* libmisc/monitor/mon-network.c: Include <rtems/monitor.h>.
* libmisc/monitor/mon-object.c:
Make rtems_monitor_object_canonical_next_remote,
rtems_monitor_object_dump_1, rtems_monitor_object_dump_all static.
* libmisc/monitor/mon-prmisc.c:
Make rtems_monitor_dump_assoc_bitfield static.
* libmisc/monitor/mon-symbols.c:
Make rtems_monitor_symbol_dump_all static.
* score/src/schedulercbsattachthread.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbssetparameters.c:
Remove checks for server_id < 0 (server_id is unsigned).
* posix/src/pspinlocktranslatereturncode.c:
Include <rtems/posix/spinlock.h> (Missing prototypes).
* libfs/src/imfs/imfs_debug.c: Make IMFS_print_jnode,
IMFS_dump_directory static.
* libfs/src/imfs/memfile.c: Make memfile_free_blocks_in_table static.
* libcsupport/include/rtems/libio.h:
Make LIBIO_FLAGS_* defined unsigned (Avoid implicit sign
conversions).
* libmisc/capture/capture.c:
Make RTEMS_CAPTURE_* defines unsigned (Avoid implicit
sign-conversions).
Make rtems_capture_trigger static (Missing prototypes).
* libmisc/capture/capture.h:
Make RTEMS_CAPTURE_WATCH, RTEMS_CAPTURE_TRACED unsigned (Avoid
implicit sign conversions).
* rtems/src/rtemsobjectapimaximumclass.c:
Include <rtems/rtems/object.h> (Missing prototypes).
* sapi/src/exshutdown.c:
Include <rtems/init.h> (Missing prototypes).
* libmisc/mouse/mouse_parser.c: Make MOU_Data static.
* libcsupport/src/chown.c, libcsupport/src/lchown.c:
Include <unistd.h>. Cleanup included headers.
* posix/include/rtems/posix/pthread.h:
Add _POSIX_Threads_Initialize_user_threads_body.
* rtems/include/rtems/rtems/tasks.h:
Add _RTEMS_tasks_Initialize_user_tasks_body.
* sapi/include/confdefs.h: Remove conditional, nested redeclaration of
_POSIX_Threads_Initialize_user_threads_body,
* libmisc/shell/shell.h: Add rtems_shell_main_monitor.
* libmisc/shell/cmds.c: Make rtems_shell_main_monitor non-static.
* rtems/src/tasks.c: Fix typos.
* rtems/src/taskinitusers.c: Fix typos.
* posix/src/pthread.c: Fix typos.
* posix/src/pthreadinitthreads.c: Fix typos.
* rtems/include/rtems/rtems/tasks.h: Typo fixes.
* posix/src/pthreadatfork.c:
Include <pthread.h> (Missing prototypes).
* posix/src/mqueuetranslatereturncode.c:
Include <rtems/posix/mqueue.h> (Missing prototypes).
* posix/src/mutextranslatereturncode.c:
Include <rtems/posix/mutex.h> (Missing prototypes).
* posix/src/semaphoretranslatereturncode.c:
Include <rtems/posix/semaphore.h> (Missing prototypes).
* posix/src/mqueuenotify.c: Make _POSIX_Message_queue_Notify_handler
static.
* posix/src/fork.c: Include <unistd.h> for "fork" prototype.
Don't include <sys/types.h> (unnecessary).
* libcsupport/src/termios.c: Remove unnecessary cast.
* libmisc/shell/main_mv.c: Add prototype for main_mv.
* libmisc/shell/main_cp.c: Include "internal.h".
Make rtems_shell_main_cp non-static.
* libmisc/shell/main_ls.c: Include "internal.h".
* libmisc/shell/main_mv.c: Remove decl of user_from_uid,
group_from_gid.
* libmisc/shell/main_rm.c: Remove decl of user_from_uid.
Comment out decl of fflagstostr.
* libmisc/shell/pwcache.c: Include "internal.h".
