Changed back to Newlib for Solaris UNIX simulator.
like signal dispatching.
correct Information block.
(andy@i-cubed.demon.co.uk). This initial submission is known
to work on the IBM 403. It is thought to work on the Motorola
601, 603, and 604 although this remains to be tested.
Another user -- Doug Currie (e@flavors.com) -- is interested in
this work and will be testing it on the 604 using the Metrowerks
C compiler and a different format assembly language.
incorporate variable length object names. Previously the algorithm
scanned an array of 4-byte names for a match. Now it scans the
object table, grabs a pointer to the name, and then compares it
if the object is active and has a name.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
newlib C library.
Fixed bug where length did not take into account amount added
for alignment requirements.
newlib C library.
blocking mechanism for it.
+ c/src/lib/libc/support/generic/malloc.c did not initialize the
sbrk amount
+ _Thread_Handler in c/src/exec/rtems/thread.c left a window
during the begin extension which could result in a context switch
fixed places which did not correctly distinguish between an
CPU_isr and a CPU_isr_entry.
