* | score: Fix _Thread_Change_priority() | Sebastian Huber | 2015-03-20 | 3 | -14/+31 |
| | | | | | | | | | | Atomically update the current priority of a thread and the wait queue. Serialize the scheduler update in a separate critical section with a generation number. New test sptests/spintrcritical23. Close #2310. | ||||
* | score: Delete unused _Timestamp_Is_valid() | Alexander Krutwig | 2015-03-19 | 2 | -31/+0 |
* | score: Fix _Debug_Is_owner_of_allocator() | Sebastian Huber | 2015-03-19 | 1 | -2/+11 |
* | libmisc/capture: Clean up formatting on ARM. | Chris Johns | 2015-03-19 | 2 | -22/+29 |
| | | | | | | | | The printing of 64bit diff's for the timestamp did not work on ARM so I have changed this to 32bit. A 32bit nano-second diff between events should be more than enough time. Print '____' for POSIX thread output. | ||||
* | testsupport: Do not suspend worker tasks | Sebastian Huber | 2015-03-18 | 1 | -1/+3 |
* | libmisc/redirector: Fix unlock on exit from the handler. | Chris Johns | 2015-03-18 | 1 | -1/+1 |
* | IMFS: NUL-terminate name returned by readdir() | Sebastian Huber | 2015-03-17 | 1 | -2/+5 |
* | cpukit/include/rtems/btimer.h: Improve brief | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | Disable deprecated warning on implementation of deprecated methods | Joel Sherrill | 2015-03-17 | 8 | -4/+46 |
* | libmisc/monitor/mon-task.c: Disable deprecated warning for use of notepads | Joel Sherrill | 2015-03-17 | 1 | -2/+21 |
* | cpukit/libdl/rtl-obj-comp.c: Use correct printf() specification | Joel Sherrill | 2015-03-17 | 2 | -3/+3 |
* | testsupport: Add worker setup handler | Sebastian Huber | 2015-03-17 | 2 | -12/+71 |
| | | | | Add rtems_test_parallel_get_task_id(). | ||||
* | score: Ensure properties of CPU_Uint32ptr | Sebastian Huber | 2015-03-17 | 1 | -0/+10 |
* | cpukit: add and use CPU_Uint32ptr type | Gedare Bloom | 2015-03-16 | 21 | -2/+61 |
* | IMFS: don't strlen() an unterminated string in IMFS_dir_read(). | Jamie Iles | 2015-03-16 | 1 | -1/+1 |
| | | | | | | | | | a43a3466 (IMFS: Implement variable length node names) introduced a changed to IMFS_jnode_t from being a null terminated string to a separate unterminated string and length. IMFS_dir_read() was still performing a strlen() on this unterminated string though and when doing an 'ls' in the fileio example I saw that some filenames had garbage suffixes. | ||||
* | shell: remove rtems ifdef, upstream is correct | Gedare Bloom | 2015-03-16 | 1 | -8/+0 |
* | shell: fix printf warnings | Gedare Bloom | 2015-03-16 | 1 | -4/+5 |
* | capture: fix warnings in print | Gedare Bloom | 2015-03-16 | 1 | -4/+6 |
* | rtems: make error codes uintptr_t | Gedare Bloom | 2015-03-16 | 1 | -1/+1 |
* | rfs: cast minor to uintptr_t to truncate explicitly | Gedare Bloom | 2015-03-16 | 1 | -2/+2 |
* | score: Add _Objects_ISR_disable_and_acquire() | Sebastian Huber | 2015-03-15 | 1 | -7/+22 |
* | score/or1k: Fix warnings. Add missing prototypes | Hesham ALMatary | 2015-03-13 | 1 | -0/+4 |
| | | | | Closes #2304 | ||||
* | posix/src/nanosleep.c: Address issue when delay is longer than desired | Joel Sherrill | 2015-03-12 | 1 | -16/+27 |
| | | | | | | | This resulted in the elapsed time going below 0 and an arbitrarily large number returned as the time remaining. closes #2296. | ||||
* | posix: Return error code if mmap is used | Daniel Cederman | 2015-03-12 | 1 | -1/+1 |
* | posix: Move function to file with matching name | Daniel Cederman | 2015-03-12 | 2 | -10/+10 |
| | | | | mmap was previously in munmap.c and munmap was in mmap.c. | ||||
* | confdefs.h: Improve the Doxygen | Joel Sherrill | 2015-03-11 | 1 | -121/+780 |
