object code that has to be loaded just for initializing the signal
manager.
NULL pointer.
rtems_bsdnet_makeFdForSocket().
and eliminate a link error.
so that the libc code did not have to know about (struct socket).
split into multiple files.
outside RTEMS. Comment:
I found a couple of places other than RTEMS where I'd like to use
the declarations supplied in m68360.h. To make this easier to do,
I've redone the declarations in m68360.h to use standard C types.
<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
with the --disable-posix option, stubs for some routines (_getpid_r and
_kill_r) that are normally defined with POSIX were added.
getting the spurious trap handling to work required a couple more
fixes - I have attached a patch against rtems-4.0.0 with the
necessary changes. I also added functionality so that the
address of the trapped instruction is reported and in case of
a data access error, the data address is also reported.
prototype.
properly in conditionals
all conflicts.
Date: Sat, 5 Dec 98 13:20:51 -0600
What do you think of this patch? It implements your `tap'
suggestion in a way that adds support for all ethernet devices with
no driver modifications. I also added a return value from the tap
function. If the return value is zero, the packet will be passed up
the chain as usual. If the return value is non-zero the mbuf holding
the packet will be freed and the packet will be dropped.
If you like it, please submit it to Joel.
I guess there needs to be an addition to the network documentation
describing the additional ioctl's -- and a big warning that the tap
function is called from a context that holds the network semaphore.
Here is Eric's patch. I've tested it a bit, and made a couple of
trivial changes. This is certainly better than mine: it should work
for all Ethernet drivers.
The only concern I have about this patch is that the tap function may
want to fiddle with the mbuf, calling functions like m_pullup and the
like. If those force the networking code to rearrange the mbuf
structure, then the caller's call to m_freem may crash. I don't know
if this is a realistic concern--I don't know enough about the mbuf
layer.
RTEMS permits using the SO_SNDTIMEO and SO_RCVTIMEO socket options to
set a timeout for most socket I/O operations. However, in RTEMS
4.0.0, those options do not affect connect or accept. I don't know of
any way to put a timeout on those calls in RTEMS 4.0.0; can anybody
point to one.
Since it is frequently useful to have a timeout on accept, and
sometimes useful to have a timeout on connect shorter than the BSD
system default of 75 seconds, the following patch causes SO_RCVTIMEO
to affect connect and accept.
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
Include files now installed as <rtems/*.h>.
PROBLEMS
can/will be fixed.
it work.
1) Socket timeout field changed from `short' to `long'. This makes longer
timeouts possible. With a 1 kHz system clock the old system allowed
timeouts only up to a little over 30 seconds! This change is a
slightly cleaned-up version of the patch proposed by Ian Lance Taylor.
2) Major changes to BOOTP/DHCP reply handling. Now supports much of
RFC2132. These changes were done at the request of, and with the
assistance of, Erik Ivanenko.
If you're making changes, you might want to change the network
supplement Essentially just do a global search and replace of BOOTP
with BOOTP/DHCP.
I just happened across the sync_io support in
c/src/exec/score/cpu/unix/cpu.c
(is this documented anywhere?). That looked more useful than the
signal driven I/O I was using before, so I tried it. I ran across a
few bugs in the way it uses select.
Select changes its fd_set arguments, so you can't use global variables
for them. You have to copy them into local variables first.
If select returns -1 with errno set to EINTR, then it has not changed
any of the fd_sets. You can't start looking at them.
When clearing a descriptor, the code has the usual select off by one
error when setting sync_io_nfds.
I don't see how this code could ever have worked correctly.
I have appended a patch for the problems I found.
with libchip.
in include file order.
