Update #3875.
Close #3949.
Update #3949.
Delete unused RTEMS_DECLARE_GLOBAL_SYMBOL().
Update #3799.
In the previous implementation, the _ISR_Stack_area_begin and
_ISR_Stack_area_end symbols were in different sections. If they do not
have the same alignment, then the following linker directive could
separate them:
*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
Do not use different sections and instead define _ISR_Stack_area_end
directly.
Update #3799.
Update #3799.
This reverts commit 8e80876bdd54e36fb668eee655eec1dd588daf13
which broke several architectures.
The _ISR_Stack_area_begin and _ISR_Stack_area_end symbols are in
different sections. They must have the same alignment, otherwise the
following linker directive could separate them:
Update #3799.
Statically initialize the ARMv7-M vector table to allow a placement in
ROM with read-only MPU settings.
Change licence to BSD-2-Clause in some files.
Remove the following undocumented configuration options:
* CONFIGURE_FILESYSTEM_ENTRY_DOSFS
* CONFIGURE_FILESYSTEM_ENTRY_FTPFS
* CONFIGURE_FILESYSTEM_ENTRY_IMFS
* CONFIGURE_FILESYSTEM_ENTRY_JFFS2
* CONFIGURE_FILESYSTEM_ENTRY_NFS
* CONFIGURE_FILESYSTEM_ENTRY_RFS
* CONFIGURE_FILESYSTEM_ENTRY_TFTPFS
Update #3836.
This type is unused. Do not mention non-existing
CONFIGURE_FILESYSTEM_MINIIMFS.
This filesystem no longer exists.
Remove unused RTEMS_FILESYSTEM_TYPE_DEVFS.
Update #3894.
These defines are not used and easily conflict with application code.
They are also defined by the standard header file <arpa/ftp.h> if
someone needs them.
Do not undefine this unused BSP configuration option. This is a follow
up of commit 92b33b8d09377feb14eb5a831ce242047c58d02b.
On most architectures, the size of the thread-local storage TCB must be
8 bytes. Fix the definition for 64-bit targets.
Check for configuration errors earlier. Allow fatal dumps without the
other extensions. Add some warnings.
Update #3904.
Add rtems_record_dump_base64() and rtems_record_dump_base64_zlib().
Add CONFIGURE_RECORD_FATAL_DUMP_BASE64 and
CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB configuration options.
Update #3904.
Update #3904.
Update #3904.
There was a race conditon in the reference counting of file descriptors
during a close() operation. After the call to the close handler, the
rtems_libio_free() function cleared the flags to zero. However, at this
point in time there may still exist some holders of the file descriptor.
With RTEMS_DEBUG enabled this could lead to failed assertions in
rtems_libio_iop_drop().
Change the code to use only atomic read-modify-write operations on the
rtems_libio_iop::flags.
Add a simplified path evaluation function IMFS_eval_path_devfs() for a
device only IMFS configuration.
The code size can be further reduced by the application if it disables
the support for legacy IO drivers via:
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES.
Update #3894.
Update #3898.
Update #3894.
Update #3894.
The CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK value is validated by
<rtems/confdefs/libio.h>. Changing this value during runtime could lead
to memory corruption.
Update #3894.
Update #3894.
Change license to BSD-2-Clause according to file history.
Update #3053.
Update #3894.
Update #3053.
Update #3894.
Update #3894.
Update #3894.
Remove IMFS_NODE_FLAG_NAME_ALLOCATED and instead replace the node
control in rename operations. This avoids a special case in the general
node destruction which pulled in free().
Update #3894.
In uniprocessor configurations, use compile-time constants for
rtems_scheduler_get_processor_maximum() and
rtems_scheduler_get_processor(). This helps compilers and static
analyzers to deduce that some loop bodies are only executed once and
some conditional statements have a fixed outcome (may improve code
generation and reduce false positives).
In SMP configurations, directly provide the internal implementation for
performance reasons.
The use of CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER does not define
anything, so remove the <rtems/btimer.h> include.
Update #3875.
Update #3881.
Update #3881.
This function is used to perform a full check of the device tree. Allow
it to be excluded if all assumptions are enabled.
Signed-off-by: Simon Glass <sjg@chromium.org>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Message-Id: <20200220214557.176528-9-sjg@chromium.org>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Add a way to remove this check and the reordering code, which is
unnecessary if the dtb is known to be correctly ordered.
Message-Id: <20200220214557.176528-8-sjg@chromium.org>
Allow enabling FDT_ASSUME_LATEST to disable version checks.
Message-Id: <20200220214557.176528-7-sjg@chromium.org>
Allow enabling FDT_ASSUME_NO_ROLLBACK to disable rolling back after a
failed operation.
Message-Id: <20200220214557.176528-6-sjg@chromium.org>
Allow enabling ASSUME_VALID_INPUT to disable sanity checks on the device
tree and the parameters to libfdt. This assumption covers that cases where
the problem could be with either.
Message-Id: <20200220214557.176528-5-sjg@chromium.org>
Support ASSUME_VALID_DTB to disable some sanity checks
If we assume that the DTB itself is valid then we can skip some checks and
save code space. Add various conditions to handle this.
Message-Id: <20200220214557.176528-4-sjg@chromium.org>
Add a new ASSUME_MASK option, which allows for some control over the
checks used in libfdt. With all assumptions enabled, libfdt assumes that
the input data and parameters are all correct and that internal errors
cannot happen.
By default no assumptions are made and all checks are enabled.
Message-Id: <20200220214557.176528-3-sjg@chromium.org>
There does not seem to be a strong reason to inline this function. Also
we are about to add some extra code to it which will increase its size.
Move it into fdt.c and use a simple declaration in libfdt.h
Message-Id: <20200220214557.176528-2-sjg@chromium.org>
This function returns an int32_t, however the prototype in
libfdt_internal.h shows it returning an int. We haven't caught this before
because they're the same type on nearly all platforms this gets built on.
Apparently it's not the case on FreeRTOS, so someone hit this mismatch
building for that platform.
Reported-by: dharani kumar <dharanikumarsrvn@gmail.com>
Including libfdt.h in a C++ project fails during compilation with recent
version of GCC or Clang.
This simple example:
extern "C" {
#include <libfdt.h>
int main(void) { return 0; }
leads to the following errors with GCC 9.1.0:
/usr/include/libfdt.h: In function ‘void fdt32_st(void*, uint32_t)’:
/usr/include/libfdt.h:139:16: error: invalid conversion from ‘void*’ to ‘uint8_t*’ {aka ‘unsigned char*’} [-fpermissive]
139 | uint8_t *bp = property;
| void*
/usr/include/libfdt.h: In function ‘void fdt64_st(void*, uint64_t)’:
/usr/include/libfdt.h:163:16: error: invalid conversion from ‘void*’ to ‘uint8_t*’ {aka ‘unsigned char*’} [-fpermissive]
163 | uint8_t *bp = property;
| void*
This commit adds an explicit cast to uint8_t* to fix this issue.
Signed-off-by: Luc Michel <luc.michel@greensocs.com>
Message-Id: <20190910104824.1321594-1-luc.michel@greensocs.com>
