* rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
* shell/shell.c: #include <time.h>
* wrapup/Makefile.am: Eliminate LIBNAME.
* rtems.adb (IO_Initialize): Make this match the C prototype.
* src/io.c: Fixed some spacing.
* score/include/Makefile.am: Remove cpuopt.h generation.
* configure.ac: Correct package name.
Don't build ada if POSIX is disabled.
Generate cpuopt.h on the fly, filter out autoconf-2.53 PACKAGE crap.
* rtems.ads: Corrected binding for Io_Initialize.
* cpu_asm.S: More PR267 tinkering which eliminates some conditional
compilation.
* configure.ac: New.
* Makefile.am: New.
* .cvsignore: New.
* aclocal/prog-gnat.m4: New.
* configure.ac: Add ada subdir handling.
* src/adjtime.c: New file -- adjtime() support required by the
Network Time Protocol (NTP) port to RTEMS.
* src/Makefile.am: Modified to reflect above.
* aclocal/bsp-alias.m4: Remove.
* src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h>
to avoid warning on ntohl().
* rtems/rtems_glue.c: Per PR270, the BSD network code expects that
the value of the number of seconds since boot is non-zero. The
RTEMS network initialization code assures this by waiting for a
second. A more efficient technique is to simply wait until the
* macros/rtems/score/coremsg.inl: Add <string.h> to remove warning.
* src/threadidlebody.c: Add return 0 to avoid warning.
* cpu_asm.S: Per PR267, the _ISR_Handler() function never was modifying
_ISR_Nest_level, and _Watchdog_Insert() requires this variable
to be modified to determine if an interrupt may have modified
the watchdog chain. Prior to modifying _ISR_Handler(), I had
a test that would fail if _ISR_Flash was not commented out in
_Watchdog_Insert(). After this modification was made, my test
ran flawlessly.
* cpu_asm.S: Clarified some comments, removed code that forced
SR_IEP on when returning from an interrupt.
* rtems_servers/ftpd.c: Remove unused variable buf.
* pppd/md5.c: #include <string.h> to make gcc31 happy.
* rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy.
* rtems_webserver/webmain.c: Remove unused variable dir, cp.
* src/write.c (_write_r): Change prototype to match newlib's reent.h.
* pppd/utils.c: Include i960 in varargs conditional to avoid error.
* pppd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o.
* capture/Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Use .$(OBJEXT) instead of .o.
* dummy/Makefile.am: Use .$(OBJEXT) instead of .o.
* dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o.
* monitor/Makefile.am: Use .$(OBJEXT) instead of .o.
* mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* serdbg/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Use .$(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use .$(OBJEXT) instead of .o.
* untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31
warnings about abort/exit).
* src/cancelrun.c: Remove check for PTHREAD_CANCELED not being defined
to ensure that newlib patch includes it.
* libc/getservent.c: Per PR265, add #include <netinet/in.h> for
ntohl() function.
* shell/Makefile.am: Remove shell.h from EXTRA_DIST.
* setup.def, binutils/base-binutils.add, binutils/target-binutils.add:
Updated to binutils 2.13 which has no known issues.
* cpu.c: Move pointer into #ifdef to avoid compiler warning.
* aclocal/version.m4: Updated to rtems-ss-20020807.
* netinet/in.h: Per PR263, added include of <machine/endian.h>
to <netinet/in.h> so it includes prototypes of ntohl() family
of routines.
* src/coretodset.c: Correct calculation of ticks until next section
boundary. It was incorrectly based upon current time not the
time that is being set.
* configure.ac: Add missing ',' to librpc activation.
Add AC_MSG_CHECKING/AC_MSG_RESULT.
* aclocal/check-networking.m4: Let AC_MSG_CHECKING refer to CPU.
* configure.ac: Fix bug in librpc activation, having introduced by
yesterday's patch.
* configure.ac: or32 does not currently support librpc.
* asm.h, rtems/score/cpu.h: Correct items that have changed since
RTEMS version or32 port was based upon.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CONFIG_PER_BSP.
* aclocal/env-rtemscpu.m4: Remove RTEMS_CONFIG_PER_BSP.
Use AS_IF instead of if/then/else/fi.
* rtems/score/cpu.h, rtems/score/types.h: Updated to fix some typos.
* asm.h, cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/or32.h,
rtems/score/types.h: Merged from OpenCores CVS repository.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* memcpy.c: Moved to libcpu.
* Makefile.am: Modified to reflect above.
* machine/param.h, sys/syslimits.h: In the continued effort to
eliminate .h conflicts between newlib and RTEMS, these were moved to
newlib.
* machine/Makefile.am, sys/Makefile.am: Reflect above.
* cpuuse/cpuuse.c (CPU_usage_Dump) : Corrected so it honors when an
object name is raw versus being a string.
* wrapup/Makefile.am: Don't install.
* wrapup/Makefile.am: Use librtems.a.
* wrapup/Makefile.am: Use libsapi.a.
* src/Makefile.am: Add librtems.a.
* src/Makefile.am: Add libsrtems.a.
* wrapup/Makefile.am: Use libscore.a.
* src/Makefile.am: Build into libscore.a.
* aclocal/canonicalize-tools.m4: Remove LD.
* automake/lib.am: Remove LD.
* Makefile.am: Put preinstall-stamp into CLEANFILES.
* aclocal/rtems-top.m4: Use with_project_root and MULTIBUILDTOP to
compose PROJECT_TOPdir (Fixes hppa1.1/genoffset problem).
