* | record: Introduce <rtems/recordserver.h> | Sebastian Huber | 2019-08-28 | 4 | -34/+81 |
| | | | | | | | This helps to get rid of the <rtems/rtems/tasks.h> dependency in <rtems/record.h>. Update #3665. | ||||
* | record: Use BSS section instead of per-CPU data | Sebastian Huber | 2019-08-28 | 5 | -29/+32 |
| | | | | | | | | | | | The .rtemsrwset section is used for the per-CPU data. This section has loadable content. Place the ring buffers in the BSS section to avoid large executable image sizes. Not using the per-CPU data makes it possible to initialize the record support earlier. Update #3665. | ||||
* | record: Add data size to client | Sebastian Huber | 2019-08-27 | 2 | -0/+9 |
| | | | | | | | This is necessary to get the thread names properly on 32-bit and 64-bit targets. Update #3665. | ||||
* | record: Fix thread names on 64-bit targets | Sebastian Huber | 2019-08-27 | 2 | -2/+8 |
| | | | | | | Also fixes the thread names on signed char targets. Update #3665. | ||||
* | record: Improve overflow handling | Sebastian Huber | 2019-08-26 | 2 | -25/+63 |
| | | | | | Signal the accumulated item overflow count with the time of the first new item. | ||||
* | record: Fix off by one error | Sebastian Huber | 2019-08-26 | 1 | -1/+1 |
* | dev/sc16is752: Reduce RX FIFO trigger level | Sebastian Huber | 2019-08-26 | 1 | -2/+2 |
| | | | | This may help to avoid character loss. | ||||
* | dev/sc16is752: Set TLS to zero | Sebastian Huber | 2019-08-26 | 1 | -0/+14 |
| | | | | Ensures that the FCR values are used. | ||||
* | dev/sc16is752: Do FIFO reset separately | Sebastian Huber | 2019-08-26 | 1 | -0/+5 |
* | dev/sc16is752: Enable enhanced func early | Sebastian Huber | 2019-08-26 | 1 | -1/+2 |
* | dev/sc16is752: Write to right register | Sebastian Huber | 2019-08-26 | 1 | -1/+1 |
* | record: Add rtems_record_client_set_handler() | Sebastian Huber | 2019-08-17 | 1 | -0/+8 |
* | record: Pass bintime to client handlers | Sebastian Huber | 2019-08-17 | 2 | -10/+29 |
| | | | | This is a minor optimization. | ||||
* | record: Simplify client visit() | Sebastian Huber | 2019-08-17 | 1 | -14/+24 |
* | record: Remove superfluous cast | Sebastian Huber | 2019-08-17 | 1 | -1/+1 |
* | record: Increase client robustness | Sebastian Huber | 2019-08-17 | 2 | -10/+34 |
| | | | | Do nothing after errors. | ||||
* | record: Improve overflow handling | Sebastian Huber | 2019-08-17 | 2 | -10/+266 |
| | | | | | | | | In case of a ring buffer overflow, the rtems_record_drain() will push the complete ring buffer content to the client. While the items are processed by the client, new items may overwrite some items being processed. The overwritten items can be detected in the following iteration once the next tail/head information is pushed to the client. | ||||
* | record: Detect also large overflows | Sebastian Huber | 2019-08-16 | 2 | -19/+34 |
* | record: Simplify rtems_record_client_context | Sebastian Huber | 2019-08-16 | 2 | -19/+27 |
* | libdebugger/arm: Support ROM tables. | Chris Johns | 2019-08-12 | 1 | -9/+294 |
| | | | | | - Parse the ROM taables if present to find the component base for the debug hardware. This lets the RPi2 run dl09.exe. | ||||
* | libdl/debugger: Fix the broken list delete when unloading an object module. | Chris Johns | 2019-08-12 | 2 | -15/+13 |
| | | | | Closes #3777 | ||||
* | record: Change thread name encoding | Sebastian Huber | 2019-08-06 | 2 | -2/+2 |
| | | | | This scheme is easier to decode. | ||||
* | libdl/arm: Add support for ARM trampolines | Chris Johns | 2019-08-04 | 1 | -1/+18 |
| | | | | Closes #3776 | ||||
* | libdebugger: ARM fixes for Cortex-A8 and ARM mode. | Chris Johns | 2019-07-31 | 6 | -247/+730 |
| | | | | | | | | | - Fix destorying the target and thread parts. - Fix the ARM backend to support Cortex-A8 and ARM mode code. - Use the DBGDSCR interrupt mask when single stepping. - Use the DBGDSCR method of entry to debug mode to filter the execptions. - Add support for BSPs to control the ARM backend. | ||||
