path: root/cpukit (follow)
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-0151-52/+54
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-0129-28/+45
| | | | | | | | | | | | | | | | | * src/imfs/Makefile.am, src/imfs/deviceio.c, src/imfs/imfs_chown.c, src/imfs/imfs_config.c, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c, src/imfs/imfs_directory.c, src/imfs/imfs_eval.c, src/imfs/imfs_fchmod.c, src/imfs/imfs_free.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_gtkn.c, src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c, src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_readlink.c, src/imfs/imfs_rmnod.c, src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c, src/imfs/imfs_unixstub.c, src/imfs/imfs_unlink.c, src/imfs/imfs_unmount.c, src/imfs/imfs_utime.c, src/imfs/ioman.c, src/imfs/memfile.c, src/imfs/miniimfs_init.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Now we do not have to reach up and over to libc to pick them up.
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-1/+5
| | | | | * configure.in: Cleanup comments. * bsp_specs: Add qnolinkcmds.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-3116-36/+50
| | | | | | | | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c, src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c, src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c, src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c: Use of _read, _write, and _close as macros conflicted with newlib's use of these as routine names. They were renamed to include "_RPC_" prefix.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-313-0/+14
| | | | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * machine/types.h: Added _CLOCKID_T_ and _TIMER_T_ to be in sync with newlib's <machine/types.h>. * rtems/rtems_bsdnet_internal.h: newlib now includes definition of struct itimerval in <sys/time.h>.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-312-1/+9
| | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * include/confdefs.h: Replaced include of <sys/siginfo.h> with <signal.h> since that file no longer exists.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-3111-10/+28
| | | | | | | | | | | | | | | | | | | * include/Makefile.am: Updated to reflect files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * include/unistd.h: Removed. Now use newlib's. * include/rtems/posix/mqueue.h: Add include of <signal.h>. * include/rtems/posix/threadsup.h: Add include of <sys/signal.h> * src/execv.c: Corrected prototype to agree with newlib. * src/execve.c: Corrected prototype to agree with newlib. * src/execvp.c: Corrected prototype to agree with newlib. * src/psignal.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. * src/pthreadkill.c: Added include of <signal.h>. * src/sigaction.c: Added include of <signal.h>. * src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. *
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-261-1/+1
| | | | | | * configure.in: Remove bogus cfg_subdirs. * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-2540-20/+120
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-254-2/+12
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-254-33/+5
| | | | | | | | | | | | * libc/ioman.c: Moved to libfs. * libc/Makefile.am: Removed ioman.c as part of moving it to libfs. * libc/base_fs.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific. * libc/libio.h: Removed prototype of IMFS_ops since it should not be in this file. * libc/mount.c: Removed IMFS specific configuration information. * libc/unmount.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-253-8/+48
| | | | | | | * src/imfs/imfs_config.c: New file containing IMFS configuration information split from libc/base_fs.c. * src/imfs/ioman.c: New file. Moved from lib/libc. Missed previously. * src/imfs/Makefile.am: Added imfs_config.c and ioman.c.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-242-1/+9
| | | | | | | | * Makefile.am, configure.in: Introduce GNU canonicalization to libfs/. The approach is currently a bit of a hack as GNU canonicalization does not support the per-BSP build some of the other directories require. As more of the tree is converted, this will become less of an issue.
* 2000-10-24 Alan Cudmore <alanc@linuxstart.com> andJoel Sherrill2000-10-2412-194/+662
| | | | | | | | | | | | | | | | | | | | | | | | | | | Joel Sherrill <joel@OARcorp.com> * This is a major reworking of the mips64orion port to use gcc predefines as much as possible and a big push to multilib the mips port. The mips64orion port was copied/renamed to mips to be more like other GNU tools. Alan did most of the technical work of determining how to map old macro names used by the mips64orion port to standard compiler macro definitions. Joel did the merge with CVS magic to keep individual file history and did the BSP modifications. Details follow: * Makefile.am: idtmon.h in mips64orion port not present. * asm.h: MIPS64ORION replaced with MIPS. Frame setup macros added. * cpu.c: Comments added. * cpu_asm.S: Conditionals changed. MIPS ISA level 1 support added. First attempt at exception/interrupt processing for ISA level 1 and minus any use of IDT/MON added. * idtcpu.h: Conditionals changed to use gcc predefines. * iregdef.h: Ditto. * cpu_asm.h: No real change. Merger required commit. * rtems/Makefile.am: Ditto. * rtems/score/Makefile.am: Ditto. * rtems/score/cpu.h: Change MIPS64ORION to MIPS. * rtems/score/mips64orion.h: Change MIPS64ORION to MIPS. Convert from using RTEMS_CPU_MODEL to gcc predefines to figre things out.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-202-0/+9
| | | | * shared/ppc.h: For multilibs, derive PPC_HAS_FPU from _SOFT_FLOAT.
