path: root/cpukit (unfollow)
2001-10-262001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2-1/+8
* src/imfs/imfs_load_tar.c: Minor modification so this will compile with gcc-2.95.3 with the arguments "-m5200 -O4".
2001-10-262001-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-16/+5
* libc/libio.c: Cleanup of initialization per suggestion from Eric Norum.
2001-10-252001-10-25 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill1-88/+116
* libc/unmount.c: Primarily restructuring and clean up to address procedures which did not do what their name implied. Also addressed problem situation where unmount fails and the filesystem was inconsistent. The mounted filesystem could have been left hanging.
2001-10-252001-10-25 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill3-8/+20
* libc/libio.c: Initialize more fields to NULL/0 during initialiation. * include/rtems/libio_.h: Fix freenode macro so it works for sockets which do not have the full set of filesystem operations and are initialized via something other than open().
2001-10-232001-10-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+6
* macros/rtems/rtems/asr.nil: Fixed typo.
2001-10-232001-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+6
* macros/Makefile.am: Replace INLINES w/ MACROS (Fix stupid typo in previous patch).
2001-10-222001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2-2/+101
* shared/ppc.h: Added mpc8260 support.
2001-10-222001-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-3/+8
* src/threadhandler.c: Use __USE_INIT_FINI__ since USE_INIT_FINI pollutes the application namespace.
2001-10-192001-10-18 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill2-2/+1
* libc/open.c, libc/close.c: Moved freenode from open to close.
2001-10-182001-10-18 Eric Norum <eric.norum@usask.ca>Joel Sherrill2-23/+85
* lib/tftpDriver.c: Properly handles ../ components in chdir() and open() operations within the TFTP file system.
2001-10-172001-10-17 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill4-5/+14
* These changes were discussed and reviewed by many people but the primary people were Jennifer Averett <jennifer@OARcorp.com> and Eugeny Mints <jack@oktet.ru>. * libc/utime.c: Add missing call to rtems_filesystem_freenode() at verification that utime is supported by the filesystem. * libc/link.c: Remove calls to freenode when the node was not successfully allocated. * libc/unmount.c: In the method file_systems_below_this_mountpoint() added calls to correctly free fs_root_loc when a failure occurs. * libc/open.c: Add freenode calls upon failure. * libc/open.c, lib/libc/close.c: (PENDING -- NOT INCLUDED THIS TIMER) Modifications the move the freenode from open() to close() (also part of this patch) are pending further discussion.
2001-10-172001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* configure.ac: Use RTEMS_CPU_SUBDIRS to make autoconf-2.52 happy.
2001-10-172001-10-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+1
* .cvsignore: Add stamp-h.in.
2001-10-172001-10-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
2001-10-172001-10-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+5
* include/Makefile.am: Fixed path to cpuopts-tmp.h.
2001-10-162001-10-16 Chris Johns <ccj@acm.org>Joel Sherrill2-48/+53
* imfs/imfs_load_tar.c: Changed the code around to remove an internal compiler error on the Coldfire target.
2001-10-162001-10-16 Chris Johns <ccj@acm.org>Joel Sherrill6-9/+170
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h, optman/no-io.c, src/exinit.c, src/io.c: Added a device driver register/unregister interface to allow device drivers to be installed and removed at runtime. This means you do not need devices present in the device table when you build.
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-5/+1
* include/zilog/Makefile.am: Remove. * include/motorola/Makefile.am: Remove. * include/sys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5 * Makefile.am: Require automake-1.5.
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-19/+9
* configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron. Reflect changes to configuration of rtems, score and sapi subdirs.
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-14/+89
* include/rtems/Makefile.am: Remove. * include/rtems/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/rtems/rtems/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * macros/rtems/rtems/Makefile.am: Remove. * macros: Handle subdirs, require automake-1.5. * Makefile.am: require automake-1.5.
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-15/+63
* include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * Makefile.am: require automake-1.5.
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-11/+145
* include/rtems/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * macros/rtems/score/Makefile.am: Remove. * macros/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/rtems/score/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * Makefile.am: require automake-1.5
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-21/+101
* include/sys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/posix/Makefile.am: Remove. * include/Makefile.am: Handle subdirs. * inline/rtems/Makefile.am: Remove. * inline/rtems/posix/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs. * macros/rtems/Makefile.am: Remove. * macros/rtems/posix/Makefile.am: Remove. * macros/Makefile.am: Handle subdirs. * configure.ac: Reflect changes above.