Make user_from_uid non-static.
* libmisc/shell/internal.h: Add user_from_uid, group_from_gid.
* libmisc/shell/print-ls.c: Include "internal.h".
* libmisc/shell/pwcache.c: Make user_from_uid static.
* libmisc/shell/shell.c: Make rtems_shell_init_env,
rtems_shell_env_free, rtems_shell_line_editor,
rtems_shell_init_issue, rtems_shell_task static.
* libmisc/shell/shell_cmdset.c: Make rtems_shell_add_topic static.
* libmisc/shell/shell_makeargs.c: Include <rtems/shell.h>.
* libmisc/shell/write_file.c: Include <rtems/shell.h>.
rtems_shell_help static.
* libmisc/shell/main_hexdump.c: Make main_hexdump static.
* libmisc/shell/main_id.c: Make rtems_shell_main_id static.
* libmisc/shell/main_ifconfig.c: Make rtems_shell_main_ifconfig static.
* libmisc/shell/main_ln.c: Make rtems_shell_main_ln static.
* libmisc/shell/main_logoff.c: Make rtems_shell_main_logoff static.
* libmisc/shell/main_ls.c: Make rtems_shell_main_ls static.
* libmisc/shell/main_mallocinfo.c: Include <rtems/libcsupport.h>.
Remove private decls of malloc_info,
rtems_shell_print_unified_work_area_message.
Make rtems_shell_main_malloc_info static.
* libmisc/shell/main_medit.c: Remove private decl of
rtems_shell_main_mdump.
Make rtems_shell_main_medit static.
* libmisc/shell/main_mfill.c: Make rtems_shell_main_mfill static.
* libmisc/shell/main_mkdir.c: Make rtems_shell_main_mkdir static.
* libmisc/shell/main_mknod.c: Make rtems_shell_main_mknod static.
* libmisc/shell/main_mmove.c: Remove private decl of
Make rtems_shell_main_mmove static.
* libmisc/shell/main_mount.c: Make rtems_shell_main_mount static.
* libmisc/shell/main_msdosfmt.c: Make rtems_shell_main_msdos_format
static.
* libmisc/shell/main_mv.c: Include "internal.h".
Make rtems_shell_mv_exit, rtems_shell_main_mv static.
Remove private decls of strmode rtems_shell_main_cp,
rtems_shell_main_rm.
* libmisc/shell/main_mwdump.c: Make rtems_shell_main_mwdump static.
* libmisc/shell/main_netstats.c: Make rtems_shell_main_netstats
static.
* libmisc/shell/main_perioduse.c: Make rtems_shell_main_perioduse
static.
* libmisc/shell/main_pwd.c: Make rtems_shell_main_pwd static.
* libmisc/shell/main_rm.c: Include "internal.h".
Make rtems_shell_rm_exit static.
Remove private decl of strmode.
* libmisc/shell/main_rmdir.c: Make rtems_shell_main_rmdir static.
libmisc/shell/main_route.c: Make rtems_shell_main_route static.
* libmisc/shell/main_setenv.c: Make rtems_shell_main_setenv static.
* libmisc/shell/main_sleep.c: Make rtems_shell_main_sleep static.
* libmisc/shell/main_stackuse.c: Make rtems_shell_main_stackuse static.
* libmisc/shell/main_time.c: Make rtems_shell_main_time static.
* libmisc/shell/main_tty.c: Make rtems_shell_main_tty static.
* libmisc/shell/main_umask.c: Make rtems_shell_main_umask static.
* libmisc/shell/main_unmount.c: Make rtems_shell_main_unmount
static.
* libmisc/shell/main_unsetenv.c: Make rtems_shell_main_unsetenv
static.
* libmisc/shell/main_whoami.c: Make rtems_shell_main_whoami static.
* libmisc/shell/main_wkspaceinfo.c: Make
rtems_shell_main_wkspace_info static.
Make rtems_shell_main_monitor static.
* libmisc/shell/main_alias.c:
Make rtems_shell_rtems_main_alias static.