* 2000-10-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-195-0/+35
| | | | | * .cvsignore, src/.cvsignore, src/imfs/.cvsignore, wrapup/.cvsignore: New files.
* 2000-10-19 Antti P Miettinen <anmietti@trshp.ntc.nokia.com>Joel Sherrill2000-10-193-13/+21
| | | | | | * lib/tftpDriver.c: add comments to handlers struct function pointers. * rtems/rtems_glue.c: move pointer arithmetic to be _after_ pointer has been checked against NULL.
* 2000-10-19 Antti P Miettinen <anmietti@trshp.ntc.nokia.com>Joel Sherrill2000-10-194-9/+24
| | | | | * rtems/score/cpu.h: define CPU_Exception_frame for rdbg. * m68302.h: Make buffer pointer in m302_SCC_bd volatile.
* 2000-10-18 Chris Johns <ccj@acm.org>Joel Sherrill2000-10-186-0/+176
| | | | | | | | | | | | | | | | | | | | | | * libfs created. * src, src/imfs, wrapup: New directories. * ChangeLog, Makefile.am, README, configure.in, src/Makefile.am, wrapup/Makefile.am: New files. * src/imfs/deviceio.c, src/imfs/imfs_getchild.c, src/imfs/imfs_readlink.c, src/imfs/imfs.h, src/imfs/imfs_gtkn.c, src/imfs/imfs_rmnod.c, src/imfs/imfs_chown.c, src/imfs/imfs_handlers_device.c, src/imfs/imfs_stat.c, src/imfs/imfs_creat.c, src/imfs/imfs_handlers_directory.c, src/imfs/imfs_symlink.c, src/imfs/imfs_debug.c, src/imfs/imfs_handlers_link.c, src/imfs/imfs_unixstub.c, src/imfs/imfs_directory.c, src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_unlink.c, src/imfs/imfs_eval.c, src/imfs/imfs_init.c, src/imfs/imfs_unmount.c, src/imfs/imfs_fchmod.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_utime.c, src/imfs/imfs_fcntl.c, src/imfs/imfs_link.c, src/imfs/memfile.c, src/imfs/imfs_fdatasync.c, src/imfs/imfs_mknod.c, src/imfs/miniimfs_init.c, src/imfs/imfs_free.c, src/imfs/imfs_mount.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_ntype.c: New files. Moved from libc.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-0/+6
| | | | | * include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0 if there is no Classic API Initialization Tasks Table defined.
* 2000-10-18 Chris Johns <ccj@acm.org>Joel Sherrill2000-10-182-1/+5
| | | | * pppd/ipxcp.c: Fixed a typo.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-0/+41
| | | | | | | * libc/Makefile.am: Added mallocfreespace.c. * libc/mallocfreespace.c: New file based on work by Nick Simon <Nick.SIMON@syntegra.bt.co.uk> which he included in malloc.c. * libc/libcsupport.h: Added prototype for malloc_free_space().
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-185-1/+101
| | | | | | | * src/regiongetinfo.c, include/rtems/rtems/region.h, include/rtems/rtems/types.h, src/Makefile.am: Added region_get_information() and information control block. * src/regiongetinfo.c: New file.
