* | Jennifer found some uninitialized variables: | Joel Sherrill | 1998-01-16 | 1 | -1/+7 |
| | | | | | | + major and minor number elements in rtems_termios_open. + arg->ioctl_return in rtems_termios_ioctl routine. | ||||
* | Error reported by Duncan Smith <dds@flavors.com>: | Joel Sherrill | 1998-01-15 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | >> >>There is a 30 day error in _TOD_Days_since_last_leap_year[2..3] >> > >> >Thanks. >> >What's the condition to hit this error? >> >Every year 4n+2 and 4n+3 ? >> >(i.e. 1998, 1999, 2002, 2003, ...) >> > >> OK: 96 97 00 01 04 05 ... >> Bad: 98 99 02 03 06 07 ... There is also a problem in newlib 1.7.x reported at the same time: >> I found another, that would strike only on 2/29/2000, or other leapyears. >> Only a problem on 1 day. >> >> Joel: FYI, there is a bug in Newlib localtime.c, localtime or (_tm_time). >> Ours is modified for dst and timezones, but the bug was in original source. >> I have not looked at the latest public source (nor do I know where to find >> it). | ||||
* | Changed initial settings of first time. | Joel Sherrill | 1998-01-06 | 1 | -3/+5 |
* | Fixed spacing. | Joel Sherrill | 1998-01-06 | 1 | -2/+2 |
* | Added CONFIGURE_GNAT_KEYS to correct the number of keys configured | Joel Sherrill | 1997-12-23 | 1 | -12/+11 |
| | | | | | | | | | for GNAT. It was the number of Ada tasks when in fact the run-time only required a single key. Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account for resources allocated for each non-Ada task/thread which invokes the Ada run-time implicitly through an Ada call. | ||||
* | Corrected prototypes for all termios console write driver entries to | Joel Sherrill | 1997-12-22 | 2 | -3/+4 |
| | | | | properly reflect the const on the buffer pointer being passed in. | ||||
* | Fixed indexing bug reported by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 1 | -1/+1 |
* | Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were defined. | Joel Sherrill | 1997-12-06 | 1 | -2/+2 |
| | | | | | This simple error resulted in the wrong FP context structure being used for hardware contexts on the m68k. This was a difficult problem to find. | ||||
* | Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto Romano | Joel Sherrill | 1997-12-01 | 1 | -0/+2 |
| | | | | | <pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/). | ||||
* | Removed warnings. | Joel Sherrill | 1997-11-29 | 2 | -1/+6 |
* | Removed warning under linux port. | Joel Sherrill | 1997-11-18 | 1 | -0/+5 |
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 1 | -1/+6 |
* | interrupt driven change from Eric Norum | Joel Sherrill | 1997-11-15 | 2 | -83/+191 |
* | Fixed prototype | Joel Sherrill | 1997-11-10 | 1 | -1/+1 |
* | Set return code to avoid spurious errors. | Joel Sherrill | 1997-11-10 | 1 | -0/+1 |
* | added katsutoshi Shibuya | Joel Sherrill | 1997-10-24 | 1 | -1/+8 |
* | Changed prototype of read routine. | Joel Sherrill | 1997-10-23 | 2 | -14/+7 |
* | Added prototype for console_reserve_resources. | Joel Sherrill | 1997-10-23 | 1 | -0/+4 |
* | fixed comment | Joel Sherrill | 1997-10-23 | 1 | -2/+1 |
* | New termios.c from Eric Norum. | Joel Sherrill | 1997-10-23 | 2 | -601/+646 |
| | | | | Added new entry point to add in per physical port resource requirements. | ||||
* | Fixed a number of warnings regarding comparisons between signed and | Joel Sherrill | 1997-10-21 | 4 | -9/+9 |
| | | | | unsigned numbers. | ||||
* | Fixed endian problem in printing object names. | Joel Sherrill | 1997-10-21 | 1 | -0/+5 |
* | Added check that return argument pointer for old_isr_handler was valid. | Joel Sherrill | 1997-10-21 | 1 | -0/+3 |
* | Converted from using a message queue for the raw input queue to using a | Joel Sherrill | 1997-10-21 | 1 | -49/+35 |
| | | | | ring buffer in conjunction with a counting semaphore. | ||||
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 1 | -0/+760 |
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 1 | -2/+22 |
* | Added casts and fixed line break. | Joel Sherrill | 1997-10-21 | 1 | -2/+3 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 250 | -500/+500 |
* | Fixed comment. | Joel Sherrill | 1997-10-06 | 1 | -1/+1 |
* | Make Post an atomic operation. | Joel Sherrill | 1997-10-06 | 2 | -2/+12 |
* | Added _Thread_Enable_dispatch to already_timedout path on Wait_support. | Joel Sherrill | 1997-10-06 | 1 | -2/+3 |
* | If the specified time period is less than a clock tick, then | Joel Sherrill | 1997-10-05 | 1 | -1/+4 |
| | | | | it is arbitrarily assumed to be 1 clock tick. | ||||
* | fixed typo | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Fixed typos. | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Uncommented gettimeofday_r to resolve missing symbol. | Joel Sherrill | 1997-09-21 | 1 | -2/+0 |
* | Cleaned up as part of adding the Monitor test. | Joel Sherrill | 1997-09-21 | 17 | -27/+21 |
* | Bug fix from Eric Norum: | Joel Sherrill | 1997-09-19 | 1 | -1/+0 |
| | | | | | | | | | | | After weeks of trying to figure why my RTEMS/KASQ server crashes now and then I found a nasty bug I introduced in adding multiple-driver support to libio. The bug only affects `add-on' driver classes (like the networking code). Old-style file descriptors were not affected. The bug cleared 32 bytes of memory (unspecified location) whenever a `close' of a socket was performed! I was clearing an IOP I hadn't allocated -- and the pointer wasn't initiallized, either! | ||||
* | updated | Joel Sherrill | 1997-09-16 | 1 | -4/+11 |
* | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 1997-08-28 | 2 | -64/+9 |
| | | | | but not in newer RTEMS. | ||||
* | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 1997-08-28 | 2 | -1/+3 |
* | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1997-08-28 | 1 | -3/+5 |
* | Added error numbers and changed default error code from 0 to -1 for | Joel Sherrill | 1997-08-27 | 1 | -7/+9 |
| | | | | error number mapping. | ||||
* | Corrected bug per Katsutoshi Shibuya's report: | Joel Sherrill | 1997-08-22 | 2 | -4/+4 |
| | | | | | | | The definition of "BEGIN_DATA" should not be null; should be ".data". Also, the definition of "BEGIN_BSS" should be ".bss". For this error, the compiled object has codes that write on the text segment area. It is fatal when the code runs on ROM. | ||||
* | Removed assert condition when not initialized or there are 0 periods. | Joel Sherrill | 1997-08-22 | 1 | -0/+5 |
* | Moved reentrant wrappers into their own file. | Joel Sherrill | 1997-08-22 | 1 | -4/+2 |
* | Fixed iop/memory leak bug reported by Dan Dickey. | Joel Sherrill | 1997-08-22 | 1 | -1/+6 |
* | Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER. | Joel Sherrill | 1997-08-22 | 1 | -10/+15 |
* | Added commit about missing support for condition initializer. | Joel Sherrill | 1997-08-22 | 1 | -0/+1 |
* | new implementation of mc68681.h | Joel Sherrill | 1997-08-04 | 1 | -72/+291 |
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 1 | -4/+19 |
