* nios2-context-switch.S: Use small-data area access for
_Per_CPU_Information fields.
* score/include/rtems/score/tod.h: Declare _TOD_Set_with_timestamp()
and _TOD_Get_as_timestamp().
* score/src/coretodset.c: Define _TOD_Set_with_timestamp().
* score/src/coretodget.c: Define _TOD_Get_as_timestamp().
* rtems/src/clockset.c: Use _TOD_Set_with_timestamp().
* score/include/rtems/score/timestamp64.h, score/src/ts64set.c:
Changed parameter types of _Timestamp64_Set().
* rtems/src/clocktodtoseconds.c: Year 2100 is not a leap year.
* rtems/include/rtems/rtems/clock.h, rtems/src/clockset.c: Added const
qualifier in rtems_clock_set().
PR 1914/cpukit
* score/src/timespecgreaterthan.c, score/src/ts64greaterthan.c:
Removed files.
* score/Makefile.am: Reflect changes above.
* score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h, score/src/ts64addto.c,
score/src/ts64divide.c, score/src/ts64dividebyinteger.c,
score/src/ts64equalto.c, score/src/ts64getnanoseconds.c,
score/src/ts64getseconds.c, score/src/ts64lessthan.c,
score/src/ts64set.c, score/src/ts64settozero.c,
score/src/ts64subtract.c, score/src/ts64toticks.c,
score/src/ts64totimespec.c: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC,
CPU_TIMESTAMP_USE_INT64, and CPU_TIMESTAMP_USE_INT64_INLINE. Removed
copy and paste.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
PR 1914/cpukit
PR 1923/testing
* score/src/schedulercbsgetexecutiontime.c: Improve coverage.
* rtems/score/armv7m.h, armv7m-context-initialize.c,
armv7m-context-restore.c, armv7m-context-switch.c,
armv7m-exception-handler-get.c, armv7m-exception-handler-set.c,
armv7m-exception-priority-get.c, armv7m-exception-priority-set.c,
armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c,
armv7m-isr-level-get.c, armv7m-isr-level-set.c,
armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New
files.
* Makefile.am, preinstall.am: Reflect changes above.
* rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and
ARM_MULTILIB_ARCH_V7M.
* rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S,
arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S:
Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use
ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M.
PR 1921/cpukit
* score/inline/rtems/score/thread.inl,
score/src/threadstartmultitasking.c: Allow CPU port to provide
optional multitasking start and stop.
PR 1914/cpukit
* rtems/score/cpu.h: Document CPU_TIMESTAMP_USE_STRUCT_TIMESPEC,
PR 1916/testing
* rtems/src/ratemondelete.c, score/src/schedulercbsreleasejob.c,
score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: Rework
to improve coverage.
* nios2-eic-il-low-level.S, nios2-eic-rsie-low-level.S: New files.
* rtems/score/cpu.h, rtems/score/nios2-utility.h,
nios2-thread-dispatch-disabled.c, nios2-context-switch.S: Added
support for thread stack protection via the MPU.
* rtems/score/arm.h: More CPU_MODEL_NAME variants.
* libmisc/shell/shell-wait-for-input.c: New file.
* libmisc/Makefile.am: Reflect change above.
* libmisc/shell/shell.h: Declare rtems_shell_wait_for_input().
* score/include/rtems/score/thread.h: Ensure CBS builds with POSIX
disabled.
PR 1906/cpukit
* sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h,
score/Makefile.am, score/preinstall.am: Add the CBS (Constant
Bandwidth Server) scheduler. This is a complex scheduling policy
built atop of the EDF scheduler. Unlike other schedulers, this one
provides a user API and handles not only deadlines of tasks but also
claimed budget per period. The main aim of the scheduler is isolation
of tasks so that each task is guaranteed to meet all deadlines
regardless of how other tasks behave.
* sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl,
score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c,
score/src/schedulercbsattachthread.c,
score/src/schedulercbscleanup.c,
score/src/schedulercbscreateserver.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbsgetserverid.c,
score/src/schedulercbssetparameters.c,
score/src/schedulercbsunblock.c: New files.
* cpukit/libmisc/cpuuse/cpuuse.h,
cpukit/libmisc/cpuuse/cpuusagedata.c,
cpukit/libmisc/cpuuse/cpuusagereport.c,
cpukit/libmisc/cpuuse/cpuusagereset.c: Fixed timestamp usage.
* rtems/score/cpu.h: Request cache alignment and small data area in
CPU_STRUCTURE_ALIGNMENT.
PR 1898/cpukit
* score/include/rtems/score/percpu.h: Use CPU_STRUCTURE_ALIGNMENT for
_Per_CPU_Information.
PR 1896/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Earliest Deadline First (EDF) Scheduling Algorithm implementation.
* score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c,
score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c,
score/src/scheduleredfenqueue.c,
score/src/scheduleredfenqueuefirst.c,
score/src/scheduleredfextract.c, score/src/scheduleredffree.c,
score/src/scheduleredfprioritycompare.c,
score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c,
score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c,
score/src/scheduleredfyield.c: New files.
PR 1901/cpukit
* score/src/threadhandler.c: Do not use internal tasks for global
initialization in MP configuration.
PR 1844/cpukit
* rtems/include/rtems/rtems/msgmp.h: Define
MESSAGE_QUEUE_MP_PACKET_SIZE.
* rtems/src/msgmp.c, rtems/src/msgqcreate.c: Use
PR 1873/cpukit
* score/include/rtems/score/heap.h: Revert previous commit.
* sapi/include/confdefs.h: Use proper constants in
_Configure_From_workspace().
* score/include/rtems/score/basedefs.h: Typo.
