2011-03-18 | Import from zlib-1.2.5 | Ralf Corsepius | 17 | -85/+227 | |
2011-03-18 | Import from zlib-1.2.5 | Ralf Corsepius | 5 | -20/+20 | |
2011-03-18 | Import from zlib-1.2.5 | Ralf Corsepius | 2 | -20/+21 | |
2011-03-18 | Import from zlib-1.2.5 | Ralf Corsepius | 2 | -48/+35 | |
2011-03-18 | Import from zlib-1.2.5 | Ralf Corsepius | 4 | -36/+74 | |
2011-03-18 | Import from zlib-1.2.5 | Ralf Corsepius | 1 | -2/+7 | |
2011-03-18 | 2010-04-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+7 | |
* zconf.h: Regenerate by zlib's configure. Eliminate HAVE_UNISTD_H. Use Z_PREFIX. | |||||
2011-03-18 | 2010-03-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -9/+4 | |
* zconf.h: Add include of config.h | |||||
2011-03-18 | Import from zlib-1.2.5 | Ralf Corsepius | 1 | -1/+2 | |
2011-03-18 | Make code match prototype to eliminate warnings. | Thomas Doerfler | 7 | -4/+22 | |
eliminate unneeded comilation of 64 bit functions | |||||
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 4 | -506/+764 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -1/+1 | |
2011-03-18 | This commit was manufactured by cvs2svn to create branch 'zlib'. | cvs2git | 6 | -0/+2084 | |
Cherrypick from master 2011-03-18 10:11:29 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com>': cpukit/zlib/doc/algorithm.txt cpukit/zlib/gzclose.c cpukit/zlib/gzguts.h cpukit/zlib/gzlib.c cpukit/zlib/gzread.c cpukit/zlib/gzwrite.c | |||||
2011-03-18 | 2010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 28 | -2243/+4032 | |
* ChangeLog.zlib, FAQ, Makefile.am, README, adler32.c, compress.c, crc32.c, deflate.c, deflate.h, infback.c, inffast.c, inflate.c, inflate.h, inftrees.c, inftrees.h, trees.c, uncompr.c, zconf.h, zlib.3, zlib.h, zutil.c, zutil.h: Update to zlib 1.2.4. * gzclose.c, gzguts.h, gzlib.c, gzread.c, gzwrite.c, doc/algorithm.txt: New files. * algorithm.txt, gzio.c: Removed. | |||||
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 2 | -40/+42 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 3 | -1/+536 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 2 | -208/+157 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -68/+411 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -92/+179 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -8/+14 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 3 | -26/+77 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 3 | -117/+250 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -8/+121 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 2 | -5/+36 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -48/+37 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 5 | -10/+126 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 3 | -47/+965 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 12 | -1134/+3162 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 2 | -6/+12 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -85/+197 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -4/+11 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -3/+1 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -4/+4 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -81/+139 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -15/+15 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 3 | -82/+120 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -9/+8 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 2 | -17/+30 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -9/+29 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -7/+26 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -2/+2 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -8/+9 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 2 | -12/+48 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -2/+3 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -6/+6 | |
2011-03-18 | Import from zlib-1.2.4 | Ralf Corsepius | 1 | -3/+3 | |
2011-03-18 | Import zlib-1.2.3 | Ralf Corsepius | 80 | -3040/+8849 | |
2011-03-16 | 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com> | Joel Sherrill | 21 | -598/+995 | |
PR 1729/cpukit * configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S, score/cpu/sparc/rtems/score/cpu.h, score/include/rtems/score/basedefs.h, score/include/rtems/score/context.h, score/include/rtems/score/percpu.h, score/src/percpu.c, score/src/thread.c, score/src/threadcreateidle.c: Add next step in SMP support. This adds an allocated array of the Per_CPU structures to support multiple cpus vs a single instance of the structure which is still used if SMP support is disabled. Configuration support is also added to explicitly enable or disable SMP. But SMP can only be enabled for the CPUs which will support it initially -- SPARC and i386. With the stub BSP support, a BSP can be run as a single core SMP system from an RTEMS data structure standpoint. * aclocal/check-smp.m4, aclocal/enable-smp.m4, score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h, score/src/smp.c, score/src/smplock.c: New files. | |||||
2011-03-16 | 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com> | Joel Sherrill | 16 | -1/+743 | |
PR 1743/cpu * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Simple Priority Scheduler as complement to existing Deterministic Priority Scheduler. This scheduler serves both as an example and as a lighter weight implementation for smaller systems. * score/include/rtems/score/schedulersimple.h, score/inline/rtems/score/schedulersimple.inl, score/src/schedulersimple.c, score/src/schedulersimpleblock.c, score/src/schedulersimpleenqueue.c, score/src/schedulersimpleenqueuefirst.c, score/src/schedulersimpleextract.c, score/src/schedulersimplereadyqueueenqueue.c, score/src/schedulersimplereadyqueueenqueuefirst.c, score/src/schedulersimpleschedule.c, score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c: New files. |
