Update #4579.
Use volatile register r0 for the per-CPU control of the current
processor instead of the non-volatile register r7. This enables the use
of r7 in a follow up patch. Do the interrupt handling in ARM mode.
Update #4579.
Update #4579.
Make sure there are no pending events after a test case.
Update #4572.
close() file 'bf' to avoid leaking descriptor.
CID 1437645: Resource leak in rtems_fdt_load().
Closes #4297
This is done to get the target path for the overlay nodes which is very useful
in many cases. For example, Xen hypervisor needs it when applying overlays
because Xen needs to do further processing of the overlay nodes, e.g. mapping of
resources(IRQs and IOMMUs) to other VMs, creation of SMMU pagetables, etc.
Signed-off-by: Vikram Garhwal <fnu.vikram@xilinx.com>
Message-Id: <1637204036-382159-2-git-send-email-fnu.vikram@xilinx.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
UINT32_MAX is an integer of type unsigned int. UINT32_MAX + 1 overflows
unless explicitly computed as unsigned long long. This led to some
invalid addresses being treated as valid.
Cast UINT32_MAX to uint64_t explicitly.
Signed-off-by: Elvira Khabirova <e.khabirova@omp.ru>
The ALIGNMENT error was missing a string, leading to <unknown error>
being returned.
Signed-off-by: Georg Kotheimer <georg.kotheimer@kernkonzept.com>
With -Wsign-compare, compilers warn about a mismatching signedness in
the different legs of the conditional operator, in fdtget.c.
In the questionable expression, we are constructing a 16-bit value out of
two unsigned 8-bit values, however are relying on the compiler's
automatic expansion of the uint8_t to a larger type, to survive the left
shift. This larger type happens to be an "int", so this part of the
expression becomes signed.
Fix this by explicitly blowing up the uint8_t to a larger *unsigned* type,
before doing the left shift. And while we are at it, convert the hardly
readable conditional operator usage into a sane switch/case expression.
This fixes "make fdtget", when compiled with -Wsign-compare.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Message-Id: <20210618172030.9684-3-andre.przywara@arm.com>
Coverity gets a bit confused by loading fdt_size_dt_strings() and
using it in a memmove(). In fact this is safe because the callers
have verified this information (via FDT_RW_PROBE() in fdt_pack() or
construction in fdt_open_into()).
Passing in strings_size like we already do struct_size seems to get
Coverity to follow what's going on here.
Only checking the FDT alignment in fdt_ro_probe_() means that
fdt_check_header() can pass, but then subsequent API calls fail on
alignment checks. Let's add an alignment check to fdt_check_header() so
alignment errors are found up front.
Cc: Tom Rini <trini@konsulko.com>
Cc: Frank Rowand <frowand.list@gmail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20210406190712.2118098-1-robh@kernel.org>
Apparently the unchecked return value of the first fdt_next_tag() call in
fdt_add_subnode_namelen() is tripping Coverity Scan in some circumstances,
although it appears not to for the scan on our project itself.
This fdt_next_tag() should always return FDT_BEGIN_NODE, since otherwise
the fdt_subnode_offset_namelen() above would have returned BADOFFSET or
BADSTRUCTURE.
Still, add a check to shut Coverity up, gated by a can_assume() to avoid
bloat in small builds.
Reported-by: Ryan Long <ryan.long@oarcorp.com>
in fdt_open_into
Changes in v3:
- Remove noop version sets
- Set version correctly on loaded fdt in fdt_open_into
Fixes: f1879e1a50eb ("Add limited read-only support for older (V2 and V3) device tree to libfdt.")
Signed-off-by: Justin Covell <jujugoboom@gmail.com>
Message-Id: <20201229041749.2187-1-jujugoboom@gmail.com>
There's a small inaccuracy in the comment describing these new helpers.
This corrects it, and reformats while we're there.
Fixes: f98f28ab ("libfdt: Internally perform potentially unaligned loads")
Commits 6dcb8ba4 "libfdt: Add helpers for accessing unaligned words"
introduced changes to support unaligned reads for ARM platforms and
11738cf01f15 "libfdt: Don't use memcpy to handle unaligned reads on ARM"
improved the performance of these helpers.
