In case the processor set is not large enough to contain the processor
affinity set of the task return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4393.
There is no need to disable thread dispatching to get the affinity of a
task.
This avoids having conditional statements to get the API-specific status
code.
Close #4392.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Since there are already excessive NULL pointer checks in the Classic
API, do this also in rtems_task_construct().
Update #3959.
API, do this also in rtems_message_queue_construct().
Update #4007.
A timer may be also reinitiated by the timer server fire directives.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
This patch fixes issue #4338 by changing _TOD_Validate()
to only accept years till 2105. This requires another patch
to change the documentation of rtems_clock_set() and other
affected API functions (indicating the end date is 2105 not 2514).
I tried to support till year 2514 but it turned out that
this needs changing the Timer Manager too. That in turn
would mean to change _TOD_Seconds_since_epoch( void )
from 32 to 64 bit. Sebastian pointed out that a naive extension
leads to trouble with 32 bit processors. He deemed a safe
re-implementation too costly performance wise considering
that year 2106 is far away and current binaries using RTEMS
Classic API are unlikely to be in use by 2106.
The constant TOD_SECONDS_AT_2100_03_01_00_00 in
cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by
1 hour. When setting the date 2100-Feb-28 23:59:59 and then
reading the date again you will find yourself in 2100-Feb-27.
Update #4338
The multiplication to calculate the length of the memory area to
allocate may overflow. Return NULL in case of an overflow.
Close #4389.
Move RTEMS_Malloc_Sbrk_amount to the only implementation file which uses
it and make it private to hide implementation-details from an API
header.
Move rtems_calloc() since it only depends on rtems_malloc(). This may
make it easier to customize the heap allocator.
Change licence to BSD-2-Clause according to file history.
Update #3053.
Last use was removed by:
commit 54550e048d3a49435912797d2024f80671e93267
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Fri May 13 08:16:30 2016 +0200
posix: Rework pthread_join()
Rework pthread_join() to use _Thread_Join().
The _CPU_ISR_Is_enabled() function operates on ISR cookies and so must
mask off the appropriate status bits. This also fixes the naming of the
parameters of the _CPU_ISR_* functions to indicate use of ISR cookies
instead of interrupt enable/disable levels.
This reverts commit 8383572963e261ea384cddfa43cd9606e7c23cdd.
This reverts commit 3299dda2454a8847c670a732f6c12ef1f2cc5dd0.
CID 1399751: Unused value in fastlz2_compress().
Closes #4341
CID 1255346: Unused value in rtems_shell_ls_printacol().
Closes #4340
CID 1255344: Unused value in copy().
Closes #4339
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
The directive returns RTEMS_UNSATISFIED if the semaphore's count already
had the maximum value of UINT32_MAX.
Replace Objects_Name_or_id_lookup_errors with new Status_Control codes.
Get rid of the _Status_Object_name_errors_to_status lookup table.
The value of STATUS_CLASSIC_INTERNAL_ERROR must be equal to
RTEMS_INTERNAL_ERROR. Add static assertions to ensure that the status
codes match.
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
At this point in time, /etc can be created in multiple ways. There
is a discussion (#4354) that would define a mechanism for
instantiating a base file system with some flexibility for the
set of directories included. For now, this particular mkdir()
call can fail because /etc could already have been created by
at least an initial filesystem image, the shell, or libbsd.
closes #4382.
This speeds up reading fragmented files.
Fix #3689
Adds a peek function that allows (for example) a file system to suggest
the next blocks that should be used for read ahead. This can increase
the read speed of fragmented files.
Update #3689
The patch was:
gen_uuid.c: Fix two Unchecked return value from library errors
CID 1049146: Unchecked return value from library in get_clock().
CID 1049147: Unchecked return value from library in get_random_fd().
Reopen #4280
Removed the _Assert_unused_variable_equals macro due to /etc
having already been created by the network stack initialization
or an initial filesystem image.
Closes #4282
The while loop, loops infinitely in case of raw FDT data.
The loop condition (size) is not modified during iterations.
Check only for invalid modes if a valid handler is presented to
rtems_signal_catch(). When NULL is used for the handler, ASR processing
is disabled and the mode is not used.
Update #4244.
Do the ASR and preemption mode change only if requested by the mode
mask. The bug was introduced by
508f868237225a75e566d9fd304206363cfe441d.
Do not mix checks for different error indicators (RTEMS_NOT_DEFINED and
RTEMS_INVALID_NUMBER). This simplifies the specification of
rtems_semaphore_create().
Rejecting initially locked MrsP semaphores was due to a limitiation of
the early limitiation of the MrsP protocol. This limitation no longer
exists.