* score/src/mpci.c, rtems/src/eventmp.c, rtems/src/msgmp.c,
rtems/src/partmp.c, rtems/src/regionmp.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskmp.c: Use RTEMS_STATIC_ASSERT() to
ensure that the packet size is small enough.
* nios2-thread-dispatch-disabled.c: Use offsetof() instead of
RTEMS_offsetof().
* rtems/score/nios2-utility.h, nios2-isr-set-level.c,
nios2-isr-get-level.c: Renamed functions.
* libmisc/monitor/mon-monitor.c: Removed "exit" and "quit" commands to
avoid confusion. They were an alias to the "fatal" command.
* rtems/score/nios2-utility.h: Use the same values for defines used by
Altera HAL.
* rtems/score/nios2-utility.h: Avoid redefines with Altera HAL.
Declare _Nios2_ISR_Set_level().
* nios2-context-initialize.c: Use _Nios2_ISR_Set_level().
* nios2-isr-set-level.c: Define _Nios2_ISR_Set_level().
PR 1895/cpukit
* score/src/coretodmsecstoticks.c, score/src/coretodusectoticks.c,
score/src/timespectoticks.c: Ensure time conversions to ticks do not
ignore partial tick and return 1 less than desired.
PR 1895/cpukit
* rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, sapi/include/confdefs.h,
score/Makefile.am, score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/schedulersimple.h,
score/include/rtems/score/schedulersimplesmp.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/coremutexseize.c: Add priority_compare and release_job
hooks interfaces to scheduler interface.
* score/src/schedulerpriorityprioritycompare.c,
score/src/schedulerpriorityreleasejob.c: New files.
* cpu.c, cpu_asm.S: Removed files.
* nios2-context-initialize.c, nios2-context-switch.S,
nios2-fatal-halt.c, nios2-initialize-vectors.c, nios2-initialize.c,
nios2-isr-get-level.c, nios2-isr-install-raw-handler.c,
nios2-isr-install-vector.c, nios2-isr-is-in-progress.c,
nios2-isr-set-level.c, nios2-thread-dispatch-disabled.c,
rtems/score/nios2-utility.h: New files.
* irq.c: Update due to API changes.
* rtems/score/cpu.h: New functions _CPU_Initialize_vectors(),
_CPU_ISR_Set_level(), and _CPU_Fatal_halt() (instead of macros).
Support for external interrupt controller (EIC). Documentation
changes.
* rtems/score/cpu.h: Add more context access functionality. Needed to
get GDB debugger hooks working.
* rtems/include/rtems/rtems/tasks.h: Formatting.
* include/rtems/userenv.h, score/src/threadhandler.c: Formatting.
* sapi/src/exshutdown.c: Add comments.
* rtems/powerpc/registers.h: Renamed defines XER in PPC_XER, LR in
PPC_LR, CTR in PPC_CTR, PVR in PPC_PVR, RPA in PPC_RPA, DAR in
PPC_DAR, DEC in PPC_DEC, and EAR in PPC_EAR.
PR 1876
* score/Makefile.am, score/include/rtems/score/isr.h, score/src/isr.c,
score/src/smp.c, score/src/smplock.c, score/src/threaddispatch.c,
score/src/threaddispatchdisablelevel.c: Add smp isr support.
* score/src/isrsmp.c: New file.
PR 1886/cpukit
* sapi/include/rtems/rbtree.h, sapi/inline/rtems/rbtree.inl,
score/include/rtems/score/rbtree.h,
score/inline/rtems/score/rbtree.inl, score/src/rbtree.c,
score/src/rbtreeinsert.c: This patch enables inserting duplicate keys
into rbtree. It is possible to turn on this feature when initializing
the tree.
PR 1890/cpukit
* posix/src/mqueuerecvsupp.c: POSIX says msg_prio is allowed to be
NULL.
PR 1873/cpukit
* score/include/rtems/score/heap.h: When using heap protection, we
should account for adding an aligned protection footer.
* cpu.c: Fix the ISR get level for the IIC. Make
_CPU_Context_Initialize a function rather than inlined.
* cpu_asm.S: Do not enable interrupt on return, rather resume the
state on entry to the ISR.
* irq.c, nios2/nios2-iic-low-level.S: Change the ISR handler so
the ipending decoding is in C and within the interrupt
context. This is usable with the Altera HAL directly.
* rtems/score/cpu.h: Add ienable and ipending interfaces. Add some
comments. Remove _CPU_Context_Initialize.
PR 1868/lm32
* irq.c: Bugfix.
* sapi/include/confdefs.h: Revert previous commit due to multi-lib
rule violation.
* sapi/include/confdefs.h: Include <bsp.h> for BSP_IDLE_TASK_BODY,
BSP_IDLE_TASK_STACK_SIZE, BSP_INTERRUPT_STACK_SIZE,
BSP_ZERO_WORKSPACE_AUTOMATICALLY, BSP_DEFAULT_UNIFIED_WORK_AREAS,
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK, and
CONFIGURE_BSP_PREREQUISITE_DRIVERS defines.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Added
init/fini array support for ARM EABI. The __libc_init_array() and
__libc_fini_array() functions are provided by Newlib.
* rtems/score/cpu.h: Clear the vector table for simple vectored
interrupts.
* irq.c: Add support for using the IIC with the Altera HAL.
* rtems/score/cpu.h: Removed superfluous comments. Format. Include
by assembler support. Removed superfluous floating-point support.
Stack alignment is now 4.
* rtems/score/cpu.h, cpu.c: Removed superfluous functions.
* nios2-iic-low-level.S: New file.
* cpu_asm.S: Moved low-level interrupt handling into new file.
* Makefile.am: Reflect change from above.