On further discussion, while there are potential cases where we could be
used on platforms that do not fixup unaligned reads for us, making this
choice the default is very expensive in terms of binary size and access
time. To address this, introduce and use new fdt{32,64}_ld_ functions
that call fdt{32,64}_to_cpu() as was done prior to the above mentioned
commits. Leave the existing load functions as unaligned-safe and
include comments in both cases.
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Tom Rini <trini@konsulko.com>
Message-Id: <20201211022736.31657-1-trini@konsulko.com>
Tested-by: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de>
The device tree must be loaded in to memory at an 8-byte aligned
address. Add a check for this condition in fdt_ro_probe_() and a new
error code to return if we are not.
Message-Id: <20201104130605.28874-1-trini@konsulko.com>
The API documentation in libfdt.h seems to follow the Linux kernel's
kernel-doc format[1].
Running "scripts/kernel-doc -v -none" on the file reports some problems,
mostly missing return values and missing parameter descriptions.
Fix those up by providing the missing bits, and fixing the other small
issues reported by the script.
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Documentation/doc-guide/kernel-doc.rst
Message-Id: <20201012165331.25016-1-andre.przywara@arm.com>
in a comparison in fdt_strerror().
Force FDT_ERRTABSIZE to be signed (it's surely small enough to fit), so
that the types match. Also move the minus sign to errval, as this is
actually what we use in the next line.
Message-Id: <20201001164630.4980-7-andre.przywara@arm.com>
comparisons in fdt_get_string().
Introduce a new usigned variable, which holds the actual (negated)
stroffset value, so we avoid negating all the other variables and have
proper types everywhere.
Message-Id: <20201001164630.4980-6-andre.przywara@arm.com>
in a comparison in fdt_setprop_inplace_namelen_partial().
fdt_getprop_namelen() will only return negative error values in "proplen"
if the return value is NULL. So we can rely on "proplen" being positive
in our case and can safely cast it to an unsigned type.
Message-Id: <20201001164630.4980-5-andre.przywara@arm.com>
in a comparison in fdt_create_with_flags().
By making hdrsize a signed integer (we are sure it's a very small
number), we avoid all the casts and have matching types.
Message-Id: <20201001164630.4980-4-andre.przywara@arm.com>
in comparisons in fdt_move().
This stems from "bufsize" being passed in as a signed integer, even
though we would expect a buffer size to be positive.
Short of changing the prototype, check that bufsize is not negative, and
cast it to an unsigned type in the comparison.
Message-Id: <20201001164630.4980-3-andre.przywara@arm.com>
in a comparison in fdt_add_string_().
Make all variables unsigned, and express the negative offset trick via
subtractions in the code.
Message-Id: <20201001164630.4980-2-andre.przywara@arm.com>
in a comparison in fdt_node_offset_by_phandle().
Uses a better suited bitwise NOT operator to denote the special value of
-1, which automatically results in an unsigned type.
Message-Id: <20200921165303.9115-14-andre.przywara@arm.com>
in a comparison in fdt_resize().
A negative buffer size will surely do us no good, so let's rule this
case out first.
In the actual comparison we then know that a cast to an unsigned type is
safe.
Message-Id: <20200921165303.9115-10-andre.przywara@arm.com>
in a comparison in fdt_splice_().
Since we just established that oldlen is not negative, we can safely
Message-Id: <20200921165303.9115-8-andre.przywara@arm.com>
In the first two cases, we have just established that the signed values
are not negative, so it's safe to cast the values to an unsigned type.
Signed-off-by: Simon Glass <sjg@chromium.org>
Message-Id: <20200921165303.9115-7-andre.przywara@arm.com>
in a comparison in fdt_grab_space_().
All the involved values cannot be negative, so let's switch the types of
the local variables to unsigned to make the compiler happy.
Message-Id: <20200921165303.9115-4-andre.przywara@arm.com>
in comparisons in fdt_mem_rsv().
Since all involved values must be positive, change the used types to be
unsigned.
Message-Id: <20200921165303.9115-3-andre.przywara@arm.com>
With -Wsign-compare, compilers warn about mismatching signedness in
comparisons in fdt_offset_ptr().
