* rtems/score/cpu.h: Increase default stack size on i386 from 1K to 4K.
Most i386 targets are not memory strapped so making this a bit large
is not a burden. It lets more tests run. ticker and psxtimer will not
even run with 1K of stack.
* posix/inline/rtems/posix/cond.inl, posix/macros/rtems/posix/cond.inl,
posix/src/conddestroy.c: Remove warnings.
* rtems/src/tasks.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c: Remove
warnings.
* posix/include/intr.h, posix/include/rtems/posix/intr.h
posix/inline/rtems/posix/intr.inl.
posix/macros/rtems/posix/intr.inl, posix/src/intr.c:
Remove (Unused, dead).
* posix/Makefile.am: Reflect changes above. Rework.
* posix/Makefile.am: Build devctl.
* rtems/Makefile.am: Rework.
* score/Makefile.am: Rework.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
* rtems/asm.h, rtems/score/cpu.h, rtems/score/types.h: Part of a large
* Makefile.am: Remove doxygen support having accidentially slipped
into, though yesterday's patch.
* Makefile.am, ftpd/Makefile.am, httpd/Makefile.am,
itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am,
libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am,
librpc/Makefile.am, posix/Makefile.am, pppd/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am,
score/cpu/arm/Makefile.am, score/cpu/avr/Makefile.am,
score/cpu/c4x/Makefile.am, score/cpu/h8300/Makefile.am,
score/cpu/i386/Makefile.am, score/cpu/m68k/Makefile.am,
score/cpu/mips/Makefile.am, score/cpu/no_cpu/Makefile.am,
score/cpu/powerpc/Makefile.am, score/cpu/sh/Makefile.am,
score/cpu/sparc/Makefile.am, score/cpu/unix/Makefile.am,
telnetd/Makefile.am, zlib/Makefile.am: Remove all-local:.
* rtems/score/types.h: Eliminate unsigned16.
* libcsupport/src/error.c: include and use inttypes.h.
* libnetworking/rtems/rtems_mii_ioctl.h: Fix formatting.
* libcsupport/src/unixlibc.c, libfs/src/imfs/ioman.c: Change
rtems_io_register_name to take a const char *.
* sapi/include/rtems/io.h, sapi/src/io.c: Change rtems_io_register_name
which included commits to RCS files with non-trunk default branches.
* ChangeLog: fixed wrong date of last ChangeLog entry.
PR 849/networking
* librpc/src/rpc/rtems_portmapper.c: Increased stack size
by ARGSIZE to prevent overrun.
* configure.ac: New header guard for cpuopts.h.
* rtems/score/cpu.h: Eliminate use of unsigned32.
* libnetworking/rtems/rtems_mii_ioctl.h: Reflect mii.h and
if_media.h having moved.
* libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h:
New (Moved from c/src/libchip).
* libnetworking/Makefile.am: Re-add rtems/rtems_mii_ioctl.h,
rtems/rtems_mii_ioctl.c, rtems/rtems_mii_ioctl_kern.c.
Add dev/mii/mii.h, net/if_media.h (Moved from c/src/libchip).
* automake/local.am: Remove depend.