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-21/+96
* include/itronsys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/itron/Makefile.am: Remove. * inline/rtems/Makefile.am: Remove. * inline/rtems/itron/Makefile.am: Remove. * macros/rtems/Makefile.am: Remove. * macros/rtems/itron/Makefile.am: Remove. * include/Makefile.am: handle subdirs. * inline/Makefile.am: handle subdirs. * macros/Makefile.am: handle subdirs. * configure.ac: Reflect changes above.
2001-10-152001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+6
* cpu.c: Fix #ifdefs, add missing #endif.
2001-10-122001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+0
* include/chain.h: Fixed typo.
2001-10-122001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-2/+4
* rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
2001-10-122001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+4
* shared/ppctypes.h: Fixed typo.
2001-10-122001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* include/rtems/directives.h: Fixed typo.
2001-10-122001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill8-0/+329
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
2001-10-122001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+38
2001-10-122001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill8-23/+58
* asm.h, cpu.c, rtems.c, rtems/score/cpu.h, rtems/score/sh.h, rtems/score/sh_io.h, rtems/score/shtypes.h: Consistency changes and made sure there were no includes from the libcpu tree.
2001-10-122001-10-12 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill4-16/+146
* cpu.c, rtems/score/cpu.h, rtems/score/sh.h: Modified to support SH4. Reviewed by Ralf Corsepius <corsepiu@faw.uni-ulm.de> who did the original SH port.
2001-10-122001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+8
* cpu_asm.S: _CPU_Context_save_fp in was incorrectly in conditional compilation block with (CPU_HARDWARE_FP == FALSE). Reported by Wayne Bullaughey <wayne@wmi.com>.
2001-10-122001-10-12 Mike Siers <mikes@poliac.com>Joel Sherrill10-308/+694
* Update to stable working state. Congratulations Mike! :) * modem_example: Directory removed. * modem_example/16550.h, modem_example/README, modem_example/modem.c, modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h, modem_example/pppcompress.c: Files removed. * pppd/example/pppd.options: New file. * pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c, pppd/pppd.h, pppd/rtemsmain.c: Updated.
2001-10-112001-10-11 Mike Siers <mikes@poliac.com>Joel Sherrill1-6/+22
* libc/termios.c: Fixed a memory leak in the termios software. Basically the tty open function was allocating an input raw buffer, an output raw buffer, and a cooked buffer that were not getting released. I have attached a patch for the latest snapshot. The patch also has a fix to ensure the tty link list is updated correctly when a tty is closed.
2001-10-112001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill17-0/+57
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
2001-10-112001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill48-0/+784
2001-10-112001-10-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+6
* src/imfs/imfs_getchild.c: Correct length of static string as reported by Ibragimov Ilya <ibr@oktet.ru>.
2001-10-102001-10-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* libc/printk.c (printNum): Properly handle a maxwidth of 0 as reported by Nick Hennenfent <NICK.HENNENFENT@ROCHE.COM>.
2001-09-282001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-2/+12
* dummy/dummy.c: Now a useful configuration that starts main(). * wrapup/Makefile.am: Include a base level configuration in RTEMS library.
2001-09-282001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-2/+6
* src/mqueueopen.c, src/semopen.c: Clarify type on va_arg.
2001-09-282001-09-27 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill1-0/+7
* cpu_asm.S: Small patch to fix a bug in the rtems sparc port. The bug has been there all the time, but only hits the leon bsp since the leon cpu has a 5-stage pipeline (erc32 has 4 stages).
2001-09-282001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+8
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-282001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+7
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-282001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* src/imfs/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-282001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-9/+22
* untar/Makefile.am: Use 'PREINSTALL_FILES ='. * monitor/Makefile.am: Use 'PREINSTALL_FILES ='. * shell/Makefile.am: Use 'PREINSTALL_FILES ='. * devnull/Makefile.am: Use 'PREINSTALL_FILES ='. * dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='. * mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='. * stackchk/Makefile.am: Use 'PREINSTALL_FILES ='. * rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='. * cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='. * rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-272001-09-27 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill1-4/+4
