* rtems/src/rtemsobjectgetname.c:
Include <rtems/rtems/object.h> (Missing prototype).
* sapi/src/getversionstring.c: Include <rtems.h> (Missing prototype).
* libcsupport/src/termios.c: Make rtems_termios_refill_transmitter
static.
PR 1981/cpukit
* posix/Makefile.am: Reflect changes below.
* posix/src/pthreadsetcputime.c, posix/src/pthreadgetcputime.c:
Remove (Obsolete).
* ftpd/ftpd.c: Make split_command static.
* libnetworking/rtems/rtems_dhcp.c:
Make format_ip, dhcp_init static.
* libnetworking/nfs/bootp_subr.c:
Make bootp_strdup_realloc static.
* rtems/src/rtemsobjectapiminimumclass.c:
Adjust rtems_object_api_minimum_class to prototype.
* libcsupport/src/sup_fs_is_separator.c:
Include <rtems/libio_.h> (Missing protypes).
* rtems/src/workspace.c:
Include <rtems/rtems/support.h> (Missing prototypes).
PR 1983/networking
* libnetworking/libc/gethostbyht.c (gethostent_r):
Abort if (!hostf).
* libnetworking/libc/ns_parse.c (ns_parserr):
Comment out if ( section < 0 ) (type is unsigned).
* libnetworking/libc/gethostbydns.c: Comment out __dns_getanswer
(Unused).
* rtems/src/ratemonperiod.c: Make _Rate_monotonic_Update_statistics
static.
* libcsupport/src/pipe.c: Include <unistd.h>.
Include <rtems/pipe.h>.
* libmisc/stackchk/check.c: Make Stack_check_Initialize,
Stack_check_Dump_threads_usage static.
* libfs/src/pipe/pipe.c: Include <rtems/pipe.h> (Missing prototype).
* score/src/heapiterate.c, score/src/pheapiterate.c: New files.
* score/Makefile.am: Reflect changes above.
* score/include/rtems/score/heap.h: Declare _Heap_Iterate() and define
Heap_Block_visitor.
* score/include/rtems/score/protectedheap.h: Declare
_Protected_heap_Iterate().
* score/src/heapgetinfo.c: Use _Heap_Iterate().
* rtems/powerpc/registers.h: More register defines.
* libcsupport/src/flockfile.c, libcsupport/src/ftrylockfile.c,
libcsupport/src/funlockfile.c:
Add __attribute__((unused)) to unused function parameters.
* libcsupport/src/envlock.c: Build conditionally.
* configure.ac: Check for envlock.h.
Check for decls of __env_lock, __env_unlock.
* libcsupport/src/envlock.c: Rename define ENVLOCK_DEDIDCATED_MUTEX
into ENVLOCK_DEDICATED_MUTEX (Typo).
* libmisc/serdbg/serdbg.h: Add serdbg_init_dbg.
* libmisc/serdbg/serdbgcnf.h:
Remove conditional serdbg_init_dbg prototype.
* libmisc/mouse/serial_mouse.c: Make serial_mouse_l_rint static.
* libcsupport/src/malloc_sbrk_helpers.c: Make
malloc_sbrk_initialize, malloc_sbrk_extend_and_allocate static.
* libmisc/monitor/mon-network.c: Include <rtems/monitor.h>.
* libmisc/monitor/mon-object.c:
Make rtems_monitor_object_canonical_next_remote,
rtems_monitor_object_dump_1, rtems_monitor_object_dump_all static.
* libmisc/monitor/mon-prmisc.c:
Make rtems_monitor_dump_assoc_bitfield static.
* libmisc/monitor/mon-symbols.c:
Make rtems_monitor_symbol_dump_all static.
* score/src/schedulercbsattachthread.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbssetparameters.c:
Remove checks for server_id < 0 (server_id is unsigned).
* posix/src/pspinlocktranslatereturncode.c:
Include <rtems/posix/spinlock.h> (Missing prototypes).
* libfs/src/imfs/imfs_debug.c: Make IMFS_print_jnode,
IMFS_dump_directory static.
* libfs/src/imfs/memfile.c: Make memfile_free_blocks_in_table static.
* libcsupport/include/rtems/libio.h:
Make LIBIO_FLAGS_* defined unsigned (Avoid implicit sign
conversions).
* libmisc/capture/capture.c:
Make RTEMS_CAPTURE_* defines unsigned (Avoid implicit
sign-conversions).
Make rtems_capture_trigger static (Missing prototypes).
* libmisc/capture/capture.h:
Make RTEMS_CAPTURE_WATCH, RTEMS_CAPTURE_TRACED unsigned (Avoid
implicit sign conversions).
* rtems/src/rtemsobjectapimaximumclass.c:
Include <rtems/rtems/object.h> (Missing prototypes).
* sapi/src/exshutdown.c:
Include <rtems/init.h> (Missing prototypes).
* libmisc/mouse/mouse_parser.c: Make MOU_Data static.
* libcsupport/src/chown.c, libcsupport/src/lchown.c:
Include <unistd.h>. Cleanup included headers.
* posix/include/rtems/posix/pthread.h:
Add _POSIX_Threads_Initialize_user_threads_body.
* rtems/include/rtems/rtems/tasks.h:
Add _RTEMS_tasks_Initialize_user_tasks_body.
* sapi/include/confdefs.h: Remove conditional, nested redeclaration of
_POSIX_Threads_Initialize_user_threads_body,
* libmisc/shell/shell.h: Add rtems_shell_main_monitor.
* libmisc/shell/cmds.c: Make rtems_shell_main_monitor non-static.
* rtems/src/tasks.c: Fix typos.
* rtems/src/taskinitusers.c: Fix typos.
* posix/src/pthread.c: Fix typos.
* posix/src/pthreadinitthreads.c: Fix typos.
* rtems/include/rtems/rtems/tasks.h: Typo fixes.
* posix/src/pthreadatfork.c:
Include <pthread.h> (Missing prototypes).
* posix/src/mqueuetranslatereturncode.c:
Include <rtems/posix/mqueue.h> (Missing prototypes).
* posix/src/mutextranslatereturncode.c:
Include <rtems/posix/mutex.h> (Missing prototypes).
* posix/src/semaphoretranslatereturncode.c:
Include <rtems/posix/semaphore.h> (Missing prototypes).
* posix/src/mqueuenotify.c: Make _POSIX_Message_queue_Notify_handler
static.
* posix/src/fork.c: Include <unistd.h> for "fork" prototype.
Don't include <sys/types.h> (unnecessary).
* libcsupport/src/termios.c: Remove unnecessary cast.
* libmisc/shell/main_mv.c: Add prototype for main_mv.
* libmisc/shell/main_cp.c: Include "internal.h".
Make rtems_shell_main_cp non-static.
