* | Added per-task variable data stucture (rtems_task_variable_t), | Joel Sherrill | 1999-11-12 | 1 | -4/+36 | |
| | | | | | task_variables field to API extension, and two directives (rtems_task_variable_add and rtems_task_variable_delete). | |||||
* | Added per task variables based on patch from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-12 | 3 | -3/+222 | |
| | | | | | After being submitted, this support was rewritten to be inside the executive rather than layered on top of it using an extension. | |||||
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 1 | -243/+239 | |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 1 | -1/+0 | |
* | Corrected to account for the way memory is divided up in | Joel Sherrill | 1999-11-10 | 1 | -7/+9 | |
| | | | | | _Object_Extend_information. This change is a side-effect of the change made to that file to fix an alignment problem. | |||||
* | Added call to _Thread_Enable_dispatch() and did some cleanup. | Joel Sherrill | 1999-11-10 | 1 | -2/+9 | |
* | Patch from Eric Norum <eric@cls.usask.ca> which includes: | Joel Sherrill | 1999-11-10 | 3 | -8/+163 | |
| | | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP. | |||||
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 31 | -130/+688 | |
| | | | | Working Group. Included are tests. | |||||
* | Commented out single letter type names since they conflict with | Joel Sherrill | 1999-11-09 | 1 | -0/+6 | |
| | | | | numerous other uses of the same variable. | |||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 90 | -33/+7834 | |
| | | | | for RTEMS. | |||||
* | Fixed warning where initialized default POSIX API structure did | Joel Sherrill | 1999-11-09 | 1 | -0/+2 | |
| | | | | have have semaphores and message queue fields. | |||||
* | Removed unused variable warning. | Joel Sherrill | 1999-11-09 | 1 | -1/+0 | |
* | Added imfs_unixstub.c to satisfy linker problems on UNIX port. | Joel Sherrill | 1999-11-09 | 1 | -0/+71 | |
* | sem_close was accidentally lost in the split. | Joel Sherrill | 1999-11-09 | 1 | -0/+47 | |
* | Patch from Eric Norum <eric@cls.usask.ca> to add NTP BOOTP support because | Joel Sherrill | 1999-11-09 | 3 | -1/+48 | |
| | | | | | | | | EPICS needs a synchronized time-of-day clock. This patch is the changes needed to get NTP server information from a BOOTP server. This patch also adds NTP server information to the network configuration structure, too. | |||||
* | Correctly set and called handlers table for the link. | Jennifer Averett | 1999-11-05 | 1 | -1/+3 | |
* | Fixed comment | Jennifer Averett | 1999-11-05 | 1 | -1/+1 | |
* | Moved imfs set handlers prototype to the imfs.h file. | Jennifer Averett | 1999-11-05 | 2 | -6/+4 | |
* | New file. | Joel Sherrill | 1999-11-05 | 1 | -0/+38 | |
* | Unmount was failing as a side-effect of splitting the rmnod handler | Joel Sherrill | 1999-11-05 | 7 | -63/+102 | |
| | | | | and not handling every case properly. | |||||
* | Split unistd.c file into sysconf.c and sleep.c. | Joel Sherrill | 1999-11-05 | 2 | -0/+68 | |
* | Following comments from Eric Norum <eric@cls.usask.ca>, a fairly | Joel Sherrill | 1999-11-05 | 3 | -285/+260 | |
| | | | | | | | substantial upgrade of newlibc.c occurred. Now the user extension data area is used rather than notepads and as many routines as possible were split into other files further reducing the minimum footprint of an RTEMS executable. | |||||
* | Fixed typo. | Joel Sherrill | 1999-11-05 | 1 | -3/+3 | |
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 18 | -13/+176 | |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | |||||
* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 4 | -3/+54 | |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | |||||
* | Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMS | Joel Sherrill | 1999-11-03 | 5 | -8/+9 | |
| | | | | internal symbols are supposed to have leading underscores. | |||||
* | Added CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM as a configuration | Joel Sherrill | 1999-11-03 | 1 | -4/+3 | |
| | | | | parameter. | |||||
* | Added prototype of _POSIX_Semaphore_Delete to avoid warnings. | Joel Sherrill | 1999-11-03 | 1 | -0/+12 | |
* | Added prototype of POSIX_Thread_cancel_run to avoid warnings. | Joel Sherrill | 1999-11-03 | 1 | -0/+12 | |
* | Split core mutex and semaphore handlers into separate files. | Joel Sherrill | 1999-11-02 | 6 | -0/+561 | |
* | Split core message queue and watchdog handler objects into separate files. | Joel Sherrill | 1999-11-02 | 14 | -991/+861 | |
* | Split Heap and Time of Day Handlers. | Joel Sherrill | 1999-11-02 | 14 | -1535/+929 | |
* | Split threadq.c into multiple files. | Joel Sherrill | 1999-11-02 | 16 | -0/+1272 | |
* | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 1999-11-02 | 10 | -128/+227 | |
| | | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | |||||
* | Split object.c into multiple files. | Joel Sherrill | 1999-11-02 | 16 | -982/+1368 | |
* | Split types.s into individual files. | Joel Sherrill | 1999-11-02 | 11 | -171/+302 | |
* | Final tuning required to drop out POSIX timers. | Joel Sherrill | 1999-11-02 | 3 | -46/+58 | |
* | *** empty log message *** | Joel Sherrill | 1999-11-02 | 3 | -921/+979 | |
* | Split cancel.c into multiple files. | Joel Sherrill | 1999-11-02 | 7 | -182/+272 | |
* | Missed these in the initial split up. | Joel Sherrill | 1999-11-02 | 2 | -0/+177 | |
* | Split key.c into multiple files. | Joel Sherrill | 1999-11-02 | 6 | -225/+290 | |
* | Wrong routine was initially cut into this file. | Joel Sherrill | 1999-11-02 | 1 | -14/+6 | |
* | Split time.c into multiple files. | Joel Sherrill | 1999-11-02 | 13 | -365/+573 | |
* | Split condition variables into multiple files. | Joel Sherrill | 1999-11-02 | 14 | -482/+537 | |
* | Split the POSIX semaphore manager into multiple files. | Joel Sherrill | 1999-11-02 | 17 | -585/+829 | |
* | Split some more stuff out of psignal.c. | Joel Sherrill | 1999-11-02 | 6 | -235/+341 | |
* | Split mutex.c into multiple files. | Joel Sherrill | 1999-11-02 | 22 | -702/+1029 | |
* | Split mqueue into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -0/+28 | |
* | Removed warnings. | Joel Sherrill | 1999-11-02 | 1 | -2/+2 | |
* | Split mqueue.c into a variety of files. | Joel Sherrill | 1999-11-02 | 16 | -672/+1120 | |
