* libcsupport/include/rtc.h: New RTC driver interface.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added RTC command.
* libmisc/shell/main_rtc.c: New file.
PR 1418/cpukit
* rtems/score/cpu.h: corrected _CPU_ISR_Flash implementation, added
core synchronization after all cli/sti.
PR 1413/cpukit
* rtems/src/timerserver.c: Fix bug where server based timers which
reinitiated themselves did not get reinserted onto timer chain.
* librpc/src/xdr/xdr_float.c: Change detection logic for h8300.
PR 1412/cpukit
* score/src/coremutex.c: Add missing braces. Broken with strict mutex
code added.
* posix/src/getitimer.c, posix/src/setitimer.c: Add error checks and
clean up so coverage analysis is possible.
* posix/src/sysconf.c: Restructure to improve coverage analysis.
* libcsupport/Makefile.am, libcsupport/src/printk.c: Restructure to
make analysis and coverage easier. Now 100% covered.
* libcsupport/src/vprintk.c: New file.
* Doxygen.in: Fixed project name. Added project number. Enabled auto
brief. Disabled include graphs.
* include/rtems/irq-extension.h, libblock/include/rtems/bdpart.h,
libblock/include/rtems/bdbuf.h, libblock/include/rtems/bdpart.h,
libblock/include/rtems/blkdev.h, libblock/include/rtems/diskdevs.h,
libblock/include/rtems/ramdisk.h, libblock/src/bdbuf.c,
libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/ramdisk.c:
Documentation.
* libblock/src/bdpart.c: Documentation. Fixed NULL pointer access.
initialization, save and restore code.
PR 1411/cpukit
* rtems/src/workspace.c, score/include/rtems/score/protectedheap.h,
score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c: Improve
workspace wrapper methods.
* libmisc/shell/login_prompt.c, libmisc/shell/shell_script.c,
rtems/include/rtems/rtems/timer.h: Fix warnings.
* posix/include/rtems/posix/psignal.h,
rtems/inline/rtems/rtems/support.inl: Remove warnings.
* sapi/include/rtems/config.h: Switch from ssize_t to uintptr_t for
work space size since it is larger than a single allocatable object.
* cpukit/libblock/src/bdpart.c, libmisc/shell/main_msdosfmt.c,
libmisc/shell/main_rm.c, libnetworking/libc/gethostnamadr.c,
score/include/rtems/score/bitfield.h,
score/inline/rtems/score/priority.inl: Remove warnings.
* score/src/objectgetnext.c: Add checks for NULL pointers.
timeouts. Options are now per file system instance.
* libmisc/uuid/gen_uuid.c, libnetworking/lib/syslog.c,
telnetd/telnetd.c: Fixed warnings.
* libcsupport/Makefile.am:
* libcsupport/src/isatty_r.c: New file.
* rtems/include/rtems/rtems/part.h,
rtems/inline/rtems/rtems/region.inl: Fix warnings.
* rtems/score/cpu.h: Lower number of priorities and do not inline as
much.
* score/include/rtems/score/heap.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/tod.inl: Remove warnings.
* rtems/score/cpu.h: Remove warnings.
* score/include/rtems/system.h: Added
RTEMS_COMPILER_DEPRECATED_ATTRIBUTE define.
* cpu_asm.S, irq.c, rtems/score/cpu.h: Add lm32 gdb stub support.
Added const qualifier whenever possible. Added
rtems_fsmount_create_mount_point() prototype.
accept. Return EIO for close() errors. Changed PORT format string.
Fixed connection termination after store errors on passive connections.
Added magic device identifier for stat().
* rtems/score/cpu.h: Lower minimum stack size to 512 and CPU alignment
to 4.
* cpu_asm.c: Add stub for setjmp/longjmp. Remove when in newlib.
* telnetd/telnetd.h: Spacing.
* rtems/include/rtems/rtems/clock.h, rtems/src/clocktodtoseconds.c,
rtems/src/clocktodvalidate.c: Add const to parameter.
* libmisc/shell/shell.c, libmisc/stackchk/check.c: Eliminate warnings.
* posix/src/condtimedwait.c, posix/src/mutextimedlock.c,
posix/src/semopen.c: Silence warnings.
* sapi/include/confdefs.h, libblock/include/rtems/bdbuf.h: Changed
type of rtems_bdbuf_pool_configuration_size to size_t.
* libblock/include/rtems/bdbuf.h, libblock/include/rtems/blkdev.h,
libblock/include/rtems/diskdevs.h, libblock/src/bdbuf.c,
libblock/src/blkdev.c, libblock/src/diskdevs.c: Buffer pool
allocation is now cache aligned. The cache functions are
currently not available on all platforms so the cache line size is
fixed to 32 bytes for now. Changed various integer types which
refer to block sizes, numbers and indexes. Fixed logical block
indexes in buffer get and read function. It is now possible to
delete logical disks. Modified documentation
* libcsupport/include/rtems/libio.h: Add rtems_off64_t for
internal use. Update the internal off_t to the 64bit offset.
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/memfile.c, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/deviceio.c: Change off_t to
rtems_off64_t.
* libmisc/shell/main_msdosfmt.c: Add an info level so the format
code can tell the user what is happening. Add more options to
control the format configuration.
* libfs/src/dosfs/msdos_format.c: Add a print function to display
the format progress and print statements. Select a better default
cluster size depending on the size of the disk. This lowers the
size of the FAT on large disks. Read and maintain the MRB
partition information.
* libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_conv.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_file.c,
libfs/src/dosfs/msdos_handlers_dir.c,
libfs/src/dosfs/msdos_handlers_file.c,
libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Add
long file name support. Change off_t to rtems_off64_t.
* libblock/include/rtems/ide_part_table.h: Add MRB partition table
size.
rtems_off64_t.
* libblock/src/bdbuf.c: Flush the transfer sync event before
blocking in a read.
* libnetworking/nfs/bootp_subr.c: Fixed PR1384. The route set in
the initialise pass is not deleted so an exists error is
returned. Ignore the error. Print the server address as an IP
address not hex digits.
* libnetworking/rtems/rtems_dhcp.c: Fixed
PR1338. Close the socket, handle the returned event flags.
* sapi/include/confdefs.h: Add a prototype for Init with C linkage
and define Init task command line arguments if confdefs.h provides
an Init entry point.
