* configure.ac: Add check for uintmax_t.
* libcsupport/src/malloc.c: Use uintmax_t instead of uint64_t for
MALLOC_STATS statistics. Use inttypes.h PRIxXXX macros for
printing.
Use inttypes.h PRIxXXX macros for printing.
* aclocal/check-networking.m4: Integrate type checks.
* configure.ac: Use rtems_cv_HAS_NETWORKING instead of
HAS_NETWORKING.
* aclocal/check-itron.m4: Integrate ITRON-type checks.
* configure.ac: Remove ITRON-type checks.
Move RTEMS_CHECK* after type-checks.
* configure.ac: Remove $LIBRPC.
* configure.ac: Check for uint64_t, int64_t.
* configure.ac, Makefile.am, configure.ac, ftpd/Makefile.am,
httpd/Makefile.am, libnetworking/Makefile.am, pppd/Makefile.am,
telnetd/Makefile.am, wrapup/Makefile.am: Replace
AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING).
* score/inline/rtems/score/object.inl, score/src/objectnametoid.c:
Properly honor searching only local node even when on single CPU
system.
* score/src/coresemseize.c: Add missing ISR enable.
* score/src/heapwalk.c: Use printk not printf.
* libmisc/rtmonuse/rtmonuse.c: Do not use float for calculations.
* libcsupport/src/sync.c: Do not dereference NULL reent.
* posix/src/semtimedwait.c: Used wrong constant for blocking with bad
timeout value.
* posix/src/semtimedwait.c: Reverse accidentally included
semtimedwait.c.
* posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/semtimedwait.c: Correct indexing of key data to use api and
index NOT class and index. Class is always 1.
* configure.ac: Suppress itron if int8/int16_t are not provided.
* configure.ac, Makefile.am, itron/Makefile.am, wrapup/Makefile.am:
Introduce AM_CONDITIONAL(LIBITRON).
Remove AM_CONDITIONAL(HAS_ITRON).
* wrapup/Makefile.am: Introduce AM_CONDITIONAL(LIBDOSFS).
* configure.ac, Makefile.am, libfs/Makefile.am:
* rtems/score/types.h: Remove unsigned64, signed64.
* libnetworking/libc/gethostbydns.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c: Cosmetic updates from FreeBSD.
Eliminate bcopy in favor of memcpy.
* libnetworking/rtems/rtems_bsdnet_internal.h: Add timeout() define.
* libnetworking/rtems/rtems_glue.c: Rename timeout() into
rtems_bsdnet_timeout().
* libnetworking/sys/malloc.h: Remove contigmalloc (non-implemented).
Remove __P-guards from malloc, free.
* sapi/src/io.c: Fix spacing.
* sapi/include/confdefs.h: Enable memory for new objects.
* posix/Makefile.am: Add file missed in previous commit.
* posix/src/posixtimespecabsolutetimeout.c: New file.
* configure.ac: Remove RTEMS_AMPOLISH3.
Add checks for uint8_t, int8_t, uint16_t, int16_t,
uint32_t, int32_t.
* aclocal/rtems-ampolish.m4: Pick up ampolish3 from ac_aux_dir.
* aclocal/rtems-top.m4: Add RTEMS_AMPOLISH3.
* ampolish3: Remove.
Add checks for uint8_t, int8_t, uint16_t, int16_t, uint32_t, int32_t.
* score/inline/rtems/score/threadq.inl, score/src/corerwlocktimeout.c:
New files.
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h,
sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/threadq.h,
score/src/corerwlockobtainread.c, score/src/threadqenqueue.c,
score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/src/pbarrier.c, posix/src/pbarrierdestroy.c,
posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c,
posix/src/pbarrierwait.c, posix/src/prwlock.c,
posix/src/prwlockdestroy.c, posix/src/prwlockinit.c,
posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspin.c,
posix/src/pspindestroy.c, posix/src/pspininit.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
* cpu_asm.S: Properly support synchronous traps.
