c,
httpd/websda.c, httpd/websda.h, httpd/webs.h, httpd/websSSL.c,
httpd/websSSL.h, httpd/websuemf.c, httpd/wsIntrn.h: New (Moved from
c/src/libnetworking/rtems_webserver).
* httpd/Makefile.am: Install libhttpd.a.
* libcsupport/include/rtems/_inttypes.h: Undefine __PRIN defines.
* libcsupport/include/rtems/_stdint.h: Apply GNUC-limits to GCC >= 3.3, only.
Add _rtems_*_t_defined defines. Add extern "C".
* libcsupport/rtems/_stdint.h: New.
* libcsupport/rtems/_inttypes.h: New.
* libcsupport/Makefile.am: Reflect changes above.
* libcsupport/include/sys/ioctl.h: Cosmetical update from FreeBSD.
Remove sys/compat_ioctl.h section (Meaningless with RTEMS).
* libfs/src/dosfs/msdos_conv.c:
Replace BSD fixed-size types with POSIX fixed-size types.
Replace SECONDSTO1980 with DAYSTO1980.
Make macros 16bit clean.
* libcsupport/include/sys/ioccom.h: Cosmetical update from FreeBSD.
* libnetworking/Makefile.am: Reflect changes below.
* libnetworking/net/slcompress.h: New (from FreeBSD).
* libnetworking/net/slcompress.c: New (from FreeBSD).
* libnetworking/kern/kern_sysctl.c: Remove uintptr_t.
Cosmetics.
* libnetworking/opt_compat.h: New.
* libcsupport/include/stdint.h: Add intptr_t uintptr_t.
* libnetworking/opt_atalk.h, libnetworking/opt_bdg.h,
libnetworking/opt_inet.h, libnetworking/opt_inet6.h,
libnetworking/opt_ipx.h, libnetworking/opt_mac.h,
libnetworking/opt_netgraph.h: New (Stubs).
* libnetworking/net/if_loop.c: Cosmetical update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Update from FreeBSD.
* libnetworking/net/if.h: Update from FreeBSD.
* libnetworking/net/ethernet.h: Remove BYTE_PACK.
* libnetworking/net/ethernet.h: Update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Cosmetical updates from FreeBSD.
Add ether_sprintf.
* libnetworking/net/if.h; Cosmetical updates from FreeBSD.
Remove if_poll* (Not implemented in RTEMS, abandoned by FreeBSD).
* libnetworking/rtems_servers/ftpd.c: Use POSIX fixed size types.
* libmisc/monitor/mon-prmisc.c, libmisc/monitor/monitor.h:
rtems_monitor_dump_char(char ch).
* automake/compile.am: Remove RTEMS_CFLAGS_*_V.
which included commits to RCS files with non-trunk default branches.
* libnetworking/rtems_webserver/uemf.h: Use CHAR_BIT for
BITSPERBYTE.
* libnetworking/pppd/rtemspppd.c: rtems_task_priority priority.
* libnetworking/rtems_telnetd/telnetd.c: Eliminate rtems_unsigned32.
PR 692/rtems
* rtems/src/regiongetsegment.c, rtems/src/regionreturnsegment.c: The
Region Manager did not follow the proper protocol when blocking and
unblocking tasks waiting on buffers. This was a bug introduced with
the transition to an Allocation Mutex.
* aclocal/rtems-cpu-subdirs.m4, libchip/shmdr/shm_driver.h,
libnetworking/pppd/utils.c: i960 obsoleted and all references
removed.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* rtems/score/cpu.h: i960 obsoleted and all references removed.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: i960
* score/cpu/i960/.cvsignore, score/cpu/i960/ChangeLog,
score/cpu/i960/Makefile.am, score/cpu/i960/asm.h,
score/cpu/i960/cpu.c, score/cpu/i960/cpu_asm.S,
score/cpu/i960/rtems/score/cpu.h, score/cpu/i960/rtems/score/i960.h,
score/cpu/i960/rtems/score/types.h: Removed.
PR 294/rtems
* posix/src/pthread.c: POSIX thread exit handler now confirms that it
created the executing thread before implicitly exitting it.
* libmisc/stackchk/check.c: Spacing.
* libnetworking/Makefile.am: Don't include subdirs.am.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
* librpc/src/xdr/xdr_float.c: Add __AVR__.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
PR 677/misc
* libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.h,
libmisc/rtmonuse/rtmonuse.h, libmisc/serdbg/serdbg.h,
libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/termios_printk.h,
libmisc/serdbg/termios_printk_cnf.h, libmisc/untar/untar.h: Add
extern C wrappers.
PR 676/networking
* libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead
of DNS servers.
PR 671/bsps
* rtems/score/cpu.h: Fixed bug in _CPU_ISR_Set_level, where input param
was always ignored.
PR 673/make_build
* aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes.
