Delete _Thread_Evaluate_is_dispatch_needed().
Use _Thread_Dispatch_is_enabled() in rtems_task_mode() instead of the
system state to determine if a thread dispatch is allowed. Signales are
now delivered in rtems_task_mode() even if preemption is disabled. This
is in line with rtems_signal_send().
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
We must obtain the processor ID after interrupts are disabled since a
non-optimizing compiler may store the value on the stack and read it
back.
Add and use _Per_CPU_Lock_release().
Returning this state in the return value leads to race conditions on
SMP. The inactive state notification must be inside the critical
section.
Use interrupt disable/enable to protect the complete refill state
change. This avoids race conditions for the task driven configuration
and a later SMP support.
Interrupt locks are low-level lock to protect critical sections accessed
by threads and interrupt service routines.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
Provide SMP support. The ISR disable/enable is not enough to ensure
mutual exclusion for SMP configurations.
Align ISR disable/enable sequence in _Objects_Get_isr_disable() with
thread dispatch disable/enable sequence in _Objects_Get().
Move thread dispatch declarations and inline functions to new header
<rtems/score/threaddispatch.h> to make it independent of the
Thread_Control structure. This avoids a cyclic dependency in case
thread dispatch functions are used for the object implementation.
The _Thread_Initialize() function has nothing to do with thread
dispatching it simply initializes the thread control.
This prevents a lock order reversal.
Add optional conversion methods for multibyte strings. With these
conversions which make use of iconv and utf8proc it becomes possible to
use strings from any language (Czech, Chinese, Arabian, Hebrew, Corean,
...) for file names and directory names.
NOTE: Iconv support must be activated during the build of the tool chain
for these conversion methods (options --enable-newlib-iconv
--enable-newlib-iconv-encodings=[ENCODINGS_YOU_WANT]). Alternatively
you can provide your own conversion methods.
utf8proc is a small library for processing UTF-8 encoded Unicode strings.
Some features are Unicode normalization, stripping of default ignorable characters, case folding and detection of grapheme cluster boundaries.
For the time beeing utf8proc is intended to be used for normalizing and folding UTF-8 strings
for comparison purposes when adding UTF-8 support to the FAT file system.
User interface and backwards compatibility for UTF-8 support in the FAT
file system. Purpose of UTF-8 support is to permit file names and
directory names with characters from all kinds of languages (Czech,
Chinese, Arabian, Hebrew, Korean, ...). This commit does not yet
support multibyte characters. It only contains the user interface and
the backwards compatibility.
Move the SMP lock implementation to the CPU port. An optimal SMP lock
implementation is highly architecture dependent. For example the memory
models may be fundamentally different.
The new SMP lock API has a flaw. It does not provide the ability to use
a local context for acquire and release pairs. Such a context is
necessary to implement for example the Mellor-Crummey and Scott (MCS)
locks. The SMP lock is currently used in _Thread_Disable_dispatch() and
_Thread_Enable_dispatch() and makes them to a giant lock acquire and
release. Since these functions do not pass state information via a
local context there is currently no use case for such a feature.
Mark rtems_smp_secondary_cpu_initialize() as no return.
This field is unused except for special case simulator clock drivers.
In these places use an alternative. Add and use
_Thread_Set_global_exit_status() and _Thread_Get_global_exit_status().
Do not assume that the scheduler selects the main processor for the
initialization thread.
Delete bsp_smp_wait_for(). Other parts of the system work without
timeout, e.g. the spinlocks. Using a timeout here does not make the
system more robust.
Delete bsp_smp_cpu_state and replace it with Per_CPU_State. The
Per_CPU_State follows the Score naming conventions. Add
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state() functions to
change and observe states.
Use Per_CPU_State in Per_CPU_Control instead of the anonymous integer.
Add _CPU_Processor_event_broadcast() and _CPU_Processor_event_receive()
functions provided by the CPU port. Use these functions in
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state().
Add prototype for _SMP_Send_message().
Delete RTEMS_BSP_SMP_FIRST_TASK message. The first context switch is
now performed in rtems_smp_secondary_cpu_initialize(). Issuing the
first context switch in the context of the inter-processor interrupt is
not possible on systems with a modern interrupt controller. Such an
interrupt controler usually requires a handshake protocol with interrupt
acknowledge and end of interrupt signals. A direct context switch in an
interrupt handler circumvents the interrupt processing epilogue and may
leave the system in an inconsistent state.
Release lock in rtems_smp_process_interrupt() even if no message was
delivered. This prevents deadlock of the system.
Simplify and format _SMP_Send_message(),
_SMP_Request_other_cores_to_perform_first_context_switch(),
_SMP_Request_other_cores_to_dispatch() and
_SMP_Request_other_cores_to_shutdown().
Do not call bsp_smp_secondary_cpu_initialize() in
rtems_smp_secondary_cpu_initialize(). This allows more flexibilty in
the BSP low-level code. Specify context requirements for a call to
Call _SMP_Handler_initialize() later and move bsp_smp_initialize() into
_SMP_Handler_initialize(). Change bsp_smp_initialize() prototype to
match integer types of calling context.