This mostly stems from "offset" being passed in as a signed integer,
even though the function would not really tolerate negative values.
Short of changing the prototype, check that offset is not negative, and
use an unsigned type internally.
Message-Id: <20200921165303.9115-2-andre.przywara@arm.com>
fdt_check_node_offset_() checks for a valid offset but also changes the
offset by calling fdt_next_tag(). Hence, do not skip this function if
ASSUME_VALID_INPUT is set but only omit the initial offset check in that
case.
As this function works very similar to fdt_check_prop_offset_(), do the
offset check there as well depending on ASSUME_VALID_INPUT.
Message-Id: <1913141.TlUzK5foHS@noys4>
Signed-off-by: Patrick Oppenlander <patrick.oppenlander@gmail.com>
Message-Id: <20200616011217.15253-1-patrick.oppenlander@gmail.com>
Message-Id: <20200618042117.131731-1-patrick.oppenlander@gmail.com>
This condition uses bitwise OR but should be logical OR. Fix it.
Reported-by: kernel test robot <lkp@intel.com>
Message-Id: <20200615160033.87328-1-sjg@chromium.org>
libfdt: fix undefined behaviour in fdt_splice_()
Along the lines of commit d0b3ab0a0f46 ("libfdt: Fix undefined behaviour
in fdt_offset_ptr()"), fdt_splice_() similarly may not use pointer
arithmetic to do overflow checks. (The left side of the checks added by
d4c7c25c9ed1 ["libfdt: check for potential overrun in _fdt_splice()"]
doesn't really lend itself to similar replacement though.)
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Message-Id: <f2d09e81-7cb8-c5cc-9699-1ac05b0626ff@suse.com>
This error indicates a logic bug in the code calling libfdt, so VALID_DTB
is not really the right check. Update it to use VALID_INPUT instead.
Suggested-by: David Gibson <david@gibson.dropbear.id.au>
Message-Id: <20200302190255.51426-4-sjg@chromium.org>
If libfdt returns -FDT_ERR_INTERNAL that generally indicates a bug in the
library. Add a new assumption for these cases since it should be save to
disable these checks regardless of the input.
Message-Id: <20200302190255.51426-3-sjg@chromium.org>
Add a little more detail in a few of these comments.
Message-Id: <20200302190255.51426-2-sjg@chromium.org>
Fix 'saftey' and 'additional' typos noticed in the assumption series.
Reword the ASSUME_NO_ROLLBACK slightly to improve clarity.
Message-Id: <20200302190255.51426-1-sjg@chromium.org>
Move the data structure definitions closer to the directives which use
them.
If RTEMS_SMP is not defined, then Doxygen adds the comments intended for
conditional the lock member to the next member.
RTEMS untar implementation had problems with overwriting or integrating
archives into existing directory structures. This patch adapts the
behavior to mimic that of a GNU tar or BSD tar and extends the tar01
test to check for the behavior. That is:
* If a directory structure exists, the files from the archive will be
integrated. Existing files are overwritten.
* If a file exists and the archive contains a directory with the same
name, the file is removed and a directory is created. In the above
example: if l1/l2 is a file it will be overwritten with a new
directory.
* If a directory exists and the archive contains a file with the same
name, the directory will be replaced if it is empty. If it contains
files, the result is an error.
* An archive also can contain only a file without the parent
directories. If in that case one of the parent directories exists as a
file extracting the archive results in an error. In the example: if
l1/l2 is a file and the archive doesn't contain the directories but
only the file l1/l2/x.txt that would be an error.
* In case of an error, it is possible that the archive has been
partially extracted.
Closes #4568
In _Workspace_Initialize_for_one_area(), properly check if there is enough
free memory available for the configured workspace size.
The bug was introduced by commit 3d0620b607ff6459fec9d30efc1e0589bbd010f9.
The sample reporting wronly added values to the wrong bin in some cases.
Close #4566.
Since the previous Interrupt Manager Extension API moved to the
Interrupt Manager, we can move the interfaces to <rtems/rtems/intr.h> so
that they are available via #include <rtems.h>.
Move all rtems_scheduler_* directives to the new header file
<rtems/rtems/scheduler.h>. Add a Scheduler Manager API and
implementation group.