* libmisc/shell/main_blksync.c:
Make rtems_shell_main_blksync static.
* libmisc/shell/main_cat.c:
Make rtems_shell_main_cat static.
* libmisc/shell/main_chdir.c:
Make rtems_shell_main_chdir static.
* libmisc/shell/main_chmod.c:
Make rtems_shell_main_chmod static.
* libmisc/shell/main_chroot.c:
Make rtems_shell_main_chroot static.
Make rtems_shell_cp_exit, rtems_shell_main_cp static.
* libmisc/shell/main_cpuuse.c:
Make rtems_shell_main_cpuuse static.
* libmisc/shell/main_date.c:
Make rtems_shell_main_date static.
* libmisc/shell/main_dd.c:
Make rtems_shell_main_dd static.
* libmisc/shell/main_echo.c:
Make rtems_shell_main_echo static.
* libmisc/shell/main_getenv.c:
Make rtems_shell_main_getenv static.
* libmisc/shell/main_halt.c:
Make rtems_shell_main_halt static.
* libmisc/shell/internal.h: #include "shell.h".
Add various missing decls.
* libmisc/shell/cat_file.c: #include <rtems/shell.h>.
* libmisc/shell/filemode.c: #include "internal.h".
* libmisc/shell/shell.h: Declare functions "extern".
* libmisc/shell/shell_cmdset.c: Remove superflous casts.
* libcsupport/src/termios.c: Make FL_* defines unsigned.
* score/inline/rtems/score/coremsg.inl (_CORE_message_queue_Send,
_CORE_message_queue_Urgent):
* posix/src/aio_misc.c: Make rtems_aio_move_to_work,
rtems_aio_insert_prio static.
* libcsupport/src/getgid.c: Include <unistd.h>.
* libcsupport/src/setgid.c: Include <unistd.h>.
* libcsupport/src/getpgrp.c: Include <unistd.h>.
Remove unnecessary includes.
* posix/src/pthread.c (_POSIX_Threads_Default_attributes): Add
missing initializer.
* posix/src/pthread.c: Make
_POSIX_Threads_Create_extension,_POSIX_Threads_Delete_extension,
_POSIX_Threads_Exitted_extension,
_POSIX_Threads_Initialize_user_threads static.
* libcsupport/include/rtems/libcsupport.h:
Add prototype of malloc_info().
* libfs/src/imfs/deviceerrno.c:
Include <rtems/devfs.h> for missing prototypes.
* libfs/src/rfs/rtems-rfs-rtems-dev.c:
Remove duplicate prototype of rtems_deviceio_errno.
Include <rtems/devfs.h> for rtems_deviceio_errno().
* score/src/rbtreeextract.c:
Make _RBTree_Extract_validate_unprotected static.
* score/src/rbtreeinsert.c:
Make _RBTree_Validate_insert_unprotected static.
* libcsupport/include/sys/termios.h: Add _POSIX_VDISABLE.
* rtems/src/tasks.c: Make _RTEMS_tasks_Create_extension,
_RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension,
_RTEMS_tasks_Switch_extension, _RTEMS_tasks_Post_switch_extension
static.
* score/src/scheduleredf.c: Make _Scheduler_EDF_RBTree_compare_function
static.
* libfs/src/imfs/imfs_eval.c: Make IMFS_evaluate_permission,
IMFS_evaluate_hard_link, IMFS_evaluate_sym_link static.
* libfs/src/imfs/imfs_fifo.c: Make IMFS_fifo_open,
IMFS_fifo_close, IMFS_fifo_read, IMFS_fifo_write,
IMFS_fifo_ioctl static.
* aclocal/check-smp.m4: Fix bogus log message.
* libnetworking/rtems/mkrootfs.c: Use mode_t for modes,
Use size_t for sizes.
* libcsupport/src/open.c: Use va_arg(..., mode_t) to retrieve mode.
* posix/src/mqueueopen.c: Use va_arg(..., mode_t) to retrieve mode.