* 2000-10-18 Nick Simon <Nick.SIMON@syntegra.bt.co.uk>Joel Sherrill2000-10-184-1/+152
| | | | | | * src/heapgetinfo.c, include/rtems/score/heap.h, src/Makefile.am: Added _Heap_Get_information() and information control block. * src/heapgetinfo.c: New file.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-4/+6
| | | | | | | * libc/fcntl.c: Do not require every filesystem to have an fcntl() handler. Most fcntl() operations can be performed with no filesystem support. * ChangeLog: Corrected comment.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-183-17/+29
| | | | | | | * cpu_asm.S, rtems/score/cpu.h: Modified to better support multilibing. These changes result in the code being able to compile with the default gcc settings. It is not functional in this configuration but does compile.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-5/+13
| | | | | * rtems/score/c4x.h: Modified to properly multilib. This required using only macros predefined by gcc.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-5/+29
| | | | | | * include/confdefs.h: Modified code that accounts for initialization task/threads with greater than minimum stack sizes so it would compile even if optional APIs are disabled.
* 2000-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-122-0/+11
| | | | | * include/confdefs.h: Account for initialization tasks and threads which use larger than minimum stack sizes.
* 2000-10-12 John S Gwynne <jgwynne@mrcday.com>Joel Sherrill2000-10-123-10/+22
| | | | | | | | | | | | | | * sim.h: These changes enable RTEMS to automatically generate the ram_init file used by gdb with the BDM patches. The 332 has on-board chip select lines (for RAM and FLASH) that must be configured before use of these peripherals. These patches parse data from start.c where the chip select lines are configured in the runtime executable and automatically generates the gdb initialization file using the same settings. A great time saver. A similar file, ram_init_FW (flash writable), is also generated that the flash programming tool uses. * BSP/start/start.c: Must be modified to support above. * BSP/start/ram_init.ld, BSP/start/ram_init.sed: New files.
* 2000-09-29 Stephan Merker <merker@decrc.abb.de>Joel Sherrill2000-09-294-3/+21
| | | | | | | * include/rtems/rtems/ratemon.h, src/ratemonperiod.c, src/ratemontimeout.c: Add next_length field so period length can be changed by the the sequence period(X), period(not X) with no intervening cancel or expiration.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-282-6/+11
| | | | | * monitor/mon-driver.c: Accounted for addition of "_entry" to fields in rtems_driver_address_table.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-283-12/+18
| | | | | | * include/rtems/io.h (rtems_driver_address_table): Added "_entry" to all names. * src/io.c: Accounted for above.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-2834-121/+121
| | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-0/+789
| | | | | | * rtems_webserver/Makefile.am, rtems_webserver/base64.c, rtems_webserver/base64.c: Renamed base64.c to wbase64.c. * rtems_webserver/sock.c: Added file missed in merger.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-283-4/+10
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-252-2/+9
| | | | | * rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not targopts.h to reduce dependency on BSP.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-252-0/+12
| | | | | * rtems/score/hppa.h: Switched to using cpuopts.h not targopts.h to reduce dependency on BSP.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-253-5/+18
| | | | | * rtems/score/a29k.h, rtems/score/cpu.h: Switched to using cpuopts.h not targopts.h to reduce dependency on BSP.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-225-9/+24
| | | | | | | | | | * machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-222-0/+5
| | | | * src/xdr/xdr_float.c: Added A29K support.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-1/+1
| | | | * libc/newlibc.c: Removed _A29K specific ifdef.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-227-8/+87
| | | | | | * amd.ah, cpu.c, cpu_asm.S, register.ah, sig.S, rtems/score/cpu.h: Updated and fixed minor things. Commented out offensive assembly and made applications link.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-225-17/+26
| | | | | | * Makefile.am, cpu_asm.S, psmacro.ah, rtems/score/cpu.h: First attempt to compile with GNU tools. Minor modifications to compile enough to get to assembler errors.
* 2000-09-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-202-1/+5
| | | | | * src/objectgetbyindex.c: Do not enable dispatching on an error path it was not disabled on.
* 2000-09-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-122-1/+5
| | | | * rtems/score/i386.h: Corrected "#elsif" to be "#elif".
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-122-1/+5
| | | | * Makefile.am: Use += to set up AM_CPPFLAGS.
* 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-061-0/+4
| | | | * wrapup/rtems/Makefile.am: Use PROJECT_TOPdir in path to size_rtems.
| | | | * rtems/score/Makefile.am: Use PROJECT_TOPdir in path to genoffsets.
