* posix/src/semaphorecreatesupp.c: Fixed warning.
* libmisc/dumpbuf/dumpbuf.c: Use printk.
* libnetworking/net/ppp_defs.h: Include rtems/stdint.h.
Use uint32_t for ext_accm.
* pppd/auth.c, pppd/demand.c, pppd/ipcp.c, pppd/ipcp.h,
pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c,
pppd/pppd.h, pppd/sys-rtems.c, pppd/utils.c: Convert to using C99
fixed-size types instead of BSD fixed-size types.
* libmisc/stackchk/check.c: Fix alignment of output.
* libmisc/monitor/monitor.h: Add network commands that were in the
network supplement but not in the code.
* libmisc/monitor/mon-network.c: New file.
PR 1261/cpukit
* posix/src/semaphorecreatesupp.c: Initialize all fields during
semaphore creation.
PR 1260/cpukit
* posix/src/pthread.c: Get initial signals blocked from creating
thread not from ourselves.
* score/src/watchdogtickle.c: Remove tabs.
PR 1259/rtems
* rtems/src/taskcreate.c: Initialize is_global in all cases since
memory is not guaranteed to be zero.
PR 1258/rtems
* cpukit/score/src/heapallocatealigned.c (block_allocate): New routine.
* cpukit/score/src/heapallocatealigned.c (_Heap_Allocate_aligned):
Use block_allocate() instead of _Heap_Block_allocate(). Replace
_Heap_Head(the_heap)->next with equivalent _Heap_First(the_heap).
* cpukit/score/src/heap.c (_Heap_Allocate): fix comments according
to changed block split strategy in _Heap_Allocate_aligned().
* cpu_asm.S: Fix two problems:
- CC bit has been clobbered and was not correctly restored
- bfin hardware does not allow to read instructions from the L1
* libcsupport/src/printk.c: Remove unnecessary comments.
* rtems/bfin/bf533.h: Add more definitions.
* libcsupport/src/malloc.c: If RTEMS_HEAP_DEBUG is defined, add heap
walk on init, malloc, and free. The ability to walk the heap appears
to disappeared during the rework of the C Program heap to skip the
Region.
* score/src/heap.c: Style.
* score/src/heapwalk.c: Add more information to prints.
* score/src/pheapwalk.c: Do not lock allocator mutex if dispatching
is disabled.
* libcsupport/Makefile.am, libcsupport/src/printk.c:
* libcsupport/src/printk_plugin.c: New file.
include/rtems/bspIo.h, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuuse.h, libmisc/stackchk/check.c,
libmisc/stackchk/stackchk.h: rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemonreportstatistics.c: Added capability to specify
your own "printf" routine to various reporting functions. This
added an XXX_with_plugin as the underlying implementation for
+ rtems_rate_monotonic_report_statistics
+ rtems_stack_checker_report_usage
+ rtems_cpu_usage_report
As demonstration, the http netdemo can now print out stack
and cpu usage reports.
* shttpd/compat_rtems.c: Style clean up.
* rtems/src/ratemonperiod.c: Clean up.
* rtems/src/ratemonreportstatistics.c: Clarify period statistics output.
* libmisc/monitor/mon-monitor.c: Fix warnings and typo.
* libmisc/untar/untar.c, libmisc/untar/untar.h: Clean up prototype.
* libmisc/Makefile.am: Add new files.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c,
libmisc/monitor/monitor.h: Merge minor parts of Thomas' improvements
that are needed by osmonweb.
* libmisc/untar/untar.c, libmisc/untar/untar.h: Add const to char *.
Use printk.
* rtems/include/rtems/rtems/clock.h, score/src/threadhandler.c: Fix
spacing and spelling.
PR 1256/networking
* ftpd/ftpd.c: Fix unaligned access.
* posix/Makefile.am: Always build nanosleep.
* libmisc/capture/README: Minor copyright change.
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h: Fixed the memory leak when lots of
tasks are being created and deleted. Improved the trigger
interface so all task type actions can be caught.
* score/include/rtems/score/object.h: Point the
OBJECTS_RTEMS_CLASSES_LAST macro to the last entry.
* rtems/score/m68k.h: Add stubs for mcf5307, mcf5407, mcfv4e.
* rtems/score/cpu.h: Use uintptr_t instead of uint32_t.
* score/cpu/mips/rtems/score/cpu.h: Use uintptr_t instead of
uint32_t.
PR 1248/networking
* libnetworking/rtems/rtems_glue.c: Luke Stras <luke@spacequest.com>
reported that when no interfaces are successfully attached, the
default route is broken and may result in a jump to an illegal
address.
* cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h:
Replace M68K_COLDFIRE_ARCH with __mcoldfire__.
* score/inline/rtems/score/priority.inl: Use size_t instead of
uint32_t for array index.
* libnetworking/netinet/in_cksum_m68k.h: Use __mcoldfire__ to
identify coldfire cpus.
* shttpd/log.c: Add preliminary version of SPLIT_SNPRINTF to
work-around bug m68k/coldfire -fomit-frame-pointer bug
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=32307.
* wrapup/Makefile.am: Create archive from a file for hosts with
a limited command line size.
* include/rtems/bspIo.h, include/rtems/pci.h:
Add extern "C" guards. Reported by
Robert S. Grimes <rsg@alum.mit.edu>.
* libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c,
score/src/timespecdivide.c: Fix various math and reporting bugs. Now
the time appears to be reported correctly and add up to what is
expected.
* shttpd/Makefile.am: Prefix all non-public symbols with _shttp_.
* shttpd/compat_rtems.c: Don't build my_stat for rtems.
* shttpd/defs.h: Don't build most of my_* wrappers for rtems.
