* cpu.c, cpu_asm.S: Remove /*PAGE markers which were interpreted by a
long dead print script.
* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Remove /*PAGE markers which were
* score/include/rtems/score/mppkt.h: Remove extra spaces.
PR 1839/filesystem
* libcsupport/include/rtems/libio_.h, libcsupport/src/fchdir.c,
libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c,
libcsupport/src/fsync.c, libcsupport/src/ftruncate.c,
libcsupport/src/read.c, libcsupport/src/readv.c,
libcsupport/src/write.c, libcsupport/src/writev.c: Some calls did not
return proper status for permission errors or incorrectly permissions
at all.
* libnetworking/rtems/rtems_showipstat.c: Print IP input queue drops.
* rtems/score/cpu.h: Added SPE support to CPU context.
* libfs/src/dosfs/fat_file.c, libmisc/monitor/monitor.h,
score/cpu/m68k/rtems/score/cpu.h: Remove stray spaces from unsigned32
to uint32_t conversion.
* libcsupport/include/rtems/libio_.h: Added
rtems_filesystem_is_root_location().
* libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_eval.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c: Use
PR 1842/cpukit
* score/include/rtems/score/basedefs.h: Added RTEMS_STATIC_ASSERT().
* score/include/rtems/score/chain.h: Fix typo.
PR 1838/filesystem
* libcsupport/src/fchmod.c: fchmod() does not need a writeable file
descriptor.
* rtems/src/msgqcreate.c: Make packet size check consistent with
_Message_queue_MP_Send_request_packet().
* libnetworking/lib/ftpfs.c: Fixed reply parsing.
* rtems/src/msgmp.c: Getting a remote object does not start a critical
section.
* score/src/threadenabledispatch.c: Modified to call
_Thread_Dispatch_decrement_disable_level() instead of accessing the
variable directly.
* libcsupport/src/malloc_report_statistics_plugin.c: Fixed format
specifiers.
* score/Makefile.am, score/preinstall.am,
score/include/rtems/score/isr.h, score/include/rtems/score/percpu.h:
Split isrlevel into its own file to avoid a circular dependancy in
smp code.
* score/include/rtems/score/isrlevel.h: New file.
PR 1381/networking
* netinet/ip_output.c: If a null or unreachable gateway is
specified either statically in networkconfig.h or from dhcp/bootp,
sendto() fails on multicast send with errno "118 Host is unreachable".
The failure occurs in networking file ip_output.c since it currently
requires all multicasts to have a valid route to the outside world.
PR 1381/networking
* libnetworking/netinet/ip_output.c: If a null or unreachable gateway
is specified either statically in networkconfig.h or from dhcp/bootp,
sendto() fails on multicast send with errno 118 Host
PR 1775/filesystem
* libfs/src/nfsclient/src/nfs.c: NFSAddress NFS issue where read/write
problems when requested bytes greater than nfsStBlksize. Failure to
create files and symlinks.
PR 1824/cpukit
* sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/exshutdown.c:
Return exit/shutdown status back to boot_card().
PR 1823/cpukit
* libmisc/fb/fb.h: Added FBIOSETVIDEOMODE define.
* score/src/coremsg.c: Use 64-bit intermediate result on multiply to
reliably detect overflow.
* libblock/src/nvdisk-sram.c, libi2c/libi2c.c,
libmisc/shell/main_msdosfmt.c: Eliminate use of GNU old-style field
designator extension as recommended by clang.
* libnetworking/rtems/tftp.h, libnetworking/lib/tftpDriver.c: Fixed
prototype.
PR 1827/filesystem
* libfs/src/rfs/rtems-rfs-rtems.c: Skip the parent (..) path value
when eval make moving up out of the RFS file system.
* libcsupport/src/malloc_initialize.c: After discussion with Till
Straumann, revert the change from r1.12 to r1.13. This broke BSPs
with sbrk() support once the libbsp sbrk() framework was enhanced.
psim runs now.
PR 1826/cpukit
* libmisc/cpuuse/cpuusagereport.c, rtems/Makefile.am,
rtems/preinstall.am, rtems/include/rtems.h: Add SMP Helper methods to
Classic API.
* rtems/include/rtems/rtems/smp.h: New file.
* score/Makefile.am, score/include/rtems/score/schedulersimplesmp.h,
score/src/schedulersimplesmptick.c: Build schedulersimplesmptick.c
and fix typos.
* posix/include/semaphore.h, posix/include/rtems/posix/mutex.h,
posix/inline/rtems/posix/mutex.inl: Fix typos.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* Doxyfile.in, score/include/rtems/score/apimutex.h,
score/include/rtems/score/basedefs.h,
score/include/rtems/score/object.h: Fix some Doxygen warnings.
Sebastien Bourdeauducq <sebastien@milkymist.org>
PR 1724/cpukit
* ftpd/ftpd.h, ftpd/ftpd.c: Added USER/PASS authentication.
* rtems/score/cpu.h, rtems/score/sparc.h, rtems/score/types.h: Convert
comments to Doxygen style and improve.
* rtems/include/rtems/rtems/tasks.h: Complete manager description.
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
PR 1819/cpukit
* rtems/src/clocktick.c, score/Makefile.am,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/schedulersimple.h,
score/inline/rtems/score/scheduler.inl: Add a scheduler entry point
which is invoked at each clock tick. _Thread_Tickle_timeslice() is
now a method owned by the Deterministic Priority Scheduler and shared
by the Simple Priority Scheduler. The Simple SMP Scheduler has its
own variation on this which does timeslicing bookkeeping on all
cores.
* score/src/schedulerprioritytick.c,
score/src/schedulersimplesmptick.c: New files.
* score/src/threadtickletimeslice.c: Removed.
* libcsupport/include/rtems/libio.h, cpukit/libcsupport/src/termios.c:
Added const qualifier to rtems_termios_enqueue_raw_characters().
Removed superfluous cast.
PR 1818/misc
* libmisc/cpuuse/cpuusagereport.c: Add SMP support to CPU Usage
Reporting.
* score/src/smp.c: Spinlock Name change necessary to resolve
compalation error.
* score/src/threadtickletimeslice.c: Spacing.
PR 1812/filesystem
* libfs/src/imfs/imfs_stat.c: stat() implementation for IMFS did not
set st_blksize field. Set it based upon user configuration.
* score/src/smp.c: Fix typo so this compiles.
PR 1811/networking
* ftpd/ftpd.c: Fixed reply format.
PR 1796/cpukit
* sapi/src/exshutdown.c, score/include/rtems/score/percpu.h,
score/include/rtems/score/smp.h, score/src/smp.c,
score/src/threaddispatch.c, score/src/threadhandler.c: Added SMP
interprocess communications.
* score/include/rtems/score/percpu.h,
score/include/rtems/score/prioritybitmap.h,
score/src/heapfree.c,
score/src/objectinitializeinformation.c,
score/src/rbtree.c, score/src/rbtreeextract.c,
score/src/rbtreefind.c, score/src/rbtreeinsert.c,
score/src/rbtreepeek.c, score/src/schedulerpriorityenqueue.c,
score/src/schedulerpriorityenqueuefirst.c,
score/src/schedulerpriorityextract.c,
score/src/schedulerpriorityupdate.c,
score/src/schedulersimple.c,
score/src/schedulersimpleextract.c,
score/src/schedulersimpleschedule.c,
score/src/schedulersimplesmpschedule.c,
score/src/schedulersimpleyield.c,
score/src/smp.c, score/src/smplock.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadsetstate.c, score/src/threadsettransient.c:
Remove white-spaces.
