* libnetworking/libc/res_comp.c,
libnetworking/netinet/igmp.c,
libnetworking/netinet/in_cksum.c,
libnetworking/netinet/in_proto.c,
libnetworking/netinet/tcp_debug.c,
libnetworking/netinet/tcp_input.c,
libnetworking/netinet/tcp_output.c,
libnetworking/netinet/tcp_timer.c:
Remove BSD "Add clause" (From FreeBSD).
* libnetworking/net/if_ethersubr.c, libnetworking/net/if_loop.c,
libnetworking/net/if_ppp.c, libnetworking/net/ppp_tty.c,
libnetworking/net/radix.c, libnetworking/net/raw_cb.c,
libnetworking/net/raw_usrreq.c, libnetworking/net/route.c,
libnetworking/net/rtsock.c, libnetworking/net/slcompress.c:
Stop using old-style function definitions.
* libcsupport/include/timerdrv.h: Rename timer driver methods to follow
RTEMS programming conventions.
* posix/Makefile.am, rtems/src/tasksetpriority.c: Improve comments and
wrapping.
* ftpd/ftpd.c: Fix prototype.
* libmisc/Makefile.am, libmisc/shell/shell.c, libmisc/shell/shell.h:
Split out rtems_shell_get_prompt() so it can be overridden by the
user.
* libmisc/shell/shell_getprompt.c: New file.
* libnetworking/libc/getproto.c, libnetworking/libc/getprotoent.c,
libnetworking/libc/getprotoname.c,
libnetworking/libc/getservbyname.c,
libnetworking/libc/inet_makeaddr.c, libnetworking/libc/recv.c,
libnetworking/libc/send.c: Stop using old-style
function-definitions.
* libmisc/fsmount/fsmount.c: Convert to using bool.
* pppd/auth.c, pppd/ccp.c, pppd/chap.c, pppd/chat.c,
pppd/demand.c, pppd/fsm.c, pppd/ipcp.c, pppd/lcp.c,
pppd/magic.c, pppd/options.c, pppd/rtemsmain.c,
pppd/sys-rtems.c, pppd/upap.c, pppd/utils.c:
Stop using old-style function-definitions.
* libblock/src/bdbuf.c, libblock/src/diskdevs.c,
libblock/src/ide_part_table.c, libblock/src/ramdisk.c:
s/rtems_boolean/bool/g.
* libmd/md4.c, libmd/md5.c:
* libcsupport/src/closedir.c, libcsupport/src/getcwd.c,
libcsupport/src/mount.c, libcsupport/src/newlibc.c,
libcsupport/src/opendir.c, libcsupport/src/readdir.c,
libcsupport/src/scandir.c:
* libcsupport/src/malloc_boundary.c: Use %zi to print size_t.
* libmisc/capture/capture.c, libmisc/shell/fts.c:
* libblock/include/rtems/bdbuf.h, libblock/include/rtems/diskdevs.h,
libblock/src/bdbuf.c, libblock/src/blkdev.c, libblock/src/diskdevs.c,
libblock/src/ramdisk.c: Eliminate sign mismatch warnings.
* libmisc/monitor/mon-network.c: Use memset instead of bzero.
* libmisc/shell/internal.h: Don't include "config.h".
Adjust header guard.
* libmisc/shell/cmp-ls.c, libmisc/shell/err.c,
libmisc/shell/errx.c, libmisc/shell/filemode.c,
libmisc/shell/fts.c, libmisc/shell/main_cp.c,
libmisc/shell/main_ls.c, libmisc/shell/main_mv.c,
libmisc/shell/main_rm.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/shellconfig.c,
libmisc/shell/utils-cp.c, libmisc/shell/utils-ls.c,
libmisc/shell/verr.c, libmisc/shell/verrx.c,
libmisc/shell/vis.c, libmisc/shell/vwarn.c,
libmisc/shell/vwarnx.c, libmisc/shell/warn.c,
libmisc/shell/warnx.c: Include "config.h".
* libmisc/monitor/mon-network.c, libmisc/monitor/mon-part.c,
libmisc/monitor/mon-region.c, libmisc/monitor/mon-sema.c:
Include "config.h".
* libmisc/shell/main_ifconfig.c: Use memset instead of bzero.
* ftpd/ftpd.c: Don't use annonymous unions.
* libblock/src/flashdisk.c: Remove bool, true, false.
* rtems/score/avr.h: Add avr25, avr31, avr35, avr51 to
CPU_NAME cascade.
* rtems/score/cpu.h: Add missing prototypes.h.
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* libmisc/dummy/dummy.c: Add missing initializers.
* score/src/threadinitialize.c: Change type of loop counter.
* libcsupport/src/error.c, libmisc/dummy/dummy.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c: Add 0 for missing initializers.
* include/rtems/status-checks.h: Fixed integer conversion warning.
* configure.ac: Abort if stdbool.h is not c99 compliant.
* pppd/pppd.h: Use stdbool.h. Remove local bool.
