Update #3943.
Update #4018.
This introduces the CPU_USE_LIBC_INIT_FINI_ARRAY define for use by CPU
ports to determine which global constructor and destructor methods are
used instead of placing architecture defines where they shouldn't be.
Close #4018
Update #4020.
Some objects can be created with a local or global scope in a
multiprocessing network. In non-multiprocessing configurations setting
the scope to local or global had no effect since such a system can be
viewed as a multiprocessing network with just one node. One and all
nodes is the same in such a network. However, if multiprocessing was
configured, creation of a global object in a single node network
resulted in an RTEMS_MP_NOT_CONFIGURED error. Remove this error
condition for symmetry to the non-multiprocessing setup. This is in line
with the task affinity behaviour in SMP systems.
Update #4005.
- Defines CPU_Interrupt_frame in cpu_impl.h
- Updates isq_asm.S to save/restore registers in matching order to
interrupt frame
Uses similar flow in cpu_asm.S for i386 as for arm.
Create a GS segment in the GDT for each processor for storing TLS.
This makes the GDT in startAP.S obsolete as all processors now share the
same GDT, which is passed to each AP at startup.
The correct segment for each processor is calculated in cpu_asm.S.
Update #3335
Store the stack pointer of the exception context to the exception frame.
Close #3987.
This is in line with pthread_setschedparam() and
pthread_getschedparam().
Update #2514.
Merge the rtems_termios_isig_status_code and
rtems_termios_iproc_status_code enums into a single
rtems_termios_iproc_status_code which is now a part of the API.
Simplify rtems_termios_posix_isig_handler() to avoid unreachable code.
Close #3800.
Use with the trace outout to check for allocation leaks.
Add the _Copyright_Notice to a special linker set to prevent a garbage
collection of this item.
Close #3973.
Update #3973.
Close #3972.
This define is
* not documented,
* not used in the RTEMS code base, and
* longer than sizeof(rtems_name).
Close #3971.
Close #3970.
Update #3970.
- The change from bool to an enum did not trip a compiler warning
and only the rel path was changed. The rela path was missed so
archs like SPARC failed.
Updates #3969
Updates #3969
- The check was for greater than and not equal or greater
Updates #3969
Updates #3969
Updates #3969
Updates #3969
This patch is an updated version from:
https://lists.rtems.org/pipermail/users/2016-January/029740.html
Closes #3693
Check that the extensions table is not NULL. Change format.
Update #3953.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
- Fix the passing of std[in/out] to child threads
- Fix deleting of managed memory in the key destructor
- Only set the key in the main loop thread
- Only allocate a shell env outside of the main loop
- Fix memory leak if the task start fails
- Remove error level from shell env, it cannot be returned this way. Add
exit_code but the API is broken so it cannot be returned.
Closes #3859
Update #3875.
Close #3949.
Update #3949.
Delete unused RTEMS_DECLARE_GLOBAL_SYMBOL().
Update #3799.
In the previous implementation, the _ISR_Stack_area_begin and
_ISR_Stack_area_end symbols were in different sections. If they do not
have the same alignment, then the following linker directive could
separate them:
*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
Do not use different sections and instead define _ISR_Stack_area_end
directly.
Update #3799.
Update #3799.
This reverts commit 8e80876bdd54e36fb668eee655eec1dd588daf13
which broke several architectures.
The _ISR_Stack_area_begin and _ISR_Stack_area_end symbols are in
different sections. They must have the same alignment, otherwise the
following linker directive could separate them:
Update #3799.
Statically initialize the ARMv7-M vector table to allow a placement in
ROM with read-only MPU settings.
Change licence to BSD-2-Clause in some files.
Remove the following undocumented configuration options:
* CONFIGURE_FILESYSTEM_ENTRY_DOSFS
* CONFIGURE_FILESYSTEM_ENTRY_FTPFS
* CONFIGURE_FILESYSTEM_ENTRY_IMFS
* CONFIGURE_FILESYSTEM_ENTRY_JFFS2
* CONFIGURE_FILESYSTEM_ENTRY_NFS
* CONFIGURE_FILESYSTEM_ENTRY_RFS
* CONFIGURE_FILESYSTEM_ENTRY_TFTPFS
Update #3836.
This type is unused. Do not mention non-existing
CONFIGURE_FILESYSTEM_MINIIMFS.
This filesystem no longer exists.
Remove unused RTEMS_FILESYSTEM_TYPE_DEVFS.
Update #3894.
These defines are not used and easily conflict with application code.
They are also defined by the standard header file <arpa/ftp.h> if
someone needs them.
Do not undefine this unused BSP configuration option. This is a follow
up of commit 92b33b8d09377feb14eb5a831ce242047c58d02b.
On most architectures, the size of the thread-local storage TCB must be
8 bytes. Fix the definition for 64-bit targets.