* | record: Add support for thread names | Sebastian Huber | 2019-07-30 | 4 | -8/+104 |
* | Add and use THREAD_DEFAULT_MAXIMUM_NAME_SIZE | Sebastian Huber | 2019-07-30 | 3 | -2/+11 |
* | libdl/arm: Fix ARM mode trampoline parsing of relocs | Chris Johns | 2019-07-28 | 1 | -16/+16 |
| | | | | | | - No need to dump globals syms in test dl01 when tracing Closes #3775 | ||||
* | score/interr: Fix comments. | Chris Johns | 2019-07-06 | 1 | -2/+2 |
* | misc/rtemsdefaultconfig: Add bdbuf so libbsd can be used with configure. | Chris Johns | 2019-07-02 | 1 | -1/+2 |
* | score: Add and use _Thread_Get_unmapped_priority(). | Sebastian Huber | 2019-06-28 | 7 | -42/+65 |
| | | | | Add and use _Thread_Get_unmapped_real_priority(). | ||||
* | arm: Return the current handler from arm_cp15_set_exception_handler | Chris Johns | 2019-06-28 | 1 | -1/+6 |
| | | | | Closes #3762 | ||||
* | libdebugger: Unmap thread priorities | Sebastian Huber | 2019-06-26 | 1 | -2/+3 |
* | rtems/confdefs.h: Fix typo | Joel Sherrill | 2019-06-19 | 1 | -1/+1 |
* | dev/sc16is752: Add set/get EFCR IO controls | Sebastian Huber | 2019-06-14 | 2 | -0/+16 |
* | dev/sc16is752: Add RS485 mode variants | Sebastian Huber | 2019-06-14 | 3 | -5/+31 |
* | libdl/rap: fix RAP file load error. | zhengxiaojun | 2019-06-12 | 1 | -2/+2 |
* | sparc: Fix mistakenly cleared PSR[EF] bit. | Maksim E. Kozlov | 2019-06-07 | 1 | -1/+1 |
| | | | | | The superfluously modified %l0 had no effect if the branch is not taken. This change clarifies the code. | ||||
* | sparc: Fix missed restoring of PSR in syscall_lazy_fp_switch | Maksim E. Kozlov | 2019-06-06 | 1 | -0/+11 |
| | | | | | | | | | It is needed to restore PSR just before return because condition codes are dirty after the CMP instructions and this may cause undefined program behavior after returning from the switching procedure (on following branch instruction, for example). Close #3756. | ||||
* | sparc: Improve _CPU_Context_validate() | Sebastian Huber | 2019-06-06 | 1 | -8/+20 |
| | | | | | | Use the FPU and check that the condition codes in the PSR are preserved. Update #3756. | ||||
* | score: Compact objects class indices | Sebastian Huber | 2019-05-22 | 1 | -20/+28 |
* | libdl: Sort object file symbols and use a binary search to find | Chris Johns | 2019-05-22 | 3 | -9/+55 |
| | | | | | | | - Replace the linear object file symbol search with a binary search. - Sort the object file symbols after loading. Closes #3748 | ||||
* | score: Add _SMP_Unicast_action() | Sebastian Huber | 2019-05-20 | 3 | -0/+67 |
* | score: Add _Per_CPU_Wait_for_job() | Sebastian Huber | 2019-05-20 | 2 | -27/+48 |
* | score: Remove superfluous include | Sebastian Huber | 2019-05-20 | 1 | -1/+0 |
* | score: Add _SMP_Synchronize() | Sebastian Huber | 2019-05-20 | 2 | -0/+18 |
* | score: Remove unused SMP_MESSAGE_TEST | Sebastian Huber | 2019-05-20 | 2 | -33/+1 |
| | | | | All uses were replaced by per-processor jobs. | ||||
* | score: Modify _Per_CPU_Perform_jobs() | Sebastian Huber | 2019-05-20 | 1 | -5/+7 |
| | | | | | | | | Process only the jobs initially registered on the processing list. This makes it possible to add jobs for the current processor in a job handler. These jobs are processed with the next SMP_MESSAGE_PERFORM_JOBS message. The lock is only acquired and released once. | ||||
* | score: Add _Per_CPU_Add_job() | Sebastian Huber | 2019-05-20 | 2 | -17/+35 |
* | score: Move per-processor job data structures | Sebastian Huber | 2019-05-20 | 2 | -72/+74 |
| | | | | | This enables re-use for other purposes, e.g. replacement for SMP_MESSAGE_TEST. | ||||
* | score: Remove SMP_MESSAGE_CLOCK_TICK | Sebastian Huber | 2019-05-20 | 1 | -10/+0 |
| | | | | Use _SMP_Multicast_action() instead. |