* | cpukit/include/rtems/btimer.h: Add DOxygen comments | Joel Sherrill | 2015-03-11 | 1 | -2/+56 |
* | cpukit/include/rtems/bspIo.h: Add Doxygen comments | Joel Sherrill | 2015-03-11 | 1 | -29/+107 |
* | cpukit: Remove old DESCRIPTION: in comments | Joel Sherrill | 2015-03-11 | 12 | -131/+24 |
| | | | | These were remnants of pre-Doxygen comment style. | ||||
* | cpukit: deprecate task variables. closes #2293. | Gedare Bloom | 2015-03-10 | 3 | -4/+15 |
* | cpukit: deprecate rtems_clock_get(). closes #2294. | Gedare Bloom | 2015-03-10 | 1 | -1/+4 |
* | cpukit: deprecate notepads | Gedare Bloom | 2015-03-10 | 3 | -7/+18 |
| | | | | | | | | | | | | | | | Deprecate Classic API Notepads. Mark task_set/get_note() with the deprecated attribute, and also mark the notepads field. Replace disable with enable option for notepads in confdefs.h, and make notepads disabled by default. The previous option CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and will emit a compile-time warning. A new option CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn on notepads, but it also will emit a compile-time warning to indicate that notepads are deprecated. Closes #2265 | ||||
* | cpukit/libcrypt/misc.c: Reverse order of statements in ifdef | Joel Sherrill | 2015-03-10 | 1 | -2/+2 |
* | posix: Install <semaphore.h> only if not provided | Sebastian Huber | 2015-03-10 | 3 | -1/+7 |
* | libcsupport: Delete superfluous _gettimeofday() | Sebastian Huber | 2015-03-10 | 1 | -16/+0 |
* | posix: Change sem_t to the 32-bit object type | Sebastian Huber | 2015-03-10 | 2 | -2/+2 |
| | | | | | This change is also valid for 16-bit object type architectures since in this case POSIX_Semaphore_Control::Semaphore_id is used as a proxy. | ||||
* | posix: Use a value of 0 for SEM_FAILED | Sebastian Huber | 2015-03-10 | 1 | -1/+1 |
| | | | | This is the standard NULL pointer. | ||||
* | score: Add rtems_set_errno_and_return_value() | Sebastian Huber | 2015-03-10 | 3 | -17/+16 |
| | | | | Remove rtems_set_errno_and_return_minus_one_cast(). | ||||
* | cpukit/libmisc/fsmount/fsmount.h: Remove duplicate comments and copyright | Joel Sherrill | 2015-03-09 | 1 | -29/+7 |
* | cpukit/dev/include/dev/i2c/i2c.h: Fix Doxygen grouping | Joel Sherrill | 2015-03-09 | 1 | -0/+2 |
* | Move contents of libcsupport/include/zilog into libbsp/shared | Joel Sherrill | 2015-03-09 | 4 | -223/+0 |
| | | | | Only a few BSPs use this and it should not have been in libcsupport. | ||||
* | Remove unused cpukit/libcsupport/include/zilog/z8536.h | Joel Sherrill | 2015-03-09 | 3 | -122/+0 |
* | Move libcsupport/include/motorola/*.h to m68k/idp BSP | Joel Sherrill | 2015-03-09 | 3 | -392/+0 |
| | | | | | | | These header files were only used by one BSP and they are hardware dependent. The hardware dependency always made them bad candidates for where they were in the tree. But this fixes that. | ||||
* | cpukit/libcrypt/misc.c: Conditionally correct 16-bit unclean code | Joel Sherrill | 2015-03-09 | 1 | -0/+4 |
* | cpukit/libdl/rtl-mdreloc-m32r.c: Add parentheses per Chris' suggestion | Joel Sherrill | 2015-03-09 | 1 | -1/+1 |
* | vprintk.c: Reorder switch and add default to eliminate warning | Joel Sherrill | 2015-03-09 | 1 | -4/+5 |
* | or1k/rtems/score/cpu.h: Add no_return attribute to _CPU_Context_restore | Joel Sherrill | 2015-03-09 | 1 | -1/+1 |
* | cpukit/score/cpu/sh/context.c: Correct name of _CPU_Context_switch | Joel Sherrill | 2015-03-09 | 1 | -1/+1 |
* | or1k: Correct _CPU_Thread_Idle_body prototype | Joel Sherrill | 2015-03-09 | 2 | -2/+2 |
* | sysconf: Add _SC_NPROCESSORS_(CONF|ONLN) | Sebastian Huber | 2015-03-09 | 1 | -0/+4 |
