<corsepiu@faw.uni-ulm.de>.
in the previous commits.
to convert the libmisc directory from Makefile.in to Makefile.am.
+ Cleaned up code.
+ Corrected enable/disable of dispatch.
Synthesizer Control Register to remove use of single letter names.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
<corsepiu@faw.uni-ulm.de> to correct the constraints on the
inline assembly language macro for sh_disable_interrupt.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
its name in the name_table. This was required by the POSIX semaphore
and message queue managers which support a concept of open, close, and
unlink. The object becomes "invisible" to further opens following an
unlink but all open sessions remain active until they are closed. This
requires that the removal of an object ID be separate from the removal
of its name.
but all paths have not been checked, yet.
to UnixWare (UW).
by Joel and Jennifer based on experience merging the other managers
and cleaning them up. No test code is available at this point.
RTEMS API extension to avoid problems when the extension is freed.
Eventually the task variable switch extension should become part
of the core context switch and the Ada tcb self implemented in
terms of it.
POSIX API is disabled.
places under the libbsp tree.
port only uses System V IPC for shared memory and semaphores to
communicate between nodes in a multiprocessor configuration. If you
disable multiprocessing, then this code should be unused. Thus systems
like Cygwin which are POSIX but do not support System V IPC should
not work.
Removed times() since the version in the C Library support code is
fine.
being reinserted onto the ticks chain.
_ITRON_Message_buffer_Translate_core_message_buffer_return_code.
was made in the conversion of bcopy() to strncpy().
