* | pointer arithmetic reworked to be more portable | Joel Sherrill | 1996-09-18 | 1 | -8/+8 |
* | casts added to numerous arguments, prototypes corrected, and | Joel Sherrill | 1996-09-18 | 10 | -22/+27 |
| | | | | proper include files added. | ||||
* | dummy function added to satisfy ANSI | Joel Sherrill | 1996-09-18 | 2 | -0/+20 |
* | modified to support non-GNU compilers and to use calloc rather than | Joel Sherrill | 1996-09-18 | 1 | -3/+20 |
| | | | | malloc for per-thread reentrancy structure allocation. | ||||
* | added malloc_walk | Joel Sherrill | 1996-09-18 | 1 | -4/+35 |
| | | | | miscellaneous corrections in casting. | ||||
* | added prototype for malloc_walk | Joel Sherrill | 1996-09-18 | 1 | -0/+1 |
* | loop to clear workspace memory changed to use sizeof rather than | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
| | | | | hardcoded 4 to be compatible with CPUs with 64-bit ints | ||||
* | corrected prototype of _Objects_Get_next | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
* | uses address object rather than direct pointer arithmetic | Joel Sherrill | 1996-09-18 | 1 | -2/+3 |
* | OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than | Joel Sherrill | 1996-09-18 | 1 | -2/+2 |
* | MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof | Joel Sherrill | 1996-09-18 | 1 | -1/+2 |
| | | | | rather than hardcoded 4 to be compatible with CPUs with 64-bit ints | ||||
* | modified declaration of CORE_message_queue_Buffer_control to avoid use | Joel Sherrill | 1996-09-18 | 1 | -11/+4 |
| | | | | of GNU C extension | ||||
* | corrected white space problems | Joel Sherrill | 1996-09-18 | 1 | -60/+62 |
| | | | | added CPU_STRUCTURE_ALIGNMENT to default context structures | ||||
* | new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 4 | -0/+1327 |
| | | | | (ostertag@transition.com). | ||||
* | Reversed logic in conditional to correctly distinguish between | Joel Sherrill | 1996-09-17 | 1 | -2/+2 |
| | | | | FIFO and priority disciplines. | ||||
* | added routine _POSIX_Timespec_subtract | Joel Sherrill | 1996-09-17 | 1 | -0/+31 |
* | Added code to insure that the post switch extension was executed and | Joel Sherrill | 1996-09-17 | 1 | -0/+5 |
| | | | | | | to made signals sent to a particular thread from an ISR operated correctly. This behavior was required by the exception detection/reporting code in the gnat runtime. | ||||
* | Corrected implementation of timed wait on condition variables. First | Joel Sherrill | 1996-09-17 | 1 | -29/+52 |
| | | | | | | | | the timeout is given as a wall-time not an interval as was previously implemented. Second, the interpretation of ETIMEDOUT behavior was incorrect as all possible error cases needed to be checked before this error was returned. This caused problems when the wall-time specified was in the past. | ||||
* | added prototype for _POSIX_Timespec_subtract | Joel Sherrill | 1996-09-17 | 1 | -0/+11 |
* | added $Id$ to file headers | Joel Sherrill | 1996-09-11 | 15 | -8/+15 |
| | | | | cpu.h: added prototype for _CPU_ISR_Get_level() | ||||
* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it would be | Joel Sherrill | 1996-09-08 | 1 | -1/+0 |
| | | | | visible to other files. | ||||
* | Ada task stack size minimize is twice that for regular pthreads. | Joel Sherrill | 1996-09-08 | 1 | -2/+2 |
* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be | Joel Sherrill | 1996-09-08 | 1 | -0/+2 |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 15 | -0/+5247 |
| | | | | Derrick Ostertag (ostertag@transition.com). | ||||
* | changed _TOD_Is_set from a function to a boolean variable | Joel Sherrill | 1996-09-06 | 7 | -29/+16 |
