* aclocal/canonical-target-name.m4, aclocal/enable-posix.m4:
Remove comment referring to HPUX.
* libnetworking/lib/ftpfs.c: Enable write and mount filesystem
with read-write access.
* ftpd/ftpd.c: Change SIX_MONTHS to time_t.
* sapi/include/rtems/io.h: Move extern "C" brace after includes.
* libnetworking/net/if_ppp.h: Eliminate pppattach, pppintr
(Unused).
* libnetworking/net/if_ppp.c: Eliminate pppintr (Unused).
* libnetworking/rtems/rtems_dhcp.c: Remove #define KERNEL.
* libnetworking/Makefile.am, libnetworking/rtems/rtems_bsdnet.h,
Remove -D_COMPILING_BSD_KERNEL_ (Unused).
* libnetworking/Makefile.am: Remove -DKERNEL.
* libnetworking/rtems/rtems_mii_ioctl.c: Remove #undef KERNEL.
* libnetworking/nfs/bootp_subr.c: #include <sys/ucred.h>.
* libcsupport/include/sys/ioccom.h: Remove #define KERNEL,
#define _KERNEL.
* libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c: Remove #define KERNEL.
* libfs/src/dosfs/fat_file.h, libfs/src/dosfs/fat_fat_operations.h:
* posix/src/barrierattrdestroy.c, posix/src/barrierattrinit.c,
posix/src/condbroadcast.c, posix/src/conddefaultattributes.c,
posix/src/condsignal.c, posix/src/condtimedwait.c,
posix/src/condwait.c, posix/src/key.c, posix/src/keycreate.c,
posix/src/keydelete.c, posix/src/keyrundestructors.c,
posix/src/killinfo.c, posix/src/mqueue.c,
posix/src/mqueuecreatesupp.c, posix/src/mqueueopen.c,
posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c,
posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c,
posix/src/mqueueunlink.c, posix/src/mutex.c,
posix/src/mutexattrdestroy.c, posix/src/mutexinit.c,
posix/src/mutexlock.c, posix/src/mutextimedlock.c,
posix/src/mutextrylock.c, posix/src/pbarrier.c,
posix/src/prwlock.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockwrlock.c, posix/src/psignalunblockthread.c,
posix/src/pspin.c, posix/src/pspinlock.c,
posix/src/pspintrylock.c, posix/src/pthread.c,
posix/src/pthreadattrdestroy.c, posix/src/pthreadcreate.c,
posix/src/pthreadinitthreads.c, posix/src/pthreadkill.c,
posix/src/pthreadonce.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer.c, posix/src/rwlockattrdestroy.c,
posix/src/rwlockattrinit.c, posix/src/semaphore.c,
posix/src/semaphorecreatesupp.c, posix/src/semdestroy.c,
posix/src/semopen.c, posix/src/semtrywait.c,
posix/src/semunlink.c, posix/src/semwait.c:
Eliminate TRUE/FALSE.
* score/include/rtems/score/object.h: Maximum index if 0xffff not 0xff
when using 32-bit ids. This resulted in unlimited configurations not
being able to create more than 255 objects of a class.
PR 1359/cpukit
* libcsupport/src/libio.c: rtems_libio_allocate:
rtems_libio_iop_freelist incorrectly zeroed on semaphore error. Now
checks error and does not modify anything until sure it has created
semaphore.
PR 1363/filesystem
* libfs/src/dosfs/fat.h: Fix issue where 32 bit values are not written
correctly in FAT f/s data.
PR 1364/cpukit
* libcsupport/src/gxx_wrappers.c: Fix compilation problems when
diagnostics enabled.
* libmisc/shell/shell.c: Fix command line parsing of valid
characters.
Joel Sherrill <joel.sherrill@oarcorp.com>
PR 1357/cpukit
* rtems/src/tasks.c: Ensure creating a task with no ASR is honored.
* rtems/src/tasks.c: Initialize event_condition to 0 just because.
* librpc/src/xdr/xdr_float.c: M32C has no native float but GCC soft
float should be IEEE format.
* score/src/objectextendinformation.c: Fold two paths into one.
* rtems/src/barrier.c, rtems/src/barrierwait.c,
rtems/src/clocktodvalidate.c, rtems/src/dpmem.c,
rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqcreate.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/part.c,
rtems/src/partcreate.c, rtems/src/partmp.c, rtems/src/ratemon.c,
rtems/src/region.c, rtems/src/regionmp.c, rtems/src/rtemstimer.c,
rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semmp.c,
rtems/src/semobtain.c, rtems/src/signalsend.c, rtems/src/taskcreate.c,
rtems/src/taskinitusers.c, rtems/src/taskmode.c, rtems/src/taskmp.c,
rtems/src/taskresume.c, rtems/src/tasks.c,
rtems/src/tasksetpriority.c: Eliminate TRUE/FALSE.
* libcsupport/src/gxx_wrappers.c, posix/include/mqueue.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/key.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, posix/src/condget.c,
posix/src/mqueuenametoid.c, posix/src/mutexget.c,
posix/src/semaphorenametoid.c, posix/src/semopen.c,
sapi/src/itronapi.c, sapi/src/posixapi.c: Make changes necessary for
all tests to run on SPARC with 16-bit Ids. This required ensuring
that all POSIX and compilering binding code makes a distinction
between the public Id type (e.g. pthread_t, etc.) and the RTEMS
Object_Id type. All POSIX Object Get routines should not take the
POSIX Id type as the argument. Sixteen bit RTEMS Ids should be placed
into the 32-bits reserved by the POSIX API type in a uniform manner
now. This removed all assumptions that the external Id types in POSIX
and ITRON are the same as the internal Object Id type.
* itron/inline/rtems/itron/semaphore.inl: THREAD_STATUS_PROXY_BLOCKING
should only be defined in multiprocessing configurations.
* posix/include/rtems/posix/key.h: Remove redundant prototypes for
inlines.
PR 1351/cpukit
* sapi/include/confdefs.h: Mask off unlimited object bit before using
configured number in calculations.
* score/include/rtems/score/object.h,
score/src/objectallocatebyindex.c: Object index should be int.
Fix bug when index is negative.
* score/src/objectextendinformation.c: Do not allow maximum number
of allocated objects to exceed maximum representable in index
field of Object Id.
* score/src/objectgetisr.c: Use same code that is in _Objects_Get
to extract index field of Object Id.
* varvects.h: Fix prototype.
* itron/include/itronsys/types.h: ITRON types should follow native
integer size.
* pppd/sys-rtems.c: Remove stray ';' introducing unreachable code.
* libcsupport/src/error.c: Remove hpux9 anachronism.
