2007-01-09 | 2007-01-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -3/+5 | |
* libcsupport/src/error.c: rtems_progname is no longer defined in the BSP startup since it never held a meaningful value. | |||||
2007-01-08 | Regenerate. | Ralf Corsepius | 29 | -76/+76 | |
2007-01-02 | 2007-01-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+6 | |
* posix/include/aio.h: s/aoi_lio_opcode/aio_lio_opcode/ (BZ 1203). | |||||
2006-12-13 | 2006-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+12 | |
* backward/rtc.h, backward/vmeintr.h, backward/confdefs.h, backward/clockdrv.h, backward/itron.h, backward/console.h, backward/imfs.h, backward/iosupp.h, backward/chain.h, backward/motorola/mc68681.h, backward/motorola/mc68230.h, backward/spurious.h, backward/rtemspppd.h, backward/zilog/z8536.h, backward/zilog/z8030.h, backward/zilog/z8036.h, backward/dosfs.h, backward/rtemsdialer.h, backward/asm.h, backward/timerdrv.h, backward/ringbuf.h, backward/ftpd.h: Abandon. | |||||
2006-12-13 | Abandon. | Ralf Corsepius | 22 | -264/+0 | |
2006-12-13 | 2006-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+8 | |
* rtems/include/rtems/rtems/types.h: Abandon backward compatibility types. * include/rtems/stdint.h: Abandon DEPRECATED_TYPES. * configure.ac: Abandon DEPRECATED_TYPES/--enable-deprecated. * Makefile.am: Abandon DEPRECATED_TYPES. | |||||
2006-12-13 | Abandon backward compatibility types. | Ralf Corsepius | 1 | -19/+1 | |
2006-12-13 | Regenerate. | Ralf Corsepius | 1 | -103/+0 | |
2006-12-13 | Abandon DEPRECATED_TYPES. | Ralf Corsepius | 2 | -46/+0 | |
2006-12-13 | Abandon DEPRECATED_TYPES/--enable-deprecated. | Ralf Corsepius | 1 | -14/+0 | |
2006-12-13 | 2006-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/rtems-ampolish.m4: Use am_aux_dir/ampolish3. | |||||
2006-12-13 | Use am_aux_dir/ampolish3. | Ralf Corsepius | 1 | -1/+1 | |
2006-12-13 | Fix ugly typos. | Ralf Corsepius | 1 | -2/+2 | |
2006-12-12 | 2006-12-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* aclocal/rtems-ampolish.m4: Require AM_MAINTAINER_MODE. | |||||
2006-12-12 | Remove RTEMS_AMPOLISH. | Ralf Corsepius | 1 | -2/+0 | |
2006-12-12 | 2006-12-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* aclocal/rtems-top.m4: Remove RTEMS_AMPOLISH. * configure.ac: Add RTEMS_AMPOLISH. | |||||
2006-12-12 | Add RTEMS_AMPOLISH. | Ralf Corsepius | 1 | -0/+2 | |
2006-12-12 | Remove RTEMS_AMPOLISH. | Ralf Corsepius | 1 | -0/+1 | |
2006-12-12 | 2006-12-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* rtems/score/ppc.h: Remove (Deprecated in 4.7). * Makefile: Remove rtems/score/ppc.h. | |||||
2006-12-12 | Regenerate. | Ralf Corsepius | 1 | -5/+0 | |
2006-12-12 | Remove rtems/score/ppc.h. | Ralf Corsepius | 1 | -3/+0 | |
2006-12-12 | Remove (Deprecated in 4.7). | Ralf Corsepius | 1 | -19/+0 | |
2006-12-12 | 2006-12-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* rtems/src/barrierrelease.c: Remove stray rtems_unsigned32. | |||||
2006-12-12 | Remove stray rtems_unsigned32. | Ralf Corsepius | 1 | -1/+1 | |
2006-12-12 | 2006-12-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -11/+6 | |
* libfs/src/imfs/imfs.h: Remove increment_and_check_linkcounts (unused), decrement_linkcounts (unused, broken). | |||||
2006-12-08 | 2006-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* libnetworking/net/route.c, libnetworking/netinet/ip_input.c, libnetworking/sys/domain.h: Cosmetics from FreeBSD. | |||||
2006-12-08 | Cosmetics from FreeBSD. | Ralf Corsepius | 3 | -74/+62 | |
* libnetworking/rtems/rtems_glue.c: Remove local extern strdup. | |||||
2006-12-08 | Remove local extern strdup. | Ralf Corsepius | 1 | -1/+0 | |
2006-12-08 | 2006-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+10 | |
* libcsupport/include/rtems/libio.h, libcsupport/src/read.c, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/memfile.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/rtems/rtems_syscall.c: Use size_t instead of uint32_t for read/write count-args. | |||||
2006-12-08 | Use size_t instead of uint32_t for read/write count-args. | Ralf Corsepius | 12 | -27/+27 | |
2006-12-08 | 2006-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
* rtems/src/timerserverfirewhen.c: Remove local extern _Timer_Seconds_chain. * rtems/src/timerserverfireafter.c: Remove local extern _Timer_Ticks_chain. | |||||
2006-12-08 | Remove local extern _Timer_Ticks_chain. | Ralf Corsepius | 1 | -1/+0 | |
2006-12-08 | Remove local extern _Timer_Seconds_chain. | Ralf Corsepius | 1 | -1/+0 | |
2006-12-06 | 2006-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* score/include/rtems/score/object.h, score/src/objectclearname.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c: Add const qualifiers, use size_t where appropriate. | |||||
2006-12-06 | Add const qualifiers, use size_t where appropriate. | Ralf Corsepius | 4 | -19/+19 | |
2006-12-05 | 2006-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -4/+9 | |
* score/inline/rtems/score/thread.inl: Add const qualifiers to work around aliasing effects. | |||||
2006-12-04 | More consts | Ralf Corsepius | 1 | -3/+3 | |
2006-12-04 | 2006-12-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -6/+11 | |
* score/inline/rtems/score/chain.inl: Add const qualifiers (works around 651 aliasing bugs). | |||||
2006-12-04 | 2006-12-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 7 | -10/+48 | |
* posix/src/prwlockunlock.c, rtems/Makefile.am, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, score/src/corerwlockobtainread.c, score/src/corerwlockrelease.c: Complete implementation of barrier as the rest of the test code is now implemented. Also add blocking code to rwlock. | |||||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-11-27 | 2006-11-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* score/src/threadget.c: Remove (Unused). * score/Makefile.am: Removing score/src/threadget.c. | |||||
2006-11-27 | Remove score/src/threadget.c. | Ralf Corsepius | 1 | -1/+1 | |
2006-11-27 | Remove (Unused). | Ralf Corsepius | 1 | -33/+0 | |
2006-11-21 | 2006-11-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* libblock/Makefile.am: Don't include preinstall.am. * libblock/preinstall.am: Remove. | |||||
2006-11-21 | Remove (unused). | Ralf Corsepius | 1 | -7/+0 | |
2006-11-20 | 2006-11-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+4 | |
* Makefile.am: Remove ampolish3. | |||||
2006-11-19 | Cosmetics. | Ralf Corsepius | 1 | -1/+1 | |
2006-11-19 | Fix typo in yesterday's patch. | Ralf Corsepius | 1 | -1/+1 | |
2006-11-18 | 2006-11-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -21/+26 | |
* score/src/heapwalk.c: Do not use printk yet since many BSPs do not prove the hooks for printk yet. This will require enough BSP changes to delay until 4.8. |