* | default thread attributes: default value for inheritsched changed from | Joel Sherrill | 1996-09-05 | 1 | -5/+25 |
| | | | | | | | | | | | | explicit to inherit scheduler to be consistent with FSU pthreads for gnat. _POSIX_Threads_Create_extension: now inherit signal blocked mask from creator if the new thread is a posix thread. _POSIX_Threads_Initialize_user_threads: make sure posix initialization threads start with a useful priority. If they inherit the priority of the creating thread, they will end up at the same priority as the idle thread. Since the idle thread does not yield, they will not run. | ||||
* | pthread_mutex_setprioceiling: fixed bug where returned priority was | Joel Sherrill | 1996-09-05 | 1 | -1/+3 |
| | | | | not converted from core priority to posix priority. | ||||
* | nanosleep: negative value for tv_sec is no longer an error. It now | Joel Sherrill | 1996-09-05 | 1 | -4/+10 |
| | | | | is changed into being a 0 delay. | ||||
* | new file to support GNU Ada. | Joel Sherrill | 1996-08-29 | 1 | -0/+28 |
| | | | | | currently the only routine in this file simply returns the minimum stack size for each thread. | ||||
* | fixed typo .. changed == to != | Joel Sherrill | 1996-08-27 | 1 | -1/+1 |
* | check that we were passed a valid mutex and ignore errors from the | Joel Sherrill | 1996-08-27 | 1 | -0/+8 |
| | | | | | later pthread_mutex_lock. This makes our behavior more compatible with that of FSU pthreads. | ||||
* | pthread_create: changed EINVAL for no more threads back to EAGAIN | Mark Johannes | 1996-08-23 | 1 | -20/+21 |
* | Changed all EFAULTs to EINVALs | Mark Johannes | 1996-08-19 | 1 | -7/+14 |
* | pthread_mutex_init: added error messages for NULL mutex and EBUSY | Mark Johannes | 1996-08-19 | 1 | -6/+22 |
* | updates from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-08-15 | 1 | -2/+4 |
* | _Thread_Start_multitasking: added code to initialize the floating point | Joel Sherrill | 1996-08-15 | 1 | -1/+25 |
| | | | | context of the first thread to execute. | ||||
* | changed ENOMEM error message | Mark Johannes | 1996-08-15 | 1 | -1/+4 |
* | clock_gettime: changed assert condition to a standard error code | Joel Sherrill | 1996-08-15 | 1 | -2/+3 |
| | | | | clock_getres: now checking for a null pointer being passed in | ||||
* | sched_rr_get_interval: converted assert condition into a standard error | Joel Sherrill | 1996-08-15 | 1 | -1/+5 |
| | | | | code and added check for a NULL interval being passed in. | ||||
* | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1996-08-15 | 1 | -0/+7 |
| | | | | condition variable | ||||
* | pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO | Mark Johannes | 1996-08-15 | 1 | -4/+6 |
* | pthread_kill: moved check for SA_SIGINFO to allow for validation of all | Mark Johannes | 1996-08-15 | 1 | -7/+7 |
| | | | | parameters. Also changed returns to macro of -1 and errno set. | ||||
* | fixed typo for NOTSUP -> ENOTSUP | Mark Johannes | 1996-08-15 | 1 | -13/+12 |
* | commented of ENOTSUP until fixed in newlib | Mark Johannes | 1996-08-14 | 1 | -0/+1 |
* | pthread_cond_timedwait: added error cases for abstime | Mark Johannes | 1996-08-14 | 1 | -0/+11 |
* | pthread_cond_destroy: added enable dispatch to EBUSY case | Mark Johannes | 1996-08-13 | 1 | -1/+3 |
* | pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First | Mark Johannes | 1996-08-13 | 1 | -3/+3 |
* | pthread_cond_destroy: EBUSY case now uses Thread_queue_First | Mark Johannes | 1996-08-13 | 1 | -1/+1 |
* | removed count from Thread_queue_Control | Mark Johannes | 1996-08-13 | 1 | -1/+0 |
* | removed Thread_queue_Get_number_waiting | Mark Johannes | 1996-08-13 | 2 | -25/+0 |
