* | | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-28 | 1 | -0/+5 | |
| | | | | | | | | | | * zconf.h: Use uint_least*_t types. * crc32.c, zutil.c, zutil.h: Misc. type fixes. | |||||
* | | Misc. type fixes | Ralf Corsepius | 2005-10-28 | 3 | -9/+9 | |
* | | Use uint_least*_t types. | Ralf Corsepius | 2005-10-28 | 1 | -0/+9 | |
| | | | | | | | | | | * Makefile.am: New. * preinstall.am: New. | |||||
* | | New. | Ralf Corsepius | 2005-10-28 | 2 | -0/+72 | |
* | | * adler32.c, compress.c, crc32.c, deflate.c, deflate.h, gzio.c, | Ralf Corsepius | 2005-10-28 | 1 | -0/+6 | |
| | | | | | | | | | | trees.c, uncompr.c, zconf.h, zconf.in.h, zutil.c, zutil.h: Reformat CVS Ids. | |||||
* | | Reformat CVS Ids | Ralf Corsepius | 2005-10-28 | 12 | -12/+12 | |
* | | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-28 | 1 | -0/+9 | |
| | | | | | | | | | | | | | | | | | | * ChangeLog.zlib: Renamed version of zlib's ChangeLog. * FAQ, INDEX, README, adler32.c, algorithm.txt, compress.c, crc32.c, crc32.h, deflate.c, deflate.h, gzio.c, infback.c, inffast.c, inffast.h, inffixed.h, inflate.c, inflate.h, trees.c, trees.h, uncompr.c, zconf.h, zconf.in.h, zlib.3, zlib.h, zutil.c, zutil.h, inftrees.h, inftrees.c, ChangeLog: Import from zlib-1.2.2.2.tar.gz. | |||||
* | | Remove. | Ralf Corsepius | 2005-10-28 | 5 | -1639/+0 | |
* | | Rename the original ChangeLog to ChangeLog.zlib | Ralf Corsepius | 2005-10-28 | 1 | -0/+0 | |
* | | Apply FC4's zlib-1.2.2.2-can-2005-2096.patch | Ralf Corsepius | 2005-10-28 | 1 | -1/+1 | |
* | | Apply FC4's zlib-1.2.2.2-can-2005-1849.patch | Ralf Corsepius | 2005-10-28 | 1 | -4/+4 | |
* | | Post-import cleanup | Ralf Corsepius | 2005-10-28 | 147 | -32362/+0 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12486, | Ralf Corsepius | 2005-10-28 | 1 | -9/+9 | |
|\| | | | | | which included commits to RCS files with non-trunk default branches. | |||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 1 | -9/+9 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12484, | Ralf Corsepius | 2005-10-28 | 3 | -7/+7 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 3 | -7/+7 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12482, | Ralf Corsepius | 2005-10-28 | 1 | -5/+5 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 1 | -5/+5 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12480, | Ralf Corsepius | 2005-10-28 | 1 | -2/+2 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 1 | -2/+2 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12478, | Ralf Corsepius | 2005-10-28 | 1 | -10/+10 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 1 | -10/+10 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12476, | Ralf Corsepius | 2005-10-28 | 1 | -9/+9 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12474, | Ralf Corsepius | 2005-10-28 | 2 | -13/+13 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 2 | -13/+13 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12472, | Ralf Corsepius | 2005-10-28 | 1 | -2/+2 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12470, | Ralf Corsepius | 2005-10-28 | 181 | -0/+46633 | |
| * | Import of zlib-1.2.2.2.tar.gz | Ralf Corsepius | 2005-10-28 | 181 | -0/+46633 | |
* | | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 1 | -0/+2 | |
| | | | | | | | | | | * libnetworking/net/zlib.h, libnetworking/net/zlib.c: Update from FreeBSD. | |||||
* | | Update from FreeBSD. | Ralf Corsepius | 2005-10-27 | 2 | -39/+58 | |
* | | Remove. | Ralf Corsepius | 2005-10-27 | 1 | -11/+0 | |
* | | * libnetworking/opt_ppp.h: New. | Ralf Corsepius | 2005-10-27 | 1 | -0/+5 | |
| | | | | | | | | | | | | | | * libnetworking/net/ppp.h: Remove. * libnetworking/net/if_ppp.c, libnetworking/net/ppp_tty.c: Reflect changes above. Cosmetics from FreeBSD. * libnetworking/Makefile.am: Add opt_ppp.h, remove net/ppp.h. | |||||
* | | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 2 | -21/+28 | |
| | | | | | | | | * libnetworking/Makefile.am: Don't install loop.h. | |||||
* | | New. | Ralf Corsepius | 2005-10-27 | 1 | -0/+11 | |
* | | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 1 | -0/+1 | |
* | | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 22 | -50/+66 | |
| | | | | | | | | | | * rtems/asm.h: Remove private version of CONCAT macros. Include <rtems/concat.h> instead. | |||||
* | | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 2 | -0/+7 | |
| | | | | | | | | * include/rtems/concat.h: Add EXPAND0, CONCAT0. | |||||
* | | Cosmetics. | Ralf Corsepius | 2005-10-27 | 1 | -2/+4 | |
* | | Regenerate. | Ralf Corsepius | 2005-10-27 | 1 | -0/+2 | |
* | | New. | Ralf Corsepius | 2005-10-27 | 1 | -0/+2 | |
* | | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 2 | -0/+6 | |
| | | | | | | | | * telnetd/Makefile.am: Only build if LIBSHELL is available. | |||||
* | | 2005-10-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-26 | 1 | -0/+5 | |
| | | | | | | | | | | * pppd/Makefile.am, pppd/auth.c, pppd/chap.c, pppd/md5.c, pppd/md5.h, pppd/pppd.h: Misc. minor fixes. | |||||
* | | Misc. minor fixes. | Ralf Corsepius | 2005-10-26 | 6 | -12/+14 | |
| | | | | | | | | | | * configure.ac: Add pppd. * Makefile.am: Add pppd. | |||||
* | | Add pppd. | Ralf Corsepius | 2005-10-26 | 2 | -0/+2 | |
* | | Regenerate | Ralf Corsepius | 2005-10-26 | 1 | -12/+24 | |
