The following were not used in any code:
__RTEMS_USE_TICKS_CPU_USAGE_STATISTICS__
__RTEMS_USE_TICKS_RATE_MONOTONIC_STATISTICS__
Both CPU Usage and Rate Monotonic Period Statistics are switched
to ticks resolution by configuring with __RTEMS_USE_TICKS_FOR_STATISTICS__
set to 1 on the configure command line.
It is not so easy to use Termios for that. We already map CRNUL to CR,
thus we cannot ignore CRs. We could change the shell code to map CRNL
to a single line end, but this is more intrusive than the change here.
The standard line editor rtems_shell_line_editor() produces an echo.
This code was reviewed as part of coverage analysis improvements. The
uncovered range had unclear documentation and the code itself was also
cleaned up to be easier to understand.
Author: Krzysztof Mięsowicz <krzysztof.miesowicz@gmail.com>
This reduces code size and provides a function similar to fputc().
Due to the fact that CBS extends the EDF scheduler, most parts of EDF are
reused. One part is the allocation of the per-thread data. However, the CBS
per-thread structure defines a further element (while including the rest of
Scheduler_EDF_Per_thread)
This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
Update to Mongoose Mercurial revision 268:38a02c8a6744 available at:
https://code.google.com/p/mongoose/
In case the read-ahead task is not configured we must not send a wake-up
event. This would send the wake-up event to the executing task.
We must send the wake-up event only in case the request list changes
from empty to non-empty. Since otherwise we may send a false transfer
event.
In case the read-ahead task has a higher priority than the reading task,
this ensures that the read-ahead request is issued after the read miss
is serviced.
The previous version was sub-optimal for read-ahead transfer counts of
one.
The 64-bit timestamps were introduced to simplify the timestamp
calculations. This works well since nearly all operations are
additions. The previous _TOD_Tickle_ticks() implementation had a
serious performance regression in case of 64-bit timestamps due to the
usage of two 64-bit divisions which are quite expensive on some
architectures.
A new field seconds_trigger in TOD_Control is introduced to trigger the
_Watchdog_Tickle_seconds() in _TOD_Tickle_ticks(). This avoids the
64-bit divisions completely and only 32-bit additions are used.
Group the global TOD variables (_TOD_Now, _TOD_Uptime, and _TOD_Is_set)
in a structure to reduce address loads in _TOD_Tickle_ticks().
Add nanoseconds_per_tick to rtems_configuration_table. This value will
be derived from the microseconds_per_tick value. This avoids some
calculations at run-time.
This allows addtion of per disk statistics for example.
Port
+ v850 does not have appear to have any optimized bit scan instructions
+ v850 does have single instructions for wap u16 and u32
+ Code path optimization preferences set
+ Add BSP variants for each GCC CPU model flag and a README
- v850e1 variant does not work (fails during BSP initialization)
BSP for GDB v850 Simulator
+ linkcmds matches defaults in GDB simulator with RTEMS mods
+ crt1.c added from v850 newlib port for __main()
+ BSP exits cleanly
+ printk and console I/O work
+ uses clock tick from IDLE task
+ Tests not requiring real clock ISR work
Documentation
+ CPU Supplment chapter for v850 added
_CPU_ISR_Initialize
The XDR library has a problem on architectures with short enums like the
default ARM EABI. Short enums means that the size of the enum type is
variable and the smallest integer type to hold all enum values will be
selected. For many enums this is char. The XDR library uses int32_t
for enum_t. There are several evil casts from an enum type to enum_t
which leads to invalid memory accesses on short enum architectures. A
workaround is to add appropriate dummy enum values.
The file size was wrong in the no space left on device condition. This
resulted in turn in a read of an invalid block which lead to an EIO
error status.
Read-ahead requests were previously executed in the context of the
reading task. This blocks the reading task until the complete read
with read-ahead transfer is finished. A read-ahead task is introduced
to off-load the read-ahead transfer. This allows the reading task to
work with the requested block more quickly. The read-ahead is triggered
after two misses of ascending consecutive blocks or a read hit of a
block read by the most-recent read-ahead transfer. The read-ahead
feature is configurable and can be disabled.
